Question about Fisher and Paykel Washing Machines
When I press the Power button the washing machine beeps and won't let me select an option, two lights are lit up and the spin light, when I press start, it won't start but the lid lock light lights up.
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now to accurately diagnose the problem in your machine I need the model number of the machine,Also when the machine is beeping you mentioned in your posting 3 lights lit up.Starting from the left to right which lights are lit when the machine is beeping,Is it the 2nd,3rd and 8th or the 1st, 4th,and 8th,---etc---?Please reply with this information and I am sure I can help you further.
Posted on Sep 01, 2010
  • Phillip Wratt
    Phillip Wratt Feb 21, 2014
    I have the same problem. The lights are 2nd and 3rd and 8th. when I press start they go out and the lid lock light goes on though the lid is not locked.
Won't spin gw608u
Fault code 41 if those are the correct lights. Service manual says faulty temperature thermistor & change the control module. Good luck with that as that model is nearly 20 years old and I don't think F&P supply that module any more.
May 02, 2017 | Fisher and Paykel GWL11 Top Load Washer
Will not spin only adgorates gw608u
Hi just read your post.Now your post has indicated the lights that are on while it is beeping are from LEFT to RIGHT are 3, 5, and 8.Is this correct.Please reply back if this is correct and it should not be hard to rectify Looking forward to your post,Lu
Jan 24, 2014 | Fisher and Paykel GWL11 Top Load Washer
Won't spin gw608u
You need to call a repair person. Or if the washer is still on warranty trade it in. This sounds like a problem from the factory
My fisher and paykel top loading q washing machine won't start. It beeps and lights 5 and 8 come on. Any ideas what the issue might be?
That is fault code 9 machine not sized
9. (00001000) Size Switch Error
The Display size switch setting does not match that which is stored in memory.
Action GW Machines: Reselect the size of the machine by using the SIZE SETTING
MODE.
To set the size switch, turn the power on at the power point and off at
the console. Press and hold Wash Temperature Setting Up then
press Power. SmartDrive will give 4 short beeps and the pattern of
LEDs will change.
One of the following buttons needs to be pushed to lock the size into
memory.
• Press Wash Temperature Setting Up, the Cold LED is on for 5.5kg
(560mm wide).
• Press Water Level Up, the Low Water LED is on for 6.5kg / 7.0kg
(600mm wide).
517790C
35
• Press Spin Speed Up, the Spin Hold LED is on for 7.5 / 8.0kg
(650mm wide).
• Press Power to confirm the setting and also exit this mode.
Action IW Machines: To access Size Setting Mode, push and hold the Fabric Care button
and then press the Power button to enter Size Setting mode. Select
the correct size on the display by pushing the Adjust button to
highlight the correct size. Size setting is then achieved by pressing
the Power button. Powering off will set the size into the memory.
Note: Fault code 9 will only be logged into the memory of IW machines. GW and MW
machines can display this fault but it will not be recorded.
Aug 13, 2012 | Fisher and Paykel Washing Machines
GWL Washer won't spin only beeps; Diagnostic lighs:the third light is lit up green in the bank of lights on the left; the first light on the right is lit up orange and the third is lit up red. Thanks,...
GWL Washer won't spin only beeps; Diagnostic lighs:the third light is lit up green in the bank of lights on the left; the first light on the right is lit up orange and the third is lit up red. Thanks,Hepi
Jul 24, 2011 | Fisher and Paykel GWL11 Top Load Washer
Hello, Re: frontloading washer Model C45172 Our washer has been operating withiout hitch since purchase about five years ago, We love it. Today I tried to program it to do an extra rinse after wash...
For the Elite (HE) machines:
Press 'STOP' twice, press 'POWER', choose a wash cycle (such as 'NORMAL'), select wash options (water temp), press 'START' to finish the reset sequence.
Other Kemore electronic washers:
Unplug the machine for a minute, plug it in. Press 'PAUSE/CANCEL' twice.
Good luck from Detroit, MI.
Jun 12, 2011 | Kenmore Washing Machines
We have a Fisher and Paykel toploader, smart drive 603. After setting up a washing cycle and pushing the start button, the machine starts for a few seconds with the water filling in in short bursts (rather...
Hi just read you posting.Could you please confirm the fault code for me.1st push and hold the WASH TEMPERATURE DOWN button then press the POWER button until the machine gives you 2 short beeps,then release both buttons.Now press the SPIN UP or DOWN button until the HOLD and SLOW SPIN LEDs are both on.Now the fault code will appear in the WASH PROGRESS lights.Please reply to confirm which lights are lit.Are they the same as your 1st posting?To get back to normal operation turn machine off at the power point.Looking forward to your reply.
Jul 05, 2010 | Fisher and Paykel GWL11 Top Load Washer
The 3 buttons
button selection : To select an option press the button and you will see a light come on above the button. Press again to cancel and the light will go out. You cannot alter the options once the machine is running. Note : remember to cancel buttons after use!
As you look at the machine
Left hand button... Rinse Hold.. use this option to Help reduce creasing of delicate or synthetic fabrics by holding clothes in the final rinse water. The rinse hold light will flash to indicate that the programme is holding final rinse water. Complete the final spin by pressing the Rinse Hold button when light is flashing.
This is not available with Wool or Spin only programmes.
Middle Button.... Energy Save... use this option to save money and time on lightly soiled loads. This is not available with the Quick Wash, Rinse and Spin, or Spin Only programmes.
Right Hand Button .... Super Rinse... use this option for Large Wash loads and items for young children or people with sensitive skin. This option increases the water level for the first two rinses. This is not available with Cold Wash, Rinse and Spin or Spin Only programmes.
Copied from my Hotpoint FEW12 user instruction sheet.
Hope it helps.
Sue
Jul 31, 2008 | Hotpoint First Edition FEW12 Front Load...
Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Aug 26, 2007 | Tricity Bendix AW1400W Front Load Washer
Washing Machines Logo
211 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
