Question about Refrigerators
I purchased a new ice maker for model ED5GHGXMQ00 which at this point number four for a 4 year old model. The model that I purchased is 4317943 but it will not come on.I plug the old one back in and it cycles but will not drop ice.What is my problem with the new one.
    Genius:
  • 1,073 Answers
Check the electrical connection at the end of the connector that plugs into the icemaker module the one with the black white tan and green wires look to see that the ends of the connector are not spread apart
Posted on May 09, 2008
Won't make ice
The bin should fill up and the machine shut off in 24-36 hours from time it is turned on. If not the condenser coil may be dirty.
1.Clean the coil this should be done every year.
The bin brain may be partially restricted causing ice to melt faster.
1. clean out the drain.
The air flow to the condenser may be obstructed.
check to make sure there is nothing covering up the grill or coil.
Nov 29, 2013 | Scotsman DCE33PA1BC 15in Built-in...
Whirlpool ice maker locks out after every cycle. I removed the ice maker to clear a ice jam and after I reinstalled it, it only runs one cycle and the control locks in the up position shutting the ice...
The internal part that is supposed to relases the control arm when the icemaker is harvestiing a cycle is hanging up and the icemaker itself or motor board would need to be replaced...all that is really needed would be the motor module and its less expensive the part numbers are
ENTIRE ICEMAKER 4317943
MODULE W10190935
depending on which one ya decide to replace (the entire icemaker or just the module) it can be purchased at your local appliance parts store or online at
searspartsdirect.com
repairclinic.com
apdepot.com
apwagner.com
partselect.com
GENE
Sep 26, 2011 | Refrigerators
Replace water inlet valve for ice dispenser with new. When icemaker cycles it dispenses through the water dispenser instead of tube going to ice maker. I have switch lines around but can only get water...
The ice maker is what tells the water control valve to open so it may be correct now and the thermostat in ice maker may be defective. Part 27 or 627985 down below where it says Whirlpool Ice Maker Parts Breakdown and in that photo is the ice maker thermostat. If your ice maker has been used for many years the complete ice maker may be better to replace. Ice maker Model=> 4317943
Or click here=>Point and Click Then enter model or part number into search feature. If you have questions please ask, Thanks, Sea Breeze
Whirlpool Model ED5GTFXKQ02 Ice Maker Parts Breakdown
Dec 17, 2010 | Whirlpool Refrigerators
Hello. I have a Kenmore Elite side by side refrigerator, model# 106.50502990. It was manufactured in March of 2000. The ice make broke and I need a replacement. The ice maker part# I got is 4317943. ...
4317943,i looked it up it says that this is the ice maker for your machine,do you know that it comes with different harnesses,or take off the old harness and put it on the new ice maker,it does have 4 wires on each harness,i just called sears for you and the guy i talked with says that's the ice maker for your machine and there's no substitutes for it,that should be your ice maker
Oct 19, 2010 | Kenmore Refrigerators
Not making ice
There are several possibilities for this and the dual water control valve is one of the possible problems. Try pouring tap water into ice maker tray if no cubes are present. Allow it to freeze and if the cubes drop then the water control valve part Click Here=> 2188542-1 Then you have a possibility that the ice maker thermostat is at fault item number 27 in photo here=> 627985 Ice Maker Thermostat Sometimes the problem is located inside ice maker and buying new makes it more worth the cost than the cost of replacement parts. This is the Replacement and parts here=> 4317943 Complete Ice Maker
If you need additional help I can be found here or here=> Appliance 911, Thanks Sea Breeze
Oct 09, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
I AM HAVING A PROBLEM WITH MY ICE MAKER FOR THE WHIRLPOOL MODEL ED5FHEXMSI0. THE PROBLEM I'M HAVING IS WHEN I PUSH DOWN THE BUTTON ON THE ON POSITION,I GET A NOISE DURING THE ICE MAKING PROCESS.NOW I 'M...
it sound like the the module on ice maker is broken on etheir case is better to repl the ice maker just remove the 3 screws on ice maker 2 on top 1 on bottom unplug wire harness install the new one same way part number is 4317943 this is a ice maker for all whirlpools one fits all that is if you are getting wtr ok let me know
Oct 15, 2008 | Whirlpool Refrigerators
Ice Maker Won't Drop Ice
you have a problem in the module of the ice maker if it is new take it back for a new one
May 02, 2008 | Refrigerators
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
