Question about Dewalt Air Tools & Compressors
Deawolt D55270 5.5 8galons.. the pomp compressor pipe gets soo hot. its been burn the coper pipe and I been have to replase it 3 times. wy?
  • 90 Answers
Those pipes will get hot. they shouldn't change color or anything though. If it is getting very hot, your cylinders must be getting hotter than normal and have heat transfer as well as heat of compression.
Posted on Sep 01, 2010
Wy do my coil get hot on tata indica
coils get hot in operation but not hot enough to burn the hand
Extra hot coils are from excessive voltage and that could be an indication of a failing ECM or failing /internal short in the coil
run the fault codes
Nov 14, 2017 | Tata Cars & Trucks
Hotpoint ice diamond RFA52 P freezer ok fridge not cold enough, this is not a frost free and there are no vents in fridge or feezer?
Good day, please check at the back, at the bottom where the compressor is located for the pencil dryer(as in photo). Get a nice firm grip on it just be careful and feel the temp if it's cold or one side is hot and the other side cold the dryer is block. Otherwise feel the thickest pipe running into the compressor it should be cold if the fridge has been running for a while and the thin copper pipe existing the compressor should be hot. If the thin pipe is freezing up with a thick layer of ice and the dryer as some med-temp then there's a gas leak. If the thin copper pipe is very hot and the dryer has no temp then there's a blockage but if the thin copper pipe feels med-temp and the thick copper pipe more or less the same but a bit cooler the compressor is not pumping also feel if the compressor is running. If dryer as a warmth temp and the thin copper pipe is hot and the thick one very cold(when tipping your finger on your tongue and pressing it against the pipe your finger should stick a bit) if all checks out then it's the thermostat switching the compressor off at the rong temp.
Regards
Jun 09, 2016 | Hotpoint Refrigerators
I think i over charged my ac unit 80 lowside 251 high side.big coper pipe is cold, small coper pipe is not hot. just wondering if that would have an affect on quality of air
You may have it a little overcharged but not much. It all depends on how hot it is outside. If its around 90 degrees F, the low side would be about 68 to 70 lbs. (refrig 22) If its 110 degrees F outside, you're sitting about right. Just make sure it's not sweating water from the big copper pipe onto the compressor. This would mean you have a pretty big overcharge.
Aug 13, 2011 | Heating & Cooling
Appears to run fine. but everything thawed. black canister at bottom (with coper wires from it) is hot to the touch. approx 3 years old
Compressor is supposed to be hot... your problem may be that the unit is stuck on defrost cycle... The defrost timer should be behind the kick panel and have a dial type adjustment on it.... find it and try to turn it just a touch. It may come on but you will need to replace it if it does
Jul 20, 2011 | Frigidaire 14.1 cu. ft. Upright Freezer...
95 Chevy Surburban. Air conditioning issue, front air blows warm, rear unit blows cold. Have replaced orface 3 times, replaced compressor 3 times, replaced accumulator 2 times, flushed condensor,...
they run off of the same compressor if rear is cold and front is hot the hot and cold function in the heater box is not working possible cable problem ? or a vacum line under dash
Aug 04, 2010 | 1995 Chevrolet Suburban
EMPIRE MDL 215 VENTID NOT HOT ENOUGH
Sal,
the gas pressure test should be done. Propane should have an outlet(heater side of the regulator)of 7 inches of water column. the inlet side has to be higher than that to supply it the proper pressure. Also the heater should have been converted to LP with proper orfices and springs
Dec 13, 2009 | Rinnai RHFE-556WTA Direct Vent Heater NG...
Ford courier 1.8 diesel van, blower works, but no heat comes into the van when heater turned on
ford courier workhorse ,great van ---right when engine is hot feel the hoses that run into the heater ,also it could be the heater core was leaking and someone has joined the hoses together .if the hoses are connected and they are hot then ,try removing them and then flushing the heater with a hose pipe
Nov 29, 2009 | 2000 Ford Escort
My vulcan 1500 1997 back fire somme time wy
lean gas mixture. or the valve timing is off, but probably both. A lean mix will run really hot and allow for secondary combustion in the pipes (backfire) when the valves let even a bit of uncombusted gas through. My guess is that the bike hasn't had the carbs cleaned out thoroughly in a while. Run a half can of Sea Foam with your full tank of gas to help clean out the carbs, but really you should take them apart and dip them to clean everything out. Also you could adjust your pilot screw settings to make it run a bit more rich, but then you are just compensating for the dirty carbs. That's just my guess.
Jul 22, 2009 | kawasaki Full Suspension Mountain Bike Men
Walkin cooler
Most Likely Low on Freon. Low Pressure switch shuts That Compressor Off.
Dec 29, 2007 | Refrigerators
Air Tools & Compressors Logo
110 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
