Question about HP Deskjet F340 All-In-One InkJet Printer
My hp deskjet f4400 printer does not respond at all. Can't turn off with power button, orange light on left side is solid on, and the digital imaging monitor says it is disconnected when it isn't. Everything is plugged in correctly and I've tried disconnecting all and reconnecting all. Even uninstalling program and reinstalling. Please help.
headstrong
  • 233 Answers
SOURCE: Printer not responding to the printer
what kind of printer is it?
remove printer from USB, and un-install, reboot
insert CD that came with printer and run installation "DO NOT CONNECT PRINTER" installation should ask what kind of connection USB or parallel AND it will tell you when to connect it
NOTE: connect it to a different USB port that the one you used.
again, this is general instructions as I have no clue on what printer you have.
Posted on Jan 06, 2008
  • 125 Answers
SOURCE: HP DeskJet F380 won't copy
If you can't get it to scan an image then you might have to have it brought to a repair center. How often do you use the copy function? Scanning function?
Posted on Apr 23, 2008
The Machine
  • 788 Answers
SOURCE: How to install my printer without the CD installer
Go to HP.com, click on Drivers Download, enter Deskjet F830 in the model box and click search. You will then be asked to pick your Operating System, most likely Windows XP or Vista. You will then be shown all the available downloads for that printer. Download and install the driver and the printer should work.
Posted on Oct 07, 2008
myjosh007
  • 530 Answers
SOURCE: My hp deskjet D4160 will
hi im josh in cebu phils. Friend it will not work now.coz maybe there is a problem in your connections. check the cables properly. or clean the parts of your printer especially the feeder coz it wont dtect the paper if its alreadyu covered with dirt good luck.!
Posted on Feb 23, 2009
  • 75 Answers
SOURCE: HP Deskjet 1220c Orange and Green light on
TRY LUBRICATING THE SILVER SLIDE BAR WITH SOME SEWING MACHINE OIL,DONT GET OIL ON ANY OTHER PARTS
Posted on Mar 09, 2010
My hp laserjet 1300 printer shows blinking the orange light instead of the green one and I couldn't find out what is the reason
1. Go light/button blinks twice with solid green and orange lights
2. Green light starts blinking with go light twice and then both go off
3. orange light goes off.
4. green light followed by orange light followed by go light cycle twice and a third time by the green light
5.followed by the orange light continuously blinking.
I have already tried the following trouble-shooting:
1. Put in a new cartridge
2. Made sure there is paper properly seated in the tray
3. Made sure all doors closed (I even took off left side to verify no memory cards
4. Verified all doors closed
5. Done a cold reboot by holding the Go button while turning the unit on.
6. Repeated steps 1-5 multiple times.Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For HP Support
Mar 06, 2014 | HP LaserJet 1300 Printer
Hp 4480 how do you unpause it
The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions):
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
    If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
    For additional support please visit http://www.inkjet411.com
    -Thank you
Dec 09, 2013 | HP F4480 All-In-One Printer
HP Deskjet F4400 able to install software on Windows 7 Home Premium 64-Bit but printer will not connect. Printer worked well previously on Windows XP operating system. All connections are secure and the...
Okay, we need to uninstall the printer. Go to Devices and printers~right click on the HP printer and left click on Remove device. Then reboot. The correct drivers should get installed automatically. If not use the installation CD that came with the printer or better still (if the printer is old) go to the HP web site and download the Win 7 drivers/software for the F4400.
May 19, 2011 | Computers & Internet
Have a deskjet 710c inkjet printer the inks seem to be stuck over to the right and the 2 orange buttons are blinking. ... * Solve It! Solve It! Bid * * * ... have a deskjet...
I found this on the HP website. http://h10025.www1.hp.com/ewfrf/wc/document?docname=bud09179&cc=us&lc=en&dlc=en&product=59307&tmp_track_link=ot_search
POWER light On c00106963.jpg RESUME light Blinking c00106965.jpg PRINT CARTRIDGE light Blinking c00106961.jpg Problem
The BANNER lever needs adjusting.
Solution
1. Turn the printer off.
2. Move the BANNER lever (next to the paper tray) up and down a few times.
3. Turn the printer on.
If these solutions did not fix the problem, have the printer serviced.
Oct 27, 2010 | HP DeskJet 710c InkJet Printer
Hp deskjet d1560 printer light flashing
After your printer has completed its initial startup you should have a solid green light. If the light indicator is blinking or orange often this is an indication of a printer error. For example, this could indicate a paper jam, issue with the ink or toner cartridge, or other serious error.
Because there is no standard to what a blinking light or orange light means if you're getting either of these we suggest referring to the printer documentation for troubleshooting steps or methods of determining what the status indicator is reporting.
http://h10025.www1.hp.com/ewfrf/wc/searchResults?tmp_product=HP+Deskjet+D1560+Printer&product=3374275&tmp_qt=power+light+flashing&lc=en&dlc=en&cc=us
Aug 06, 2010 | HP D1560 Deskjet Printer InkJet
Hhp deskjet 5550 - orange and green light keep
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.) 2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.) 3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons. 4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times. Finally press the Power button.
Jun 09, 2009 | HP DeskJet 5550 InkJet Printer
HP Deskjet 610CL
This is the resume button. If it is blinking and the power light is steady and if just installed a print cartridge, make sure the cartridge is securely snapped into the printer with the arrow aligned with the dots on the top of the printer cartridge cradle.
Close the top cover of the printer if it is open.
Check the lower (IN) tray to make sure it contains paper and that the paper is correctly loaded in the tray.
Press resume to clear the error condition. Then check your computer screen for any reported error message and corrective action instructions.
If the resume and power lights are blinking - press the power button to turn off the printer. At the computer, cancel any documents awaiting printing. Then press power button again to turn on computer. Good luck from Lady Isobel.
May 15, 2009 | HP DeskJet 610cl InkJet Printer
Canon i560 Ink jet Error Code 5C00
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
May 05, 2008 | Canon BubbleJet i550 InkJet Printer
HP Deskjet F340 All-In-One InkJet Printer Logo
691 people viewed this question
Seeker5211
Seeker5211
