Question about Faria Chesapeake Series Tachometer
Find instruction manual for Dixco Pro Tester 7 Diagnostic Analyzer
Circuit tester when plugged into 3 pronged plug, comes up with 2 green lights and 1 yellow light. There is no code on other side of tester to access this problem
Circuit analyzer does not show all possible problems, and tester might be defective.
Use analyzer on other outlets.
Buy another circuit analyzer.
Buy a multimeter at local hardware, and test for voltage, and continuity, and compare with known outlet that are functioning correctly.
For example outlet may be 240Volt instead of 120V.
Copy following links to see typical circuit analyzer and code:
http://waterheatertimer.org/images/Typical-circuit-analyzer-15.jpg
http://waterheatertimer.org/images/Outlet-polarity-200.jpg
May 22, 2012 | Leviton Electrical Supplies
Engine light came on and now it blinks off and on when its on solid car runs good but when it blinks car loses all its power wont hardly run and shakes
you need to hook up a diagnostic code retrieving tool to the aldl [ assembly line diagnostic link ] this is normally located on the drivers side under the instrument panel, it should be about 2 1/2 - 3 inches wide. the tester reteives the trouble codes that your car's computer has stored, you hook the tester up to the link, and turn your ignition key on, and the tester will start picking up the information that is stored in your computer, once it shows the code #s, write them down, and compare the # or #s to the diagnostic booklet that the tester comes with. [ follow the instructions of the tester] if you do not have a tester, your loacl auto part store can do this for you, normally free of charge.
Feb 20, 2011 | 2006 Lincoln Zephyr
Does a 91' camry have an on board diag computer and how do you access trouble codes
ill bet it has a connector under the dash or hood which you can connect to a diagnostic analyzer.
you get the error codes from the analyzer.
Jan 20, 2011 | 1991 Toyota Camry
My printer will not print black ink i just changed 3 cartridges
HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 27, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Searching for obd 2 port
Hi!!
The OBD Diagnostic Link Connector is located in front seating area, passenger side, under dash, above kick panel, mounted rear of glove compartment.
Don't forget to rate this post, Good Luck!!
Apr 27, 2010 | 1997 Ford Thunderbird LX
Need a manual for a 92163 engine analyzer
Hello there
If you do a google search for the tester using the make and model number you will be able to find all a viewable users that is printable plus any information that you may be looking for ok
best regards mike
Aug 08, 2009 | Measuring Tools & Sensors
Help me to find Laptop Analyzer Diagnostic Card
Most of the time you don't need a Diagnostic card because you can swap components and if you get POST error codes they detail the faulty component.
The Diagnostic card can point to motherboard problems but 90% of the time motherboard faults with surface mounted chips cannot be fixed easily.
May 23, 2009 | Computers & Internet
Faria Chesapeake Series Tachometer Logo
617 people viewed this question
Top Faria Boating Experts
Steve
Steve
ray gallant
Bill Boyd
Are you a Faria Boating Expert? Answer questions, earn points and help others
