Question about Cycling
Centric safe haven front mounted bike seat instructions problem: The problem is i do not have the instructions. I was given this as a hand me down. Could you please forward the instruction manual?
  • deadcandance Jun 19, 2018
    Still no one has helped you i see. i have the same issue. I cannot find a manual for this seat. I am missing parts but cannot see what parts I need.
    Top Expert:
  • 15,442 Answers
Notify manufacturer or online search
Posted on Jun 19, 2018
dunnbiker
  • 8546 Answers
SOURCE: My husband bought me a
Get on a search engine "how to shift gears" for video instruction
Posted on Jul 10, 2011
Testimonial: "Thanks - I checked youtube and found some videos that were helpful - should have thought of that but appreciate the help. "
SOURCE: have lost instruction manual
I need the manual of samsung D900
Posted on Sep 23, 2008
  • 1214 Answers
SOURCE: instruction manual needed for breville rice cooker- rc18
It looks like manuals are avaiable for free at
http://www.breville.com.au/products_results.asp?div=1&cat=6&subcat=38
You will need to enter your contact info.
Reply back if you have any further questions.
Posted on Feb 05, 2009
SOURCE: cant fit nania first car seat
We just fitted our 'new' secondhand narnia yesterday with instructions and it was a bit of a fiddle, but once in was very secure. Place the lap/diagonal belt through the slot in the back so that it comes out the front, it then goes over the arm rest, back through the other slot, across the back of the seat, then through the slots in the other side over the arm rest again and click it in.
Posted on May 17, 2009
SOURCE: Instructions on how to instal a second hand safe-n-sound car seat
how do i put the straps back on through the cover
Posted on Aug 03, 2009
Can you buy the bar onto which you fix a centric safe haven bike seat to? we have the seat but not the bar.
if you are talking about the plastic piece,its cheaper to buy the whole thing,otherwise,it clips to your seat bar,see pic,
CENTRIC SAFE HAVEN FRONT CHILDS BIKE SEAT
Apr 11, 2015 | Motorcycles
Tip
Bike sizing tip
Your bike must fit properly to be safe and comfortable. In the case of road bikes, most people will agree that you should be able to stand over the middle of the toptube on a man's style frame, with your feet about twelve inches apart, and be able to lift the front wheel one or two inches. For bikes that will be used for off-road riding, you should be able to lift the front wheel 4 or 5 inches. The reasoning is not that you may hurt yourself by hitting the toptube in an accident, but that while you are trying to prevent an accident, you may have to put a foot down here and there. You should not have to be concerned about hitting the toptube, so you can focus on the problem at hand. Getting a bike that's too small means the handlebar may be too low relative to the seat for good comfort and control.
on Dec 21, 2010 | Cycling
How much can I lower a 2013 street glide?
Anything much lower than an inch and a half, the ride quality suffers bad! Put a lowering kit in the front forks and use shorter shocks in the rear. DO NOT install any type of aftermarket kit that moves the rear shock mount rearward. If the bike still isn't low enough, check into purchasing a thinner seat. Good luck!
Oct 18, 2012 | Harley Davidson FLHX Street Glide...
