Question about Philips Magnavox 52MF437S/37 52 in. LCD TV
The tv is not come on and the green light on the power button if flashing on and off very fast
  • 33 Answers
Do a hard rest. unplug for two min. then plug back in. let me know if that helps
Posted on Aug 31, 2010
Flashing green power light
If the model indicated here is right It could be in the power supply and this model sometimes fails where light just blinks--that could be also convergence issue--in this model there is a way to disconnect the power going to the convergence board to see if set will then turn on.
Jun 14, 2012 | JVC AV-65WP74 Rear Projection Television
Can set up th remote control for this tv with the direct tv cable remote
Here's how to scan for TV codes on your DIRECTV remote
1.Make sure your TV is turned on.
2.Slide the mode switch at top of remote to "TV".
3.Press and hold the MUTE button. This is located above the number 1 button.
4.While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
5.Then enter 991, the green light on remote should flash twice.
5b. Press 1 again (it will flash twice again), then you press the power on button at the very top right.
6.Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
*If you hit channel up very fast, you risk going past the code. Pressing channel down will back it up. I alway hit channel up very fast till the tv turns off, then back it up slowly till it comes back on.
7.When the TV powers off, press and release the SELECT button.
*Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
Mar 05, 2011 | Curtis LCD2425A TV
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
T2042 E-Machine Both the power button and the hard drive light keep flashing i also noticed the lights also flash they all flash fast but never boots. The power button is flashing green along with green...
Disconnect the power cord from the back of the system. Press and hold down the power button for 10 seconds.
Disconnect everything from the back of the computer ,except keyboard, mouse and monitor.
Reconnect the power cord and then check
Thanks for using fixya
proton
Nov 07, 2009 | E-Machines eMachines Desktop PC
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Tv won't come on. It has a flashing green light on by the power button.
the tv is not come on.it has a flashing green light on.tv model hd 1080.
Oct 19, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Oct 12, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Philips Magnavox 52MF437S/37 52 in. LCD TV Logo
129 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
