Question about Fossil Blue watch #AM3804 Watch for Men
I have a fossil model AM-3804. i have had it since january 2005 and has not worked since the middle of 2008. i need to know how i can fix it or anything i can do to make this watch work again. i had a new battery installed but the watch stopped working a couple days after the battery was put in. there were also a couple new holding pins put in place but they were put in wrong and i will also need those replaced.
SOURCE: Fossil JR8096 - Display Not Working
hi i have a watch very simalar. They run on two seperate batteries. sounds like one of them is dead. get the digigtal one replaced
Posted on Aug 24, 2007
SOURCE: link pins for a womens Fossil watch
The only place you can get them is at a watchrepair. Sometimes I have found wierd sized link holes and have had to make my own pins. I just take a small nail and file it to the size I need. If you have a dremmil tool with a sandpaper attachment it is so much easier! Take a nail that is a little bit longer than the link is and sand down in a slow graduating cone shape, make sure to top of the nail is a little bit wider than the hole on the top of the link. Once you have that , put the smaller end in the link , line up the other link so that the pin goes into both links , and then tap it in. The pin should go into the bottom of the links. It might be good to do this on a piece of wood so that if the pin goes a little through the bottom, you don't damage anything. Try to make the pin as tight as you can, and than file (or dremmil) the top and bottom to the links size. If you still have problems please let me know, and maybe I can help you further. Good luck!!!!!
Posted on Oct 27, 2008
SOURCE: Instruction Manual for Fossil Watch
-> Go to fossil.com
-> Customer Care
-> Product Info / Watch Instructions
-> Do a mouseover on the various headlines to see the design of your watch.
-> Download desired PDF file
Problem solved. Thank you!
Posted on Feb 21, 2009
  • 8 Answers
SOURCE: Question:how to set the weekday on a Fossil watch model BQ-9165.
You have to pull out the stem all the way and turn clockwise until you get to the correct day. Hopefully you won't have to wind thru the whole week.
Posted on Mar 03, 2009
  • 110 Answers
SOURCE: pin fell out of my fossil watch stainless band.
Stainless steel pins are readlily available to fit most any watch. You should be able to take it to a watch repairmens's shop and have them put it in.
Posted on Oct 31, 2009
A Fossil ME 3060 automatic watch worked great for 2 days then kept stopping. I exchanged it for a new one only to encounter the same problem. It has been wound, worn and still does this.
Anon, looks like there is a defect in that model of watch, return for refund and purchase a different model.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 30, 2016 | Fossil Watches
How do u open back to fix an fossil black 5 atm fs-4351 hand watch
Jerry, If its smooth on the back cover, you have to pry it off carefully. Get a magnifying glass and look around the cover edge, there should be a small under cut. Pry at this point with a penknife blade or similar. If the cover has 6 or 8 small indentations in it then it likely unscrews but you may still need to see a watch shop for the tool to unscrew it.
Fossil watches have a 2 year warranty so if its inside this, take it to a dealer.
Nov 03, 2014 | Fossil Watches
My fossil blue watch stops working i lost my manual, i would just like to know if the said model of my watch is automatic, or quartz?
You don't say which model watch you have.
If you go to Fossil.com, at the bottom of the screen you will see a list, click on "customer care" and under "product info" you will see "watch instructions".
Go through the list of illustrations to find yours and download.
Jul 05, 2011 | Fossil Watches
We bought the Fossil Brown rectangle watch model FS4284, it stopped working so thought it was the battery. we replaced the battery and then 2 months later it's not working again, faulty battery or is...
  • Change the battery. If your watch stops ticking, chances are the watch is not broken and the battery simply needs to be replaced. You can purchase a watch battery at your local department store or drugstore. Use the screwdriver to pry the back off the watch and place the new battery in the same place where the old one fit.
  • Step 2 If your watch is still not working, determine the problem. If you can hear the watch ticking but the hands are not moving, there may be a gear stuck inside. If only one of the hands does not move, the hand itself could be broken. Once you determine the problem, you can see whether it makes more sense to purchase a new watch or get the old one fixed.
  • Step 3 Check your watch warranty. If your Fossil watch came with a warranty that is not yet expired, Fossil will fix your watch if you send it to the company and pay for shipping and handling. See the "Resources" section below to fill out the Watch Repair Form provided by Fossil.com. If your watch strap is broken, however, Fossil will charge you a fee as broken straps are not covered in the warranty.
  • Step 4 Check a competing local watch repair store. There are watch repair stores located all over the United States that will repair a Fossil watch if your watch is no longer under warranty or if you do not want to pay the shipping and handling to send the watch to Fossil's watch repair department. Although the watch repair store may not have the exact strap you are looking for, it may offer a replacement strap that is similar to the one that originally came with your watch.
  • Step 5 Return the watch to the store where you bought it. If you purchased a Fossil watch that was broken when you purchased it or broke recently after you brought it home, you may be able to return the watch for a refund or store credit. Check with the store's policy before purchasing the watch if you are concerned about returns.
  • Aug 10, 2010 | Fossil Brown Ip Brown Rectangle Ip FS4284...
    Basic Functions of Fossil FS4358
    Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all FOSSIL watch manuals.Rate me, please.
    Mar 17, 2010 | Watches
    I have a fossil blue watch that isnt working. i have tried to change the battery and that does not seem to help.
    take it to a jewlrey store, like sergios. They know how to fix all watches. I took my fossil blue to 4 watch stores including the fossil store in the mall and none of the stores could fix it. I took it to sergios they changed 2 batterys in like 5 minutes with no charge.
    May 03, 2008 | Fossil Watches
    Fossil Blue watch #AM3804 Watch for Men Logo
    64 people viewed this question
    Top Fossil Watches Experts
    Ansel Alberto
    Ansel Alberto
    Jimmy Accardi
    Are you a Fossil Watch Expert? Answer questions, earn points and help others
