Question about Dell Computers & Internet
Sudden shutdown and restart - Dell Computers & Internet
  • 808 Answers
Its looking the registry error in ur system so do a registry repair scan with Intel software partner Reg In Out registry cleaner
Posted on Sep 01, 2010
How know if your crankshaft sensor going bad?
The crankshaft position sensor sends pulses to the ECM to inform it of the crankshaft's position (thus the name). The ECM uses this info to determine when to fire the spark plugs and fuel injectors. Failure of the sensor will cause the vehicle to shut off while running, or crank without starting. They usually fail intermittently at first, often causing ransom shutdowns, which will often allow immediate restarts. Eventually, the time between shutdown and restart gets longer and longer, and eventually the sensor will fail totally. Often, in the early stages, there will not be a Check Engine Code set for the problem, since it occurs so suddenly.
Jun 13, 2015 | 2004 Chevrolet TrailBlazer
How can i reboot my computer please
Rebooting a computer means, pressing the Reset/Restart button. But if you wish to securely restart it, click Start (Windows XP) and then "ShutDown" button, again click "Restart". There's another option when Windows XP is in Classic mode, once you press the Shutdown button, you'll see a small window showing "Shutdown", you can click the arrow button next to the "Shutdown" and then select "Restart", now click the "Ok" button to restart the system. In Windows Vista and Windows 7, click "Start", if you don't see the "Restart" button, you might be seeing the "Shutdown" button, just next to the "Shutdown" button, there's a small right arrow button, click it and select "Restart". Your system will restart.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Sep 05, 2011 | Acer Aspire 5500 5570-2609 Laptop
Why do I need to run Chkdsk utility?
Chkdsk it is command for harddrive disk checking this command run on command prompt. This command is used for recover and fix errors on harddrive. When your computer's harddrive ahs bad sectors or any error it run slow and shutdown or restart suddenely. You can fix this problem with "chkdsk" go to start menu->command prompt then type ni prompt "chkdsk /r" without "" then it ask for press "y" press "y" then restart computer then when it start it will fix and recover errors on harddrive. Let me know if you need further assistance. Thanks for using FixYa.
Oct 03, 2010 | Computers & Internet
Sudden shutdown
If the battery is full and still shuts down suddenly then it could be a heatsinking problem on your Notebook. Also try unchecking the option "Automatically Restart" from StartUp & Recovery section in System Properties.
May 03, 2010 | HP Pavilion dv6000z Notebook
Sudden Shutdown of the unit, I Cannot use my FP72E BenQ LCD monitor Properly because at the middle of using it, it suddenly shutdown, open, shutdown again, open again. is this unit is capable for long...
For the monitor that is more than 2 years old, first place to look will be the power supply, look for bad caps with bulging top first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps; http://s807.photobucket.com/home/budm/allalbums
Feb 16, 2010 | BenQ FP72E 17" LCD Monitor
Suddenly shutdown my laptop what is a problem i
Hello my friend,usually laptops when are overheating because of the processor or graphic card they start restarting or shutting down.Was your laptop warm when shut down or you was watching video or playing a game?
Feb 06, 2010 | Compaq Computers & Internet
Suddenly shutdown
Hi.
Try formatting your pc.
Maybe this will help.
Tell me if you still have a problem.
Oct 13, 2008 | Fujitsu AMILO D-7820 Notebook
For solving blue screen error
HP Notebook PCs - "Windows Unsafe or Sudden Shutdown" Blue Screen Error Occurs During Startup or Boot
Description
Windows XP may not start and the following error message may appear on a blue screen:
This error occurs after Windows was not shutdown using a safe method. The notebook may have been turned off without clicking Shut Down or briefly pressing the computers Power button. The power may have been suddenly disconnected from the computer or the Power button may have been held for more than 5 seconds.
An unsafe shutdown can damage some of the Windows system files, preventing the computer from starting properly.
Solution
If the error occurs allow the operating system to complete a check of the hard disk. Windows will prompt your to run CHKDSK. CHKDSK scans the hard drive for damaged files and repairs the files if necessary. The scan may take up to an hour depending on the size of the hard drive and the number of damaged files. The computer will restart when the scan is complete and Windows should start normally.
If Windows will not start or the computer will not boot after the scan is complete see: HP Notebook PCs - Troubleshooting a Startup or No Boot Problem (In English)
use the link to know how to use recovery option with hp laptop
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=us&dlc=en&product=18703&docname=c00608578#
_____________________________________________________
Thanks and Regard
dilipbagdi
Technical Associate
May 18, 2008 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
46 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
