Question about Kenmore Dishwashers
I have a kenmore dishwasher about 5 years old seems to be leakig from the bottom hose a conection look fine wasnt spaying out just a heavy leak
  • Kenmore Master
  • 43,501 Answers
It is not uncommon for the connection at the end where ti swivels to screw fast to leak after five years...
That hose is just a normal washing machine hose...get a new one and replace it...
heatman101
Posted on Aug 31, 2010
Model 665.13929kq11. Why isn't it draining completely?
Dishwasher is draining slowly , and not completely ... - iFixit
https://www.ifixit.com/.../Dishwasher+is+draining+slowly+,+and+no...
iFixitJun 26, 2014 - I have a kenmore dishwasher (about three years old) ! ... with a solid plug in the drain tube for situations where a dishwasher isn't connected.
My Kenmore Dishwasher Won't Drain and is Leaking- How ...
? 5:35
https://www.youtube.com/watch?v=u7uaA2NZKl0
Nov 14, 2011 - Uploaded by mkbrennan13
This is a video to help someone fix their dishwasher. It's a How to fix your dishwasher that won't drain. If your dishwasher isn't draining and ...
How to fix drain problem with kenmore dish washer - YouTube
? 6:46
https://www.youtube.com/watch?v=ZMPXn6XgRkk
Aug 16, 2010 - Uploaded by itdatanow
Kenmore dishwasher would not drain. ... How to fix drainproblem with kenmore dish washer ... Is Your Dishwasher DrainInstalled Properly?
Dec 12, 2015 | Kenmore Dishwashers
It appears that the Inlet Valve is leaking on my Kenmore dishwasher. By replacing the inlet valve do I also need to undo the connection at the bottom with the teflon tape - or can I just undo the screws at...
Probably just hard water causing the solenoid to stay slightly open. Shut off water Remove 1/4 hose Remove wire harness/plug Remove other side hose should be a clamp. Unscrew mounting bracket and replace in the same order.
Hope that helps
May 11, 2011 | Dishwashers
Kenmore UltraWash Dishwasher is leaking from black hose...
No you will have disconnect the copper line. I would suggest that while you have it out that you replace the copper line with a braided stainless steel hose (also known as a dishwasher connector hose) If possible get a 60" or 72" hose so you can hook up the dishwasher when it is out and then push it back in with the water supply already hooked up.
Jul 31, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Elite Drawer Dishwasher leaking
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
ppi
Jun 29, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Dishwasher tub leaks underneath
Hello. Anything is worth trying! But I would recommend epoxy. It works alot better with plastic and rubber items. Most of the leaks I have found in Kenmore machines are at the water pump. You may want to take a peek while it's running, just stay away from the wires!! Thanks!
Jan 17, 2009 | Kenmore 15899 Built-in Dishwasher
Technika Diswasher
Hi ,I have a leaking problem with aTechnikaTDX20W and have discovered from service that it is the spray arm which has cracked along the seam edge . This then spays the door seals and they leak. unfortunately the part is out of stock which seems to be a problem with Technika. If anyone can help with a new spay arm I would appreciate it. I have tried te glue it however didnt work. The dishwasher is only three years old and I am considering buying an Australian made one to ensure parts. Worth a check of yours. Regards,Brian.
May 05, 2008 | Hotpoint 24 in. DF55 Free-standing...
Soap door won't open
The rinse aid compartment on my Kenmore Portable dishwasher ( Model 17829) leaks and doesn't hold the solution. It seems to have done this for longer then I can remember. What can be the problem?
Sep 21, 2006 | Kenmore 17252 Free-standing Dishwasher
Dishwashers Logo
51 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
