Question about Toshiba Tecra A8-S8314 Notebook
Hello, I have Toshiba Tecra A8 My problem is that when I start my computer the screen is on just for a second and after that it turns black. The computer is working perfectly and to see what is going on, I'm swiching the screen on my TV where the image is normal but the computer screen stays black. Even if I'm playing to shut down and/or restart the problem remains. I tryed to remove the battery thinking that it could be a reason because it's old, I swiched the contacts of electricity but I have the same problem. Could you please help where to look and what could I do to fix that problem? Is the screen or the software problem? Thank you for the help!!!
  • Toshiba Expert
  • 276 Answers
The problem is your lcd screen or invert er board. therefor plug the lcd and test the screen and invert er
Posted on Sep 23, 2017
SOURCE: toshiba TECRA A8 won't turn on
if you plugin the charger and the light in the charger remains that is does not flicker but when you plug it to the laptop it flickers the you have a problem with your motherboard. easily solved with a solder iron and the know how. but if you a novice take it to a prof.
Posted on Apr 13, 2008
SOURCE: Cant get the password of Tecra A8
Clear it with the 'clear cmos jumper'.
Posted on Jul 29, 2008
SOURCE: Bios Password
Deer GeekMan,
thanks for your solution. it seems usfule but my notebook didn't has printer port(paralel port).
it just have usb,and s400 port(smale port for usb printer)
Posted on Feb 02, 2009
  • 43 Answers
SOURCE: How Can I Remove Bios
Enter bios. Go to user setup. Type the password.And that`s it
Posted on Mar 16, 2009
  • 942 Answers
SOURCE: I have a Toshiba Tecra A8 and it will not boot up
This is an Hardware Failures: Doesn't Boot Up.
First of all, most of the hardware failures that are going to be presented in this article require you to disassemble the laptop and work on its internal components. Because of this, you need the required components to take the laptop apart (such as screwdrivers, etc.) and space, lots of space. If you don't have a workbench, then working on that large table in the living room should do it.
Second of all, you need to be extra careful about ESD (electrostatic discharge). Sure, this is important when working with a desktop system too, but you really shouldn't consider this as some sort of overreaction or waste of time. A few anti-static conductive bags should suffice. These are going to be useful when you take apart components from the laptop and you need a safe place to put them down.
Now let's begin. If the laptop does not power on using the batteries, then try to power it using the AC adapter. Pay attention and see whether the LED on the laptop lights up, signaling that the adapter was detected. If yes, then your power jack works. If the notebook still does not power on, disassemble the laptop and remove the batteries. Look first for the CMOS battery and take it out.
If your particular laptop model has more than one battery, like a multi-port battery or a handle battery, then take those out too. This should serve as a master reset. Try powering on using the AC adapter. If it still does not power on, then read on.
Your best bet is that the problem is memory-related. What you need to do is re-seat the memory modules. If there are more than one, then try swapping them between each other and try different slots. Try booting again. If it does not work, then try running with only one module - this way, you can tell whether one is faulty.
Narrow down the problem by removing each "unnecessary" component. Disassemble the laptop and remove the HDD, CD/DVD drives, and the modem and/or wireless card(s). If possible, take out the sound card module (if separate). To minimize the possible causes, you may disconnect the LCD panel as well. Try running this way. If it does boot, then try connecting each connector one at a time, booting up in between to localize the problem.
On the other hand, if you have stripped it down to a bare-bone laptop and it still refuses to POST, then chances are your motherboard might be the root of the problem. Another option is temporarily replacing the memory modules with good ones. This way, you can eliminate that from the list of possible causes. This leaves the motherboard and CPU. Take apart everything; re-seat both the CPU and motherboard. Try again.
As a last resort, if you are familiar with using a multimeter, then try checking the power button and see whether it actually "switches" or not. You may also monitor the voltages during the VRM circuitry (whether or not it gets power). Verify the resistances between the common places (such as verifying whether the motherboard is grounded or not - you know, those metallic rings near the screw holes).
Nevertheless, if you still can't diagnose the problem and the laptop gives absolutely no sign of life, then take it to a repair center. But chances are that you have found it by now, at least let's hope so. Now let's talk about other problem scenarios.
