Question about Garden
I'm looking for a Sherwood water transfer pump Model AT120 12V.D.C. called the Aqua tiger . It is part of a chemical spray system.
5 Suggested Answers
SOURCE: How do I reset the EFO Aqua Control system?
Thanks Guest! It worked perfectly lifting the face of your machine by 45 degrees
The washing machine was full of powder (this was the cause)
Posted on Oct 10, 2008
SOURCE: My Tiger hot water pot,
Hi! My tiger hot water pot had the same problem, and I founded the solution IT¨S SILLY but works I blow for the pipe where the water flows. The hot pot was full of water. really works for me
Posted on Nov 27, 2008
SOURCE: water boiling but not pumping round spray bars
the nut on the impeller was tightening up as the pump span round causing the motor to jam
Posted on Sep 01, 2009
  • 3 Answers
SOURCE: Since we changed from a pumped gravity fed to a
One possible reason is you have reversed the hot and cold supply pipes in the process
Posted on Dec 21, 2014
The shark moves in the water but does not pick up anything
contact the manufacturer we have no info on that one
Aug 30, 2015 | Aqua Vac Tiger Shark
Filter is green and clogged
make sure to soak filters in TSP tri sodium phosphate can purchase at hardware store put a handful in bucket then fill with water soak filter for 30 minutes then rinse off then soak in a 4 to 1 muriatic acid and water 4 parts water 1 part muriatic acid solution then rinse filters should be like new
Jul 22, 2014 | Aqua Vac Tiger Shark
Brand new and doesn't work
Fuse or small Reset switch somewhere? what model?
May 25, 2014 | Aqua Vac Tiger Shark
Tiger Shark moves slow
no tension need to replace tracks
Jun 25, 2012 | Aqua Vac Tiger Shark
My tiger shark does not work!! I have power to the transformer and shark, but it won't move. I just spent $400.00 at my pool store to get it fixed, they put new wheels, filters, and a new cord and...
The motor pack...
Was the store able to scan the motor to pull out operational info? Was it water tested prior to being returned to you? Perhaps the store will make accomodations to get it returned and repaired correctly?
John
Jul 23, 2011 | Aqua Vac Tiger Shark
Coleman Powermate pressure washer. Model PW0751310 A lot of water leaks out in the handle where you squeeze for the unit to work, thus the power spray is weak at best. Took handle/arm apart and didn't...
There may be orings in gun but usually not available as a repair kit. Replace the gun with a 5000 to 6000 psi. You will get a much longer life by over sizing gun. If you like to tinker, you can by orings at Lowes in the plumbing department. Lube the orings with silicone paste (also sold at lowes). Good luck
Mar 17, 2011 | Caterpillar Cat Pump Pressure Washer Pump...
My tiger shark pool cleaner spends a lot of time at the top of the water line. How can I adjust it so it does not climb so far?
the tiger shark is designed to climb but you can adjust the weights to keep it down. check out http://www.aquavacsystems.com/Weights-and-Floats_ep_31-1.html
for more info and specs of your unit. good luck
The Pool Tech
Jul 02, 2010 | Aqua Vac Tiger Shark
Plugged in and turned on but doesn't move
look at the rubber belt wrapping the wheels, there are some little rubber numbs along the belt in order to grap the wheels and make them move. If some of the numbs are broken, the grab is too week to move the wheels. I guess, replace the belt is the only solution
Aug 11, 2009 | Aqua Vac Tiger Shark
Garden Logo
125 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
