Question about RCA HD52W59 HDTV Projection Television
3 -D coloring red, blue, green.yellow. Overlapping picture
  • RCA Master
  • 8,617 Answers
That symptom can usually be repaired by installing the kit called The ITC222 and ITC222A convergence option missing repair kit available from www.tvrepairworld.com The kit contains the parts and the CD with instructions.
Posted on Sep 01, 2010
IGO tv connected with dish sound come from tv but pictur not show only blue color show
Component RCA Connectors are RED, BLUE, GREEN for picture. Sound is RED and WHITE. The red and white for sound work the same with the YELLOW that does picture. If the RED, BLUE, GREEN are in the wrong order you will get a blue or green picture. For the sound, try the other red and white connectors nearby. Make shore the right red connectors are connected correctly for sound or picture. Otherwise there could be a cable fault or a TV fault. If you get the picture right but not the sound, connect the sound into a stereo.
Jul 17, 2017 | Televison & Video
What is convergence IC problem
Convergence has to do with how different colors are displayed on a screen or monitor - typically the rear projection and some other types. When colors are overlapping to create unexpected combinations, or leave gaps between areas where overlapping is expected that results in a shifted red, green or blue image strip or edge - that is an indication of a convergence issue. They can look like this in severe cases:
Colors will drift, so manufacturers often include a utility to help you nudge the colors back in the right place. Most times this utility is buried in the Set Up Menu and when activated, produces a screen like this:
You will need to adjust the red, green and blue colors for each cross so that only a white cross is displayed. Keep red, green and blue fringing to a minimum. When you're done, the screen should look black and white, symmetrical and straight - like this:
Problems arise when you are no longer able to coax the utility to give you these crisp, B&W results with no red, blue or green ghosting. This is often due to a failing convergence integrated circuit ("Convergence IC"). Many times, replacing it will solve the problem, but other times it can be the result of failing components either ahead or after this IC. If you're attempting to replace this IC, please make sure the TV or monitor has been *unplugged* for 24 hours or more to allow the dangerously high voltages to dissipate.
Sep 08, 2014 | Hitachi 50VS810 50" Rear Projection HDTV
I need the color code for phone cables. 25 pair up to 1800 pair. I need to splice it.
white/blue
white orange
white green
white brown
white slate
red blue
red orange
red green
red brown
red slate
black blue
black orange
black green
black brown
black slate
yellow blue
yellow orange
yellow green
yellow brown
yellow slate
violet blue
violet orange
violet green
violet brown
violet slate
**Keep all pairs together and you should be fine***
Feb 22, 2010 | Lands Phones
Pictures coming out green
On a picture that you have printed, when you see an area of green, what color should it be? You probably have reduced flow of one of the "balancing" colors. Blue, Yellow and Red add up to Black. If your picture is supposed to be almost black and you don't have enough red, the color will pull toward the blue and yellow, giving it a green tint.
Aug 04, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Colors arched and overlapping
if the option for convergence is still listed under the setting section of the on screen menu, then you need a convergence power supply board. If the convergence option is missing from the menu you need the ITC222 convergence missing repair kit. You can get either one at the following link they include instructions for the repair.
http://www.tvrepairworld.com/
Jul 13, 2009 | RCA R52WM24 52" HDTV Projection Television
DVD won't play movies in color
RCA cable connectors (red,white, yellow) are usually for an analog setup. You could still use these for "component" setup, but know the difference with color stamps as follows:
Component color stamps are "blue, green, red" ( blue is marked Pb, green is marked Y, red is marked Pr)
RCA color stamps your using are "red, white, yellow"
Here are the proper hook up method for "Component" using your "RCA" connectors:
On both the TV and DVD component setup:
Plug the red RCA fitting in the component port marked "Pr (red)
Plug the white RCA fitting in the component port marked "Pb (blue)
Plug the yellow RCA fitting in the component port marked "Y (green)
Be sure this setup is the same for the TV's component input ports, and the DVD's component output ports.
i-Note:
For optimum picture quality you may want to purchase component cables as the gage is thicker giving better impedance match resulting in better picture and sound quality.
Jan 25, 2009 | Vizio Televison & Video
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Yellow haze
The blue filter is burnt out. A very common problem in Zenith DLPs. There are 3 color filters, 1 blue (a pinkish color), 1 green (a grayish brown) and 1 red (it is red) they give you your colors for you picture. This is a simple fix.
Mar 23, 2008 | Zenith E44W46LCD 44" Rear Projection...
Yellow Haze Center Screen
Mar 19, 2008 | Zenith E44W46LCD 44" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
71 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
