Question about Protron PLTV3250 32 in. LCD Television
Plug for pc speakers wire - Protron PLTV3250 32 in. LCD Television
  • Protron Master
  • 5,184 Answers
To use the speakers on the TV when you connect to a PC, get a 3.5 mm M/M audio cable (it may be called a patch cable or audio aux cable) and connect it to the PC audio in port to the left of the composite A/V ports (that's the group with 3 RCA jacks yellow (video)/red(R audio)/white (L audio)). The other end goes into the computer's line out (speaker out) port - which is generally colored green. Otherwise your regular computer speakers will play the audio.
If you want the TV's audio to output to external speakers, use the headphone jack (sometimes labels Phones, again a 3.5 mm plug) or a set of speakers/receiver that takes an optical audio connection. The optical audio jack is between the two coax connectors. Please note using the headphone jack will force the internal speakers off.
I hope this helps.
Posted on Aug 31, 2010
How do u connect a sony speaker system to a pc?there are 2 speakers plus a sort of base unit
It is easy to hook up this 2 speaker setup first the ac power cord, then plug the green plug into the green audio output on the rear of your pc, there may be a wire connecting the 2nd speaker.
Jul 02, 2011 | Audio Players & Recorders
What wire colors do i connect to my old wires in my 95 dodge neon
For Dodge Neons:
Factory in-dash wire harness has 2 pc harness (black plug and gray plug).
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
Metal braid plastic connector attached to back of radio is the ground wire.
May 20, 2010 | Car Audio & Video
Anyone have the 2001 VW Golf speaker wire colors?
If your Golf is the premium sound model here is the list:
2001 Volkswagen Golf Car Radio Wiring Schematic for Monsoon Audio
Car Radio Battery Constant 12v+ Wire: Plug #3, Pin #7
Car Radio Accessory Switched 12v+ Wire: Plug #3, Pin #4
Car Radio Ground Wire: Plug #3, Pin #8
Car Radio Illumination Wire: Plug #3, Pin #6
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Plug #2, Pin #5
Left Front Speaker Negative Wire (-): Plug #2, Pin #6
Right Front Speaker Positive Wire (+): Plug #2, Pin #3
Right Front Speaker Negative Wire (-): Plug #2, Pin #4
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Plug #2, Pin #7
Left Rear Speaker Negative Wire (-): Plug #2, Pin #8
Right Rear Speaker Positive Wire (+): Plug #2, Pin #1
Right Rear Speaker Negative Wire (-): Plug #2, Pin #2
Signal for Anti-Theft Alarm System Wire: Plug #3, Pin #1
Data Link Connector (DLC) K-Wire: Plug #3, Pin #3
Battery Supply Constant 12v+ Wire for Anti-Theft System (SAFE): Plug #3, Pin #5
CD Changer Data In Wire: Plug #1, Pin #13
CD Changer Data Out Wire: Plug #1, Pin #14
CD Changer Clock Wire: Plug #1, Pin #15
CD Changer Constant Battery 12v+ Wire: Plug #1, Pin #16
CD Changer Control Signal Wire: Plug #1, Pin #17
CD Changer Ground Wire: Plug #1, Pin #18
CD Changer Left Line Out Wire: Plug #1, Pin #19
CD Changer Right Line Out Wire: Plug #1, Pin #20
May 18, 2010 | Car Audio & Video
No sound from speaker on the right with power led and digital audio port for tht SP08A11 speakers
Check the wires for tiny cuts. The Auxiliary cord on the speakers are most likely at fault
Apr 11, 2010 | Computers & Internet
How do i set up
Ty this - there is one wire with a green end - plug this into the sound card on your pc.
Take the one wire from the left speaker and plug it into the main control box to the matching plug.
Take the remaining wire and plug it into the other matching plug on the back of the main LARGER control box.
Plug it in the wall socket.
Play music on your pc.
Mar 29, 2010 | Creative Labs Inspire T3030 Computer...
