Question about Maytag 24" Built-In Single Gas Wall Oven - Stainless-Steel
Oven beeps and display read "F3". what does this mean?
    Genius:
  • 1,157 Answers
Hi dpaulthomas,
The F3 fault code description is a shorted or open oven temperature sensor. The easiest way to resolve this error is to check the sensor harness and harness connection between oven sensor and oven control. If you noticed that the wiring is all ok, replace the oven temperature sensor (RTD).
Hope it helps.
Thank you for using FixYa.
Posted on Jun 21, 2011
F3 appears and it beeps when I try to preheat the oven
The F3 error code means that the oven temp. sensor is shorted out....this tip i wrote explains in more detail what the F3 means and what to check. http://www.fixya.com/support/r10343697-error_codes_f3_f4_mean_oven
GENE
Sep 13, 2011 | Maytag Ovens
The oven reached a very high temperature and the digital screen read F1 and F3 at times and also beeped for sometime... could not turn the oven off so I unplugged it.. Not sure what F1 or F3 means...
Hello & Welcome to FixYa
F3 error code indicates an open/shorted oven temperature sensor and to solve this problem the temp.sensor needs replacement. If you want to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Mar 28, 2011 | Ovens
F3 displayed and won't stop beeping
F3 in most machines is an indicator of a faulty/shorted oven sensor. Disconnect the sensor quick connect and it should Ohm out to around 1100 ohms. Check fro continuity between each wire to frame. If you get a reading your pesky sensor has shorted to frame. Replace that ****** and party on!
8cb36f7.jpgGet yer popcorn ready for the Checking the sensor Movie:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 08, 2010 | Ovens
Have a Kenmore electric drop-in range less than 2 years old. Turned on self-clean cycle but after an hour or so started beeping and F3 was displayed. Have lost manual.. What does f3 mean?
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Aug 04, 2010 | Kenmore 42161 / 42169 Electric Single Oven
Oven doesnt heat, after a few minutes displays error code F3 E2
F3 E2 USUALY IS THE SENSOR IN THE OVEN IF YOUR LUCKY YOU CAN REMOVE THE 2 SCREWS INSIDE AND PULL THE WIRES THROUGH. MAKE SURE YOU UNPLUG IT FIRST.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 12, 2010 | Whirlpool RBS275PD Electric Single Oven
Display reads " -F3-
Replace the oven temperature sensor. Unplug the range. Open the oven. The temp sensor will be in the top right or left of the oven.A short metal piece about half the size of a pencil. Remove the screws,pull it out carefully. Disconnect the wire plug. Reverse this order to install the new sensor.
Sep 14, 2009 | Frigidaire FEB27S5A Electric Single Oven
F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
thank u
rate me!!!
Aug 14, 2009 | Maytag Ovens
When using oven it beeps and displays f3
Could be one of 2 problems. Perhaps both.
Unplug the range.Access the control panel and unplug the ribbon connector from the control.
Wait 35 seconds and re-connect it.
If it continues to beep and code replace the temperature sensor.
Mar 15, 2009 | Kenmore Ovens
Kenmore Electric Oven Model 4088816 - Error Code F3
f-3 means the oven temp sensor is bad. replace the sensor and problem solved
Nov 25, 2007 | Ovens
Maytag 24" Built-In Single Gas Wall Oven - Stainless-Steel Logo
169 people viewed this question
Top Maytag Ovens Experts
Oloyede Monsuru
Mack Baxter
Craig Butler
Craig Butler
Are you a Maytag Oven Expert? Answer questions, earn points and help others
