Question about Citizen Navitach JQ8020-52Y wristwatch
I replaced the battery but the analog hands don't move
Hands wont move but the digital part works
That watch might take two batteries when it's open there should be a big battery which is a lithium but under it will be a silver oxide batter that needs to be replaced if there is not then the analog has to be lubricated and spun out the worst case senerial is u will have to replace the movement remember all was change ur batteries asap when the go dead. Digital batteries always last longer than the analog batts do
Apr 22, 2017 | The Watches
Do I reuse 2 batteries for my Umbro chrono watch?
Normally the Umbro Chronograph watches having analog and digital clock works on single battery. When u put the battery inside ur digital is working fine but some times for analog hands do not move due to the loose button which is used to move the watch hands. So pull it out again and insert it agin gently till tick sound comes and u r good to go.
Let me know if ur watch is working successfully:)
Jan 27, 2017 | The Watches
Wrangler Hero Watch analog hands dont work after battery replacement
Remove the PCB and replace the AG4 battery in the analog quartz movement. The stem can be removed by pressing the small lever through the hole visable after the CR2016 battery has been removed. I think it uses a Y121 movement.
Jan 31, 2013 | Watches
The watch hands don't move
the battery will need changing digital and analog watches normolly have two battaries.
Nov 27, 2012 | Watches
Digital working, hands don't
digital and analogue watches have 2 different batteries,I believe you need to replace the battery of the analog part ..just reminder,so save money and time you can replace both at the same time to prevent to replace the digital one 2 months later.!
Hope this helps!
Take care and please Remember to rate/vote for us to continue for Helping out the Community :)
Thanks
Jul 04, 2011 | Watches
Will the analog (hands) stop working on a Wave Ceptor when the battery is low/dead? Digital feature still works fine....watch about 4 years old
Yes, definitely analogue part will stop, because it takes more power to move gears and hands. Replace battery and you'll be OK. Rate me, plz.
Mar 16, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
I cant get the hands to move on my iron man 42 lap dual tech watch
This watch has two batteries in it, one for the digital display and one for the analog movement. Chances are you just need to replace the analog battery, which is under the larger digital battery.
Aug 15, 2009 | Timex Ironman Triathlon 42 Lap Combo Dual...
Getting analog part of Mossimo watch to start
FIXED!!!
As it turned out these Mossimo ANA/DIGI watches use two different batteries, one for the digital part (big) and other for the analog mechanism (small).
Have the watch serviced to change the second battery and VOILA!!!!
Enjoy!
Mivales.
Made in Costa Rica!!
Sep 01, 2008 | Watches
Cant get Casio 4303 to enter receive mode
See: http://ftp.casio.co.jp/pub/world_manual/wat/en/qw4303.pdf
and go to the section "Adjusting the Home Position"
This is a "calibration" procedure to get the motor of the analog movement back to the home position of 12:00. This worked for me, after replacing the battery.
Note that in this procedure the hour hand does not move separately, but moves with the minute hand. So to get the hour hand to move, you have to let the minute hand spin a number of times until you get the hour hand up to twelve o'clock.
Jul 16, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Analog hands not moving but digital part works fine.
A Benrus advance is not a Casio PRG-60T Tough Solar Protrek watch. You posted your query in the wrong place.
Jun 20, 2008 | Casio Triple Sensor Pathfinder PRG60-1AV...
Citizen Navitach JQ8020-52Y wristwatch Logo
Top Citizen Watches Experts
Jimmy Accardi
Are you a Citizen Watch Expert? Answer questions, earn points and help others
