Question about Kitchen Ranges
Ceramic/glass top stove
Left side back burner no longer working, any way to fix myself
  • oldsoo May 09, 2008
    Hi, I have a 2001 GE ceramic/s top range, the back left burner has stopped working, how do I fix this?
  • 117 Answers
Lift the ceramic top and look at the burnner to see if it is bad or not.
You only have to take 2 screws in the front of the ceramic top at the bottom, just open the oven door and look at the corners.
Don't forget to unplug the stove first
Posted on May 10, 2008
Is it okay to use glass whistler tea kettle on ceramic stove top range
I've seen mixed results across the internet on this one. From personal experience, for some reason, my glass teapot left some sort of stain on my ceramic stovetop. It also took longer to heat. I then went out and bought a simple metal one and have been pretty satisfied. If cosmetics are a concern, it's not too difficult a step to pour the water into your teapot after the fact, right?
Jul 23, 2014 | Frigidaire Ffed3025ls 30 Smooth Top...
Maytag ceramic top stove with the double oven, two small burners don't get hot anymore can I fix myself and how?
It is simple . Before the process make sure the the power is off .. There screws on the back after removing them you can lift the top n easily remove the none working ones . You can buy the spear ones online or local shop . I have done it myself or search YouTube with model number youse come a cross with repair option . Good luck .
Aug 06, 2013 | Cooktops
I have a Jenn Air S160 stove and the burners stopped working. Is there a reset button? The grill does work on one side but the burners do not. Thanks, Pam
Try switching the grill to the other side if it works the ceramic burner is bad replace the ceramic burner. burners and grill coils unplug when you pull them out. The left one pulls out from the front the right one pulls put from the rear. you can enterchange the burners on either side.
Oct 07, 2010 | Jenn-Air Kitchen Ranges
I have a kenmore ceramic top electric stove and one of the burners quit getting hot. what could be the problem
It is a kenmore glass top stove about18 years old. One of the burners stop working just wondering if I can fix it myself?
Aug 06, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Big chip in glass top burner
If you are looking to fix instead of replace (the better option) you will need to find a ceramic adhesive to put the parts back in place. You arn't going to find it at a hardware store. Try this link. It sells for about $20 bucks.
http://www.waleapparatus.com/catalog.asp?prodid=548630&showprevnext=1
Jan 04, 2010 | Frigidaire FEF336BC Electric Kitchen Range
I just shatter the top of my stove ,glass ceramic, can it be repaird.. it's a glass cake cover fell handle first and 3 of the burners have cracks running through them ..do i hve to replace it or can it be...
Unfortunately no your ceramic glass top cannot be repaired and will have to be replaced. as for the burners as long at the metal heating part of it isn`t damaged and its just the outer white coloured insulation that is cracked or chipped this is okay and still operate normally.hope this helps
Thanks
Oct 12, 2009 | Maytag Ovens
How can I fix a hairline crack on my Hotpoint range top?
There is nothing you can do to remedy this problem short of replacing the glass top. Sorry.
Apr 03, 2009 | Hotpoint RB787 Electric Kitchen Range
Soup boiked over on stove top
I had some luck removing food and other stains with the new Vielda Glass Ceramic Scrung (its a sponge)
"Special scour sponge for cleaning glass ceramic cook tops without scratching. Eliminates burnt-in stains and greasy dirt film. Removes grease and loose dirt particles. Microfibre side will create a streak free finish."
I found mine at Walmart. It was a little pricey but if you just use the sponge for the stovetop then it will last a very long time.
Hope this helps.
Dec 17, 2008 | Kenmore 95592 / 95594 / 95595 / 95599...
Burner no longer functions
two thiongs, you might have a bad switch( under control knob), or before you try that ck the old elemnt that you replaced, on the back of the limiter( the glass rod that goes through elemnt itlself), you'll see little letters 1a,2a,1b,2b.--- new replacemnets depending on age are wired differently, they too will have 1a2a1b2b but in different position. id check that first
Mar 02, 2008 | Jenn-Air JES9800AAS Electric Kitchen Range
Frigidaire smooth top stove
MY OVEN IS WORKING, THE STOVE TOP DOSEN'T. tHE CLOCK SHUTS OFF WHEN i TURN THE BURNER KNOB OFF AND WHEN i TURN ONE BURNER ON THE CLOCK FLASHES 12:00 AND THERE IS A SHORT BUZZER SOUND COMING FROM BEHIND THE PANEL. CAN I FIX THIS MYSELF?
Dec 16, 2007 | Frigidaire Gallery Series GLHS269ZDB 36"...
Kitchen Ranges Logo
842 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