If your notebook always "forgets" the system clock, then it is almost always a faulty CMOS battery. Disassemble the laptop, locate the battery, measure it with a multimeter or voltmeter, and, if need be, get a replacement. If your laptop powers on but beeps like there's no tomorrow, then those "beeps" stand for an error code. Find out which BIOS your notebook has (perhaps it's not AMI, Award, or Phoenix). Then do a quick Google search to find out what those beep codes stand for on that particular BIOS version. More often than not, it indicates a memory-related problem. As I suggested earlier, try re-seating and playing around with the modules.
Good luck!Thanks for using fixya.
Posted on Aug 28, 2009
ACPI Flash BIOS version 3.20 for Tecra A8 (PTA82) Posted Date: 2016-09-19 ' Version: 3.20 ' Size: 3.82M ACPI Flash BIOS version 3.30 for Tecra A8 (PTA82) Posted Date: 2016-08-24 ' Version: 3.30 ' Size: 3.82M ACPI Flash BIOS version 1.40 for Tecra A8 (PTA82U) Posted Date: 2016-08-24 ' Version: 1.40 ' Size: 3.54M ACPI Flash BIOS version 1.60 for Tecra A8 (PTA82) Posted Date: 2016-08-24 ' Version: 1.60 ' Size: 3.52M ACPI Flash BIOS version 1.50 for Tecra A8 (PTA82) Posted Date: 2016-08-24 ' Version: 1.50 ' Size: 3.54M ACPI Flash BIOS version 1.30 for Tecra A8 (PTA82) Posted Date: 2016-08-24 ' Version: 1.30 ' Size: 3.54M
Apr 02, 2014 | Toshiba Tecra A8-EZ8311 Notebook
Enter bios toshiba tecra a8
when powering the computer up hold the F8 or esc key
Jan 28, 2014 | Toshiba Tecra A8-EZ8312 PC Notebook
I need original windows for Toshiba tecra a8 model
You would need to purchase that from Microsoft or a reputable software vendor in your area.
You may also want to get a free upgrade from their site provided you had an original before hand.
Do this and your Toshiba Tecra a8 will thank you for it!
Take care.
Aug 03, 2011 | Toshiba Tecra A8-EZ8412 (PTA83U-03J02C) PC...
Remove password toshiba tecra a8 pta83e
open the back of the computer , remove plastic cover , there you will find a battery, Lithium (size of a quarter), discoonect the connection for 30 seconds , place it back
if no connection present, remove the battery (carefully) and place it back after 30 seconds
Oct 16, 2010 | Toshiba Tecra A8-EZ8313 Notebook
Trouble install soundcard di toshiba tecra
You need to goto the manufacturers website, find their support section and there should be a list of drivers for your specific machine. Installing these should resolve your problem. I have a list of links to most manufacturers drivers on my website.
Hope this helps,
Jun 08, 2010 | Toshiba Tecra A8-EZ8313 Notebook
Replace screen on oshiba Tecra A8 laptop
Check the following link you need proper tools,
Best of Luck
If you require further assistance please free to ask me.
Mar 25, 2010 | Toshiba Tecra A8-EZ8313 Notebook
Hi there i have a toshiba tecra a8 want to reformat it don't know how to do it.I believe it is built in
You need to have a working CD/DVD Installer of your OS like Windows Vista or Windows XP or the like.
Now, you need to start your laptop while the disc installer is in your CD/DVD Drive. Then it will automatically boot from the CD/DVD drive to start the installation. Just follow the on-screen procedures.
Feb 04, 2010 | Toshiba Tecra A8-EZ8311 Notebook
Looking for drivers for toshiba model tecra A8
Go to the toshiba web site
Click Support >Mobile Computing>Drivers and downloads
You will be directed to the page Drivers and Downloads by Model.
On the left box Choose Notebook, then select Tecra, then Tecra A8.
In the last box you have to select the specific version of the Tecra A8.
Once you do that, you will end up on the page where all software for the model is listed. You can then download what you need.
Best of luck,
Hope it helps.
Aug 19, 2009 | Computers & Internet
Toshiba TECRA A8 won't turn on
Apr 13, 2008 | Toshiba Tecra A7-S712 Notebook
Toshiba Tecra A8-S8314 Notebook Logo
229 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
