Question about Acer Aspire RC500 PC Desktop
Will not Boot up
Can any one help. When my RC500 is switched on the monitor only display's the very first page you normally get (the one where you can enter setup) and just sits there and will not booy up.
Before this happened I would get a 'very interment' weird noise from the power supply fan.
any help would be appreciated, Many thanks, Paul (UK)
  • springcc May 23, 2008
    I got the same problem which display the very first boot up Windows logo and then display gone out but the system is still booting normally but with a black out screen.
Make sure the fan area is clean, no dust. If it's still making noise when you boot up, get a new fan installed on the tower.
Posted on May 09, 2008
Screen in two parts, just during boot
Don't worry about it. During boot time, the input to the monitor is set to a different resolution (640X480 for plain text). The monitor remembers settings for different resolution inputs, and the position is wrong but it's not a monitor problem as such. You could adjust the position and the display would be properly centered, but it's not worth the effort. Once the system starts Windows and the resolution switches to your normal settings, the display looks right. Once in Windows, you can't even set the resolution low enough to adjust the monitor; Windows won't go below 800X600 pixels.
Feb 06, 2011 | HP Pavilion F1703 17" LCD Monitor
Monitor says "Out of Range"
This normally happens when display resolution is changed to higher resolution and cannot be compatible/displayed by monitor. Either plug in another monitor and lower down resolution or Press F8 and go to advanced boot option and start your computer in safe mode and try changing display resolution. If it still doesn't works and you have the drivers for you display adapter (video card) then uninstall display adapter from device manager by booting in safe mode. Once you get to normal boot mode reinstall drivers for display adapter.
Jun 05, 2010 | Sceptre X20g-Naga III 20.1" LCD Monitor
I have this monitor hooked to my PC ATI 7500 graphics card with a DVI cable. When the PC initially boots up, the monitor display is blank - it does not display the boot-up messages until the MS Windows...
This is normal. Your monitor has a VGA hook in for regular definition. What it is doing, the monitor always by default looks for the VGA hook first. On my desktop it does the same thing until it finds a signal on the DVI.
Dec 29, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
Not booting
if this is a wireless computer,check the wireless installation again.
Jun 08, 2009 | Acer Aspire RC500 PC Desktop
Input not support, Acer V193w
if the monitor is DVI conencted to PCI card, the computer will not see the monitor, on boot up, only in the Windows mode.
replace the DVI connecting with a VGA connection on the monitor, if there is no VGA connection on the monitor then you need to get a VGA monitor and connect that to theVGA port on the motherboard connector at the rear of the computer.
Apr 28, 2009 | Acer V193w LCD Monitor
My LCD shows display in safe mode but no display in Normal boot.!
Its the problem with your display resolution. In Safe mode set it to 1280x800 and restart..
Apr 19, 2009 | Samsung SyncMaster 152 B 15" LCD Monitor
Analog- out of range
boot PC into safe mode, (pressing f8 on startup) then go to display settings and switch resolution to 640x480 (basic setting)
then reboot into normal mode, and then go to display settings and then choose an appropriate display resolution
this is caused when you replace a monitor as the old monitor ma have had different capabilities from the new
Feb 25, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
The monitor on my laptop has been broken for a while so i'm using an external monitor, now all of a sudden when the laptop gets to the loggin screen it switches to the native (broken) laptop monitor and...
open the device mgr. and disable the internal and set the external as default windows should set it as default automatically when disabling the internal
Dec 21, 2008 | Computers & Internet
No Display - Screen says "NOT SUPPORTED"
Turn your computer on.
When the boot screen cahnges to black start pressing F8
You should get a Windows startup screen
If you see the Windows Logo loading page, then hit the reset button and tray again.
On the Windows Start page, select Safe mode.
Press enter twice and Windows will load
Go into display properties (right click on the desktop and you will see it on the menu)
A box will pop up, select the last tab (Display Properties) there will be a slider on the left side. Move it left to around 800x600.
Select apply and then close the window.
Restart Windows normally and it should be fine.
If not, post back and we will try something else.
Hope it helps =)
Apr 12, 2008 | Computers & Internet
Blank screen
hai pls reconnect the hard disk cables and power cables properly and try again it will work
Oct 05, 2007 | Acer Aspire RC500 PC Desktop
Acer Aspire RC500 PC Desktop Logo
83 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
