Question about Samsung Cameras
I put my picture in the computer and I put back my LEXAR PLATINUM II OF 2 GB inside my camera, I try the take some picture now but when I push yhe picture button I can on my scream '' CARTE VERROUILLÉE'' or ''CARD LOCK '' Why ???? I did something wrong on my last transfert ???
  • menardpaul30 Aug 31, 2010
    Thank you for your solution, the problem was the plastic '' lock tab'' on the side of the memory card.
    Thanks
  • 10,319 Answers
Remove the batteries and reinstall. it may work when done this way
Posted on Sep 01, 2010
  • 3,083 Answers
It could be software settings, or it could be that the plastic "lock tab" on the side of the memory card accidentally got moved. If the card is ok, check your manual for resetting the software- it will be in the index under "memory card lock", or something like that.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Aug 31, 2010
I want to transfer music from one computer to another using Lexar jumpdrive s5032 gb. How to do that
Upload the files to the jumpdrive. Remove jumpdrive from computer 1 and insert in computer 2. When computer 2 recognizes the jumpdrive, copy the files to a directory folder where you want to save the music. Unplug the jumpdrive.
May 13, 2015 | Lexar JumpDrive S50 32 GB USB Flash Drive...
Professional High-Speed 2GB Secure Digital Memory Card: how do I format my lexar 2 gb memory card for my c...
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
May 16, 2010 | Lexar Professional High-Speed 2GB Secure...
Tried to unlock Lexar SD 2GB and Lexar SDHC 4 GB - No luck
First of all, the 4GB card will never be able to work in your camera. Check on its face. It likely says SDHC, and SDHC cards as this format came out after your camera was designed (I know it looks exactly like a normal SD card, but it's not).
Now the 2GB card should work with your camera as it is a standard SD card. Remove the card from your camera. Look on the side of the card for the tiny slide switch, and slide it to the other "unlocked" position. Reinsert it in the camera, and see if that corrects the problem.
Oct 19, 2009 | Canon PowerShot A620 Digital Camera
Lexar SDHC Card from Kodak Easy Share, disk not recoginized
Honestly, it is most likely a defective memory card or not compatible with your camera. Sorry.
Mar 23, 2009 | Lexar Professional High-Speed 1GB Secure...
Sandisk ultra 2 1.0gb will not download onto my computer?
Inspect the camera itself under good light with a keen eye. You may find a pin is bent, broken or missing in the flash card compartment. This would require the aid of a camera technician to fix. If this is not the case though, then perhaps the card has become corrupt or faulty. I would suggest purchasing a leading brand card reader(eg lexar or sandisk) as they often come with image recovery software to help in these situations. Good Luck!
Feb 20, 2009 | SanDisk ULTRA II 4GB Compact Flash Card...
Lexar Platinum II 4GB sd card won't work on my Polaroid PDC 3070
That card is not compatible with that camera. It's too large for an older model like that. Backup the card's contents and format it. It should work in newer models but probably not the PDC 3070.
Jan 16, 2009 | Samsung Digimax S730 Digital Camera
Brought a Lexar 2gb Memory stick pro duo, when I put it my camera. My camera displays memory stick error. Look for help or possible fix.
Check if your camera accept that capacity first.
If yes >>
Reset your camera to factory settings
Format the Memory stick and try again.
Oct 03, 2008 | Creative Labs Sound Blaster Audigy 2...
How do I install my Lexar 1 gb into my new Kodak Easy share camera?
Usually the memory card (which is what the SD card is - it is like film for a non-digital camera) is inserted in the same area as the battery or batteries. If you open the battery compartment, you may see a slot next to where the batteries are placed. You should insert the card with the metal parts in the same direction as the matching ones inside the slot (there may be a small diagram on the door of the battery compartment).
Mar 10, 2008 | Cameras
Compact Flash
Read the Manual about the Max Card size
Oct 04, 2007 | Nikon Coolpix 4600 Digital Camera
Cameras Logo
15 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