How to change front power seat track worm in 1993 landcruiser
Lift the front edge of the seat bottom by using the regular power seat switch. Take voltage readings of the seat slide motor.2 Verify that the voltage to the seat slide motor on the harness side between "BR" and "W/B" is 12v when the power seat's switch is pressed backwards and forwards. Jot down your radio presets and tap the seat slide motor so that the motor will work long enough to give you access to the seat mounting bolts.3 Pull the seat as forward as it will go. Take off the two M10 rear seat mounting bolts and set them aside. Push the seat as far back as it will go. Take off the two M10 front seat mounting bolts. Switch the ignition so that it marks "OFF." Unplug the negative battery cable. Stand by for 4 minutes. Raise the seat assembly to find the harness-to-seat connectors. Disconnect them.4 Take out the entire seat assembly and place it on a dry, clean, flat surface. Position it so you can access the bottom of the seat. Undo the seat bottom's carpet flap and take out the four M8 bolts. Then, take out the top screws from the right hand and left hand side finishers. Unplug the seat sub-harness connector.5 Put both the seat rails back into their rear position and take out the worm gears, motor, flexible wire and gear boxes all at the same time. Take out the flexible wire from the gear boxes using a screwdriver. Verify that the new seat track mounting tab makes contact with the rear stopper and that the threaded shaft facing up is point upwards. 6 Install six new rubber grommets. Place the new worm gears, flexible wire and gear boxes into the frame. Reposition the seat tracks over the seat track mounting tabs. Use your hand to tighten the M6 bolts securing the seat track mounting tabs. Torque the six base plate nuts securing the gear boxes to 64 to 85 inch pounds (7.17 to 9.69 Nm) and the M8 bolts on the seat's front edge to 13 to 17 foot pounds (17.5 to 23.7 Nm).7 Plug the slide motor connector back in and hook the carpet flap's strap. Reinstall the seat assembly and reconnect the electrical connectors and negative battery cable. Torque the mounting bolts to 27 to 36 foot pounds (37 to 49 Nm). Operate the seat to make sure that the problem has been resolved
Sep 29, 2011 | 1993 Toyota Land Cruiser
The oil filter has dropped down, the shifter are in front is down below the foot rest, and the whole thing vibrates excessive when there is not gas given to it. We believer the motor mounts have broken or...
No it's not difficult to replace the engine mounts. You need a way to stand the bike upright and keep it safely in that position. Also a small jack with which to raise and hold the engine into position on the frame while you replace the mount. Not really that difficult.
Good Luck
Steve
Sep 04, 2011 | Harley Davidson FLTR-FLTRI Road Glide...
I bought a used older model It is a huffy aerocruiser bicycle trailer. has no instructions on how to assemble them onto your existing bike.where does it get attached to and what hardware do you newed to...
While I am no expert, I have a huffy aerocruiser. I also purchase mine second hand, but the woman who sold it to me was excellent on giving instructions at pick-up time! There should have been a peice that fits over the stem of your bike seat and and arm type thing that runs from bike seat piece to the stroller itself. There should also be two clips, a wheel, and a handle. To assemble for bike use, remove your bike seat and place the bike seat adapter piece on the stem of the bike seat then replace bike seat. Use one clip to attach arm to bike seat adapter thing. Use the other clip to attach the arm to the stroller (where the front wheel would go, wheel removed). The bike seat adapter thing remains on the stem of your seat and you just remove the clip that holds the arm to the bike seat when not using the trailer.
To use for jogging, remove the arm and replace the wheel. Slide handle into place and use two clips to hold handle on.
If this requires clarification, please let me know! I may not have made it that clear. I would be happy to take some pictures if it would help!
Best of luck and enjoy your new stroller!
Aug 29, 2010 | Huffy Cycling
Can't get my seat off of my 2002 Harley Fatboy in order to change a fuse underneath so I can get it started.
To remove the seat on a 2002 Fatboy:
1. Unbuckle the ******** the seat by pushing the metal part of the strap down from the left hand side of the seat.
2. There are two bolts located underneath the seat on the sides one on the left and another on the right which you have to unscrew.
3. There is another bolt located behind the passenger seat that you have to unscrew lift the seat up and that should do it.
PS When reinstalling the seat watch out for the bolt on the passenger seat not to scratch the tail of your bike.
Mar 07, 2010 | 2002 Harley Davidson FLSTF - FLSTFI Fat...
1100 yamaha 2003 vstar classic gas tank remove
1) Make sure your fuel petcock is closed, then detach the gas line coming off it (left underside of tank)
2) Remove the back seat (single acorn nut on rear fender)
3) Remove the front seat (two allen bolts at the back of seat)
4) There are two metric 12mm bolts under the front seat that hold the tank down. Remove them. The tank should be sitting loose on bike, but connected by some wires
5) Disconnect the white wiring harness under the bike. Tank is now totally free to remove.
6) Pull tank up and back at the same time, it will slide off the two rubber mounts at the front.
Jan 28, 2010 | 2003 Yamaha V Star 1100 Classic
Oct 19, 2008 | Baby Gear
Cycling Logo
1,094 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
