Question about Black Diamond Oval Carabiner
The spring part has gone out to the other side and the spring will not work and wont lock
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 07, 2010
1999 FORD EXPLOROR DRIVER SIDE DOOR LOCK STOPPED WORKING THEN I USED THE PASSENGERS SIDE LOCK TO LOCK THE DOORS NOW THAT SIDE WONT WORK AND THE REMOTE WONT LOCK THE DOORS THE ONLY ONE THAT WILL STILL LOCK...
its a problem with the immobilisor i think ,in the back drivers side behind a panel is a bosch vehicle immobilisor and the relays for the doors are in here but before you play check the door lock itself as the contacts or operating mechanism inside the door could have broke away from corrosion or the plastic clips have gone brittle allowing a shaft to come loose which will cause the problems you describe so take a door panel off and have a look for a possible cause
Aug 20, 2011 | 1999 Ford Explorer
Driver side power lock wont work whats the problem
lock solenoid has gone bad needs to be replaced
Feb 09, 2011 | 2003 GMC Envoy Xl
2008 Dodge Advenger wont go out of park
The car has a shift solenoid that releases the shift lever so you can move it into gear when you apply pressure on the brake pedal. Upon depressing the brake the shifter should move freely. If not the solenoid for the shifter has gone bad
May 29, 2010 | 2008 Dodge Avenger
Driver side keyhole cover spring does not work...
You will have to replace the dust cover by removing the lock assembly. Sometimes, the entire lock assembly is replaced as the cover is crimped to the lock cylinder.
Mar 07, 2010 | 2004 Honda Civic
My driver's seat slides and does not lock into place. I can't figure out what replacement part I need to fix this issue.
the seat is on a track when u move the handle latch forward or backward a long wire and spring do the same on other side of seat if wire or spring break/or disconnect seat wont lock into track
Feb 08, 2010 | 1999 Chevrolet Silverado 1500
The driver side door lock wont go all the way up.
The outside door handle spring is broke ,or the latch spring is broke. The only way to tell is remove the door panel and inspect the rod from the handle to latch. Look for broken spring on handle. I have installed an external spring from the handle rod to latch to keep the rod in the full up position.
Nov 18, 2009 | 1999 Ford Ranger SuperCab
Door and Boot Locks
the problem lies in the drivers side operating switch for the central locking .this would involve removing the drivers side door handle and checking the switch mechanism thats built into the lock,havent done one o n this model only a opel astra ---but they are different from the opel although the car looks the same ,well similar pull it off have a go ,the key barrel must turn something so look for an internal switching or external switching and see if the spring is ok that returns the switch
May 02, 2009 | 2001 Daewoo Lanos
The door wont lock
those door latches have a spring that gets damaged they are junk. 99% you need a new latch. i replace all the time
Mar 16, 2009 | 1996 Ford Explorer
The frame tilt seized on Bugaboo Cameleon
bUGABOO will send out free replacemnt buttons even if your pram is out of warranty you need to contact them. They will fix the problem but i had to put them in the oposite sides to what their instructions suggested for them to work so def a fiddly job but does fix problem.
Dec 12, 2008 | Bugaboo Cameleon Jogger
Dishwasher door not catching
that is the spring thats gone and will not lock the jaws you need to replace the lock on the door normaly about£5.00
Dec 06, 2007 | Dishwashers
Black Diamond Oval Carabiner Logo
516 people viewed this question
Top Black Diamond Rock & Ice Climbing Experts
RatanbssBD
Level 1 Expert
Bill Boyd
Are you a Black Diamond Rock and Ice Climbing Expert? Answer questions, earn points and help others
