My fork are toyota lpg and have spark, gas but doesnt crank . if i turn off the gas they try to crank ,can do you have idea wich could be the problem
  • 1,498 Answers
If when the gas is on it tries to crank but doesn't seem to have enough power it could be either the timing is too far advanced or a low battery state.
Jump it first. Quickiest easiest and cheapest.
Remember: be safe. Those models had a tendency to pop into gear at the slightest nudge
Best regards
Mike
Posted on Sep 01, 2010
96 toyota camry. Replaced fuel pump, strainer and filter. Will crank if you spray starting fluid in it, but wont run. Any ideas?
Check for spark. Start at the coil, spark at the plug, Could be the coil or crank position sensor. Check codes.
Jun 28, 2016 | 1996 Toyota Camry
C200 Merc 2009 model, engine turns but car wont start, why
same for all engines. (no engine stated, so no exact answers)
is your gas or diesel (ill guess gas)?
gasoline and not LPG or other fuels. real gas ,nor flex fuels on E100
cranks but no starts.
blown fuses, check fuses first, ( always #1 with EFI)
bad gas.,
the first check is spark , gas dont burn lacking SPark (mr,otto cycle)
watch funny guy SCOTTY.
https://www.youtube.com/watch?v=064Ilsz8Fzg&NR=1&feature=fvwp
any engine can run on test fuel, if it has spark (Otto)
some engines will never start
  1. lost compreesion 1 or more cylinders
  2. melted CAT converter, blocking exhaust
  3. EgR stuck open, wide, if your unstated engine has one.
  4. fuel pressure zero or 10psi. dead. must be at spec.
Dec 18, 2014 | Cars & Trucks
Hi the other day i started the toyota up after finishing work it backfired now it wont run on lpg. It runs on petrol but wont on LPG any ideas would be great.
the fact that it runs on fuel means that the electronics of the vehicle are all operational. The problem is the fuel selection process for he LPG. The converter for the lpg is prone to corrosion and failures internally so I would suggest that you have an accredited Auito gas specialist look at the gas system
Dec 03, 2014 | 1992 Toyota 4Runner
2002 4runner wont start
You could see if spark plugs have spark if not ck crank sensor or you got a tank of bad gas.
Mar 05, 2014 | Toyota 4Runner Cars & Trucks
My 98' toyota rav4 acts as if it wonts to crank but want turn over,want crank up.it has gas,oil,etc.lights and windows work fine.What do you think is the problem or what should i check?
Mileage? Ever do timming belt ?wich should be done every 50,000 miles it's what keeps engine going synchronized.if it wasn't done you could have damaged ur engine good luck
Nov 01, 2013 | 2008 Toyota RAV4
Cranks well but won't start.
Looks like you got spark, and gas in the throttle body made it fire: nice work.
Sounds like your fuel pump is out or the wiring is not turning it on. One way to be sure is to set a spare battery near the tank and hot wire the pump with jumper wires. Or if you have a voltmeter check for voltage at the fuel pump connector while the truck is cranking.. If the pump is working and getting gas to the engine, see if the injectors are pulsing. A good idea to check fuel pressure if the pump is working.
Nov 17, 2012 | 1992 Toyota Pickup
I was driving my 94 toyota p/u & it just died like it stopped getting gas. i think something may have come loose.any idea on what to check?
Check your battery and alternator connections for tightness. Does it crank over, but won't start? If it won't even crank over, then likely some connection did come loose, like an alternator connection, possibly your fusible link (near the battery).
If it does crank, but won;t start: You'll just have to start from scratch to find the problem. Try to determine if it's fuel or ignition-related. Check for spark at a plug wire. If you have spark, then ignition is not the problem. Check if your fuel pump works. When you turn key on, you should hear the pump buzz on for a couple of seconds. It should also be on when cranking and running, but you can only hear it, or should, when you first turn key to on. If your toyota has a schrader valve on the fuel rail (a valve for checking pressure-it looks like a typical air valve, like on your tire, but is for attaching a fuel pressure gauge) if it has one punch the center with a little screwdriver-gas should shoot out if you have any fuel pressure, If not, have your fuel pressure checked.good luck.
Nov 01, 2011 | Cars & Trucks
My LPG regulator ices over and freezes in my Toyota Landcruiser dual fuel 4x4.
I would have it checked for a leak, when LPG leaks it will cause freezing of the valve. LPG under pressure gets extremely cold when it is released. I see this all the time around shut off valves on propane tanks. I am not a Toyota Mechanic so I can't say for sure, but it sounds like the regualtor has a small leak in it. Some fork trucks use these regulators and I have seen them freeze up just from being used as gas passes thru the regulator. does this freeze up when you are using LPG or does it freeze up all the time. If it is freezing while not being used, I would definatly have it checked for a leak.
Nov 15, 2010 | Toyota Land Cruiser Cars & Trucks
Toyota 3y engine fuel system
LPG 3Y engine toyota crown comfort automatic - fuel consupmtion is 13.30litre per 100km? How can this be reduced?
Jan 08, 2010 | 2002 Toyota Camry
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
