Question about Car Audio & Video
If the set had popped out from the connection then make sure that it is plugged on in the right slot. Now check the RED and the ORANGE to be having the positive voltage , one is continuous and the other switched on when the key switch is turned on. Check also the ground to the set. Now there is a small plug in fuse normally in the slot under the plug in wires. Just check this out.
Once you are confirmed of the power, check the front panel connection if there is any damage in the panel connecting the main unit. clean and make sure it fits correct.
Test this out. If there is no action, the set must be pulled out to check on the powerr circuit inside.
BUT make sure that the power is present as described in the firrst part, use a multimeter to check in DC range with the set as the ground.
Posted on Sep 01, 2010
Test the red cable. That is the cable that tells the radio to turn on, aka when you turn your key.the red cable is not getting power when key is in on position.
The color of cable may differ,but in most of the radio stereo units its red power cable for radio and black cable for ground.The radio is having power but its power cable is not receiving power when the key is turned on.Its getting cut off.Check the radio power wire and reconnect it.
That will help.Keep updated.Thanks.
Posted on Aug 31, 2010
Sep 08, 2014 | Pioneer Car Audio & Video
May 27, 2014 | Car Audio & Video
Apr 16, 2014 | Pioneer FH-X700BT
Jan 20, 2014 | Pioneer Car Audio & Video
Aug 28, 2013 | Pioneer Double-DIN Car Stereo With...
Jan 30, 2013 | Pioneer FH-X700BT Double-DIN Car Stereo...
Oct 21, 2012 | Pioneer FH-X700BT
Mar 26, 2011 | Car Audio & Video
Jan 16, 2010 | Sony CDX-F7710 Car Audio Stereo CD MP3...
May 10, 2009 | Car Audio & Video
57 people viewed this question
ok i will try that thanks i thought the wiring was all ok as i tested it but will look at again..thanks
