Question about Dell 3000cn Color Laser Printer
Printer Problems I was wondering if anybody could help me. My printer is printing a straight thin line an inch left of center on every page. I have used the cleaning tool on the side of the printer but the line will not go away. Is there something else I should try. Thanks!
  • DP1986 May 09, 2008
    What's an Optical path? And how do I get there?
What's an optical path?
Posted on May 09, 2008
  • Dell Master
  • 5,568 Answers
From experience with similar machines, it sound very much like either contaminents in the optical path or a scored drum.
HP 2840 printing two thin black lines from top to the bottom of the center of the page is that a fuser kit problem?
It could be a fuser problem.
Put paper in the manual feed tray. Print a few pages. As the paper gets
1/2 way into the printer, open the cover. Look down at the paper in the printer.
If it has 2 thin black lines, the toner cartridge needs to be replaced. If there are no lines the fuser is probably bad.
Jul 22, 2011 | HP LaserJet 2840 All-In-One Printer
I'm getting a straight line of no text or image running from the top of the page down to the bottom of the page. The print started getting fainter and fainter until there was no print at all in a 1/8 to...
Please run a printer alignment exercise. Then do a print head cleaning exercise. If these does not solve the problem then try to reset you printer. Clear the printer memory. Please follow the user manual to perform the steps.
Dec 21, 2010 | OKI C5100 Laser Printer
HP Laserjet M1319fMFP Copies have a line down the
if it only happens when COPYING AND NOT PRINTING there is a long thin glass that "reads" your originals inside the document feeder. It probably has whiteout on it. clean it with your fingernail. this glass is about 10 inches left to right and 3/4 inch long. Your manual should point this glass out to you.
Dec 14, 2010 | HP Laserjet M1319F Laser Multifunction...
My Ricoh Aficio CL2000N is printing several faint lines
Couple possibilities:
Fuser hot belt has wear lines transfering to the page
Black pcu needs to be replaced
Transfer unit is not being cleaned properly and needs to be replaced.
Remove each of these assy and inspect them for wear or lines that corespond to the lines on your prints.
Mar 25, 2010 | Ricoh Aficio CL2000N Laser Printer
Canon MX700 printer - vertical lines aren't straight
Have you tried to do an alignment. Also check encoder strip
Aug 19, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Printing lines not straight and letters shadowed. Help!
Open the cover over the print head and *carefully* inspect the clear thin plastic strip that runs from left to right near the print head. If you see any lubricant (white grease) on this encoder strip, it needs to be cleaned off.
1. With the cover open and the print head in the center, unplug the power cord. This will allow you to gently move the print head left or right.
2. With a cotton swab wetted with rubbing alcohol, *gently* wipe the grease spots from the encoder strip. (Be VERY CAREFUL you don't dislodge the strip.) You may need to move the print head to the left or right to get all areas cleaned.
3. Let the alcohol dry off completely. With the area clear of cleaning tools, debris, and fingers, plug the power back in.
4. Try a test print.
Jun 17, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Black vertical line (1 inch wide) appears while scanning/copying
For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
Hope this help
Byron
Jun 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Black stripe down middle of page when copying
open the top cover on the left hand side glass plateform with a narrow piece glass clean it with alcohol.
Dec 13, 2008 | Brother MFC-7820N Printer
Scanning document leaves streak down right hand side
hmm this has happened before
make sure it is sitting straight and cleaning it might help
Jan 07, 2008 | HP PSC 1315xi All-in-One Printer
Dell 3000cn Color Laser Printer Logo
44 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
