Question about HP Photosmart C6180 All-In-One InkJet Printer
I finally had to unplug the printer because it constantly cycles through the startup process and then restarts and does it all over again. I never received any error message. I just see the progress bar and this is shuts off and restarts. Unplugging it doesnt help.
I had this same problem with my C6180. The printer was well out of warranty so I decided to tear into it. I removed the three black torx screws covering the mother board. I then removed the screws holding the mother board to the chassis and found a swollen 330 uf 10V capacitor. I replaced the capacitor at a cost of $1.70 and everythng now works fine.
Posted on Oct 14, 2010
Maintenance steps to resolve continuous cycling at startup
Dear
Its standard procedure to do the routine clean the head (nozzles) of the ink cart. at the time of start(power on or from sleep mode).
Thanks.
Feb 04, 2015 | HP Officejet Pro 8500a Plus All-in-one...
After unplugging the refrigerator it takes too much time for the compressor to start. The last time it took around 20 hours for the compressor to start running again. I want to know if the overload...
Typically after unplugging / replugging a refrigerator they will start running again within a few minutes. Have you checked the defrost timer? This will essentially interrupt the cooling cycle to provide time for the defrosting process. A faulty timer may be delaying the startup to after the next defrost cycle. Hope this helps..
Oct 28, 2013 | Refrigerators
Power problem
This may or may not be of any help, but I had a Sony system that had a malfunctioning remote control and it would cycle power constantly. You might try pulling the batteries and see if it changes.
Nov 27, 2011 | Audio Players & Recorders
The icon for the HP 6500 keeps getting deleted from my WIN7 Home Premium 64bit's "Devices and Printers" folder. I have to constantly go through the installation process all over again.
unlock deepfreeze then restart computer , when finish boot , windows open , INSTALL HP DRIVER , when finish lock deepfreeze to protect your PC then restart again.
Jul 11, 2011 | HP Officejet 6500 Wireless All-in-One...
The red lights on the ink and the paper keep flashing back and forth and the printer will not work. I finally got an "internal error"?? is there anything I can do without taking it in to be...
Here's what you need to do. Reset the printer by pressing and holding the power button 5-10 seconds. It should turn off. Unplug it from the power outlet and from the computer. Do a power cycle by pressing the power button for 5 seconds (connections should still be disconnected during this process). Plug it back in to the power source and the computer. Turn it on.
Restart the computer. After restarting, test print. It should work. I have tried it a lot of times.
Mar 22, 2011 | Office Equipment & Supplies
My HP PhotoSmart C6150 printer keeps restarting.
I had this same problem with my C6180. Printer was well out of warranty so I removed the three black torx screws holding cover over mother board. I then removed screws holding mother board to chassis and found a 330 uf 10V capicator that was swelling. I replaced the capicator at a cost of $1.70 and everything works fine now. Better than buying a new printer.
Oct 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
Keeps restarting
I do not know about the screeching part, that could be part of the problem or completely independent of the problem. When my machine kept repeating the "startup" process, it was because my bulbs went out. The printer then would never get warm enough to melt the ink to begin printing, so it would just keep restarting, and restarting the warming up process. One way to tell is to take off the side cover. Then peer into the side and see if you see a bright light - which would be your bulbs. I have no idea though what to tell you about the screeching thing.
Jun 03, 2009 | Xerox Phaser 8200 Laser Printer
Can't load the software on my new laptop for my hp printer
Removing the software and reinstalling it using a "clean boot" may resolve the symptoms you are experiencing. Booting clean is a way to eliminate programs from conflicting with installation of software.
1. Open the Windows Control Panel.
2. Open the Add / Remove Programs window.
3. Locate the listing for the software and remove it. When prompted to remove the printer drivers files, click Yes.
Now download the latest version of the software for your OS from the manufacturer's website.
The following is the procedure for a 'clean boot'. I am assuming that you have XP.
1. Click Start --> Run --> Type MSCONFIG --> Click OK
2. On the General tab, choose Selective Startup
3. Uncheck Process SYSTEM.INI file
4. Uncheck Process WIN.INI file
5. Uncheck Load Startup Items
6. Click on the Services tab
7. At the bottom, check Hide All Microsoft Services
8. Uncheck all boxes in the window or click the button labeled Disable All
6. Click OK
7. Click Restart
After restarting, install the downloaded software. Next, do the following:
1. Click Start --> Run --> Type MSCONFIG--> Click OK
2. Replace checkmarks in the items that you previously removed them from.
3. On the General tab, choose Normal Startup
4. Click OK
5. Click YES, when asked to restart your computer
Hope that helps...Should you have any further questions, please feel free to post them here.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 08, 2008 | HP Office Equipment & Supplies
Dell 1600n Display panel freezes soon after power up
it is definately a problem with the startup cycle circut but will need testing to determine the exact cause , it old enough that they may have stopped making parts for it though
Oct 08, 2008 | Dell 1600n All-In-One Laser Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
176 people viewed this question
Seeker5211
Seeker5211