How do i hook up two altec lansing speakers and
Depending on the sound card installed in your system, integrated into the motherboard or not, you may need a "Y" splitter adapter. Typically, the subwoofer has a black plug while the regular speakers have a green plug. The red color is a new one on me, but let's assume that it is the subwoofer. If you have a black outlet on your computer, plug the red one into that outlet.
If your speakers came with your system, HP would have provided you with proper adapters to make the speakers work for whichever speaker system you have. If you have any "Y" adapters, use them.
Feb 23, 2010 | HP Pavilion a1610n PC Desktop
Audio cuts in and out in media center or while watching a dvd
Check to ensure that the speaker connection plug is fully inserted into the speaker jack on the computer. Do the same for the power connection at the speaker, too. Slightly wiggle or twist the connections and wires - one at a time to isolate the source of the failure (can be the power plug or wire, audio plug or wire, or even the jack on the PC . If related to the speaker plug, try using the speakers in another speaker jack on the PC - or other device (mp3 player, etc.) if the problem is still present on both locations, it is related to the speakers / power. Try using a pair of headphones plugged directly into the speaker jack on the PC to see if the problem is present still. If the problem is common to both speaker and headphones, the jack on the PC is likely the culprit, and a new sound card will probably have to be installed. Otherwise, replace / repair the speaker cable, plug or system.
The likely source of the problem is a stretched wire along the cord - or at the plug. A repair can be attempted if desired - or replace the speaker system if lacking tools or if unsure how to go about it.
Sep 28, 2009 | Gateway GT5016E (RBGT5016E) PC Desktop
Wiring internal board of labtec computer speakers
The shielded wires are for ground, so they get connected together. Plug the wire into the PC and run some music. Then touch each wire to the others. You only have a couple of combinations to try...red-to-green and white-to-yellow, or red-to-yellow and white-to-green, . You can do this while the PC is one and music playing until you get sound thru the speakers. There virtually no current running thru the wires and you can't hurt the PC by doing this.
If the speakers use an external power supply, have it plugged in and working when trying these connection options.
Sep 07, 2009 | Labtec LCS 1040 Computer Speakers
Don't know how to hook them up
What a lovely daughter, how very nice of her,
here goes....straight for Mr. Koss
To Operate with AC Adapter
  1. Open battery compartment located at the back of both speakers and remove wires.
  2. Replace battery covers.
  3. Connect DUAL PLUG CONNECTOR on left speaker to right speaker at connection marked "TO LEFT SPEAKER."
  4. Connect remaining wire with 3.5mm plug to headphone jack on your audio source.
  5. Connect AC adapter (not included) to back of left speaker at connector marked "DC 6V." Plug remaining end of AC adapter into wall outlet. Be sure your AC adapter is built with the center pin as ("-") negative. Connect remaining wire with 3.5mm plug to the headphone jack on your audio source.
  6. Turn ON/OFF switch at back of right speaker to "ON."
  7. Set "INPUT SELECTOR" switch to audio source.
  8. Turn on audio source
  9. Adjust sound in the following ways: Turn volume control to desired level; push Bass Boost button located on right speaker to "ON" for added bass; push Treble Boost button on right speaker to "ON" for added treble
  10. Operating a microphone through your speakers require an additional 3.5mm plug to 3.5mm plug cable (included). Connect cable with 3.5mm straight plug to right speaker at input marked "MIC" on back of speaker. Plug the remaining 3.5mm L--plug into the mic input on audio source. Connect your microphone to the front of your speakers at "MIC" input (microphone not included)
Hope you have all of the skinny you need, good luck,
please leave a rating, thank you kindly
Apr 27, 2009 | Computers & Internet
Installing Labtec LCS 800 speakers
1 wire goes between the 2 speakers
1 wire goes from the speaker with 2 jacks in it to the computer, the back of the computer should have a green port to plug in the cable to
1 wire is the power
this is a guess without seeing your setup
Feb 17, 2009 | Labtec Audio Players & Recorders
Protron PLTV3250 32 in. LCD Television Logo
239 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
