Question about Emerson Televison & Video
Require access # for remote Model ECR 2089 Serial# 5012A302-0603801 Please
  • sydsmail Sep 01, 2010
    Have already tried three different models and none of them worked.
  • Emerson Master
  • 17,129 Answers
My advice is to get a universal remote control which can be very weel used with use devvice . Thre are many models whihc confirm to this standard and if you can get one with a auto mode to scan and fix the frequency as you do a search, it will be very easy for you to set it up.
Please search around in your area/city for the electronic spare parts shops/the Tv dealers and choose a convinient model. Many such types are economical than the get the original which can cost you almost three times.
Also please sure when you purchase that in event of the remote not locking into the model, you may have to return it without damge so at that an alternative model is given to you.
Or if possible if these delears have a local delivery ask for one to be send through their repaiman as you will pay once the demo is done and set up in yourr TV. This will be the no hazzle deal.
Posted on Sep 01, 2010
  • Donald DCruz
    Donald DCruz Sep 01, 2010
    Was the emersonmodel specified on the catalogue. If so was the set up correct.?
    The other point did you try repairing your old one. Check for the crystal damage or the controller IC, change if available, there can be no other issues but to have the original back in action.
I need a manual for a Sanyo ECR 105
Go to Sanyo and give Model and possibly serial # and request manual and then copy.
Dec 31, 2014 | Computers & Internet
How do I repair Lithonia ECR M6 LED Emergency/Exit Light combo. No emerg lights when test button is depressed, no led lights from AC? just a flash when test switch is depressed? is it the small transf
Fixtures are covered by Lithonia Lighting 24-month warranty against mechanical defects in manufacture.
All life safety equipment, including emergency lighting for path of egress must be maintained, serviced, and
tested in accordance with all National Fire Protection Association (NFPA) and local codes. Failure to perform the
required maintenance, service, or testing could jeopardize the safety of occupants and will void all warranties.
Note: Specifiations subject to change without notice.
Actual performance may diffr as a result of end-user environment and application.
Standard
Catalog Supply Input Pallet Carton
Number UPC Description Voltage Wattage Qty. Qty.
ECR LED M6 784231874516 Red 120/277 3.8 108 6
ECG LED M6 784231874592 Green 120/277 3.2 108 6
ECR LED HO M6 784231874561 Red, high output 120/277 3.8 108 6
ECG LED HO M6 784231874615 Green, high output 120/277 3.2 108 6
Accessories: Order as separate catalog number.
ELA WG3 Wireguard (back mount only) 1
ELA LED M12 Single remote lamp2,3
ELA LED T M12 Double remote lamp2,3
ELA LED WP M12 Single, weather-proof remote lamp2,3
ELA LED T WP M12 Double, weather-proof remote lamp2,3
Notes
1 See spec sheet ELA-WG.
2 See spec sheet LED-Remote Lamps.
3 Only available with HO option.
11 5/8 "
7 3/16 "
1 5/8 "
Integrated Exit-Unit Combo
12-5/8"
(32.1)
8"
(20.3)
4-3/8"
(11.1)
5-3/8"
(13.7)
1-7/8"
(4.8)
LED Unit
LED Combo
LED Exit
15 (38.1)
3-3/4
(9.5)
5-3/8 (13.7)
12 (30.5)
3-3/4
(9.5)
2"
(5.2)
4-1/2"
(11.4)
9"
(22.9) 8"
(20.3)
20"
(50.8)
12"
(30.5)
All dimensions are inches (centimeters).
Shipping weight: 3.6 lbs. (1.6 kgs.).
ECR LE
Oct 27, 2014 | Lithonia ECR M6 Exit/Emergency Lighting...
Where do i find the manual for a GE um-4 ecr 03 universal remote?
    • try 1 (888) 348-7563 General Electric, Customer service if google fails.
Oct 07, 2014 | GE Televison & Video
Dark picture on monitor
Occasionally, you may find your laptop's monitor is too dim for your liking. A normal desktop computer's monitor has an on-board menu system that lets you adjust the brightness and picture control settings as you please. A laptop monitor has no such controls. You can adjust the brightness of your laptop monitor using your laptop's keyboard.
1. Press and hold the "FN" key on your laptop's keyboard. This is the "Function" key, which operates much the same way that the "Shift" key does: It allows keyboard buttons to be used for multiple purposes. It's located in the lower left corner of most laptop keyboards, next to the "Windows," "CTRL" and "ALT" keys.
2. Look at the top row of keys on your keyboard for a key with a tiny triangle pointing upwards and the symbol of a sun on it. This is the "Increase Brightness" key. With the "FN" key held down, press the "Increase Brightness" key. On most laptop keyboards this is the "F7" key, but it varies depending on the model.
3. Continue to hold down the "FN" and "Increase Brightness" key until your dim laptop monitor has reached the level of brightness you require. A laptop monitor can only get so bright. It will stop at its highest setting.
4. Release the "FN" and "Increase Brightness" keys. You have now fixed your dim laptop monitor.
I hope you find it very helpful. Thank you for using fixya
Aug 17, 2011 | Acer Aspire 5610-2089 Notebook PC (ACER...
I have a Warfedale tv (do not know the model) and the child lock is on and I do not have a remote. How can I unlock the tv without the remote?
Never heard of that brand!
You need to look at it real good- find the manufacturers label which will have the model and serial number. Copy the information and go to any good electronics store and find a universal remote for that set. Configure the remote and find the child lock menu and turn the lock off. If it requires a password and you do not have that either, you will have to perform a "reset to factory defaults" from the menu.
TV's will not usually allow access to the child lock controls without a remote.
Jan 28, 2011 | Televison & Video
I need the code for my tv 19 inch tv model number is 19tvd4s
The code is 1944 on a universal remote, but you will only be able to access basic functions, not the setup functions....you will need to find the original remote on ebay or something to get full access to the TV functions
Dec 14, 2008 | Televison & Video
Olivetti ecr 350 cash register problem starting up
There is an ECR350 manual here that might help:
All of these manuals can be downloaded at:
http://the-checkout-tech.com/
olivetti CMS-140B User Programming
olivetti ECR-2100 User
olivetti ECR-2150 User
olivetti ECR-2200 User
olivetti ECR-2250 User
olivetti ECR-2300 User Programming
olivetti ECR-2350 User Programming
olivetti ECR-2400 User Programming
olivetti ECR-2450 User Programming
olivetti ECR-2500 User Programming
olivetti ECR-2550 User Programming
olivetti ECR-300 User Programming
olivetti ECR-350 User Programming
olivetti ECR-3550T
olivetti ECR-5000 User Programming
olivetti ECR-5100 User Programming
olivetti ECR-5700 User Programming
olivetti ECR-5800 User Programming
olivetti ECR-5900 User Programming
olivetti ECR-5920F User Programming
olivetti ECR-6100 User Programming
olivetti ECR-6700 User Programming
olivetti ECR-6800 User Programming
olivetti ECR-6900 User Programming
olivetti ECR-6920F User Programming
Jun 20, 2008 | Olivetti Office Equipment & Supplies
JENSEN 323
Here are some of the codes still looking for manual
GE VCR: 2000, 2013, 2021, 2022, 2053, 2087, 2089, 2091, 2115, 2120
Mitsubishi TV 0093, 0150, 0178, 0019
JVC VCR 0067, 0041, 0008
JVC DVD 0558, 0623
samsung codes is 1004,1005,1006,1012,1013,1015,1017,1019
Motorola Cable Box: 5000, 5003, 5046, 5047, 5052
Jan 13, 2007 | Jensen 143307 Remote Control
Televison & Video Logo
27 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
