Question about Samsung RFG297AA (285 cu ft) Bottom Freezer Commercial French Door Refrigerator
We just bought the samsung RFG 297AA french door refrigerator and have had it for 5 days and we can't get it to make ice. we can get water thru the front door, so i know the water is on.....would there be some kind of a blockage that i could check?
carlsbiz
  • 1124 Answers
SOURCE: My icemaker in my large French door Samsung
There is no way to speed it up..
If the bucket is empty - 2 to 3 days to fill is normal..
It takes somewhere around 37 minuets for new cubes to freeze,, then dump.. Cant make the ice freeze faster..
If it has a inline filter on the water line - replace it.. If it is clogged it could slow the water that is going in..
If you-all use allot of ice and empty it before it catches up - I would suggest getting a bag of ice from the store and put some in the bucket to keep the ice level up..
Have a nice day...
Posted on Sep 08, 2009
  • 1891 Answers
SOURCE: Samsung French Door Refrigerator not cooling
it's only 4 weeks old ./ don't mess with it it has a warranty you may void it if you work on it . it is probably in the main digital control in th fresh food .. but i would call the seller and they can set up a service for it .. mm
Posted on Dec 24, 2009
  • 65 Answers
SOURCE: samsung RFG 297 series... contro panel reads 88 88
This is technical unit an they can be pretty touchy with power outages sometimes. It may be in a display mode. If you havent already try unplugging the unit for a minute or two and plug it back in. This doesnt reset its programming try holding Energy Saver Key + Lighting Key for 8 seconds and let the unit run thru a self diagnstic test and hopefully it will reset. If neither works its going to have the main board replaced.
Posted on Jan 23, 2010
Testimonial: "It worked! Thank you so much!"
  • 1891 Answers
SOURCE: Maytag refrigerator isn't cold.
if freezer is working and ice mker is working . and fan / then only other is the damper in top center is not working . very common . mm
Posted on Apr 19, 2010
Testimonial: "Thank you. We will work on that and see what happens. "
toolkits
  • 1099 Answers
SOURCE: 27 cu. ft. samsung refrigerator, side by side with
Troubleshooting an Ice Maker that won't Make Ice
Troubleshooting an ice maker is very important if you have problems with it. If you are having problems making ice with your ice maker then this is a very serious issue which will need to correct. If you are suffering from problems with your ice maker then there are a few simple things that you can do to diagnose and correct the problem yourself.
Checking the LinesThe first thing that you should do is check the water supply lines to ensure that they are not blocked. Sometimes ice can block the lines which may mean that they need to be cleaned out.
If the fill tube is frozen then this might need to be defrosted so that you can use it again. If the tube is too badly damaged then it might need to be replaced.
Broken LinesIf the lines break or become damaged then they can prevent water from getting to the ice maker. In this case the lines will need to be replaced so that you can restore the functioning of your ice maker.
Not Connected to WaterIt's also worthwhile checking the connections between your freezer and the water lines. If your freezer is not connected to the water lines, or if the tap is turned off then this will cause the same problems. There will not be any water available to make into ice. This is a very easy problem to correct and shouldn't take long to identify.
If you are not able to get any water from your freezer either then this suggests it could be a problem with the water supply. You will probably hear a buzzing noise when you're trying to make ice, this means that the freezer is trying to pump water which isn't available.
ValvesThe valve which is connected to the tap could also be damaged or broken. Check the valve opens and closes correctly and consider replacing it if it is damaged.
Too WarmIf the freezer is set to a too warm temperature then this will also create problems with producing ice. You will also notice that this isn't keeping your food as long as it should do. To correct this problem you will need to change the thermostat on your freezer so that it is lower.
Checking the Bail WireThere is a bail wire inside the ice maker which will lift when the ice maker is full of ice. This is designed to prevent too much ice being produced. If the bail wire is stuck in the up position then this will be preventing ice production.
Check the position of the bail wire by locating it inside your freezer. The instruction manual should help you to locate this wire.
SolenoidUnplug the freezer and pull it out from the wall. The water will travel to a solenoid located at the back of your freezer before being sent to the ice maker. If the solenoid is not working or is not getting power then this could be a reason for concern. If you're not skilled at home electronics then you might want to hire a specialist to help compete this task for you
Good luck
Posted on Jul 14, 2010
Samsung french door refrigerator ice maker no dispenser defroster leaking water into bottom and produce drawers
If it is a frost free unit the water collects in a well at the compressor , there is a heater element in the well that boils off the water , this is were the fault is.
Jun 04, 2017 | Samsung RF217ACPN - 20 cu. ft. French Door...
My Samsung RF265ABWP French door refrigerator has suddenly stopped making ice. I hear the old familiar noise it used to make just before I heard the ice drop in the bucket, only no ice drops. It sounds...
Is it getting water? If not, Most likely water valve is faulty and not letting water through, or feed tube through back freezer wall to ice maker is frozen which would be caused by dripping valve. It's either the valve or the ice maker not sending voltage to valve.
Nov 12, 2017 | Samsung RF265AA Bottom Freezer French Door...
Went on vacation and shut water off in house. Came back from vacation and frig. stop making ice. What do I do?
fill tube is probably clogged with ice you will have to melt the ice in the tube that goes thru the back wall to the ice maker, if you shut off the water turn off the im too
Feb 21, 2011 | Samsung RF265AA Bottom Freezer French Door...
Samsung AW2-PJT RFG 297AA ....... Need to know which componets or relay boards would have burned out when 220 volts was applied to outlet while fridge was plugged in. 120 volts was restored to outlet but...
Remove the lower cover in rear of refrig ..the board sits in right hand corner..there are several screws to remove and the icemaker valve may have to be removed and then there is a large plastic housing that holds the board..hopefully, this is your problem
Jan 23, 2011 | Refrigerators
No ice coming out of my ice maker
did you turn the water on if so when you tightened the water line you might have tightened it to tight and crushed the water line
Apr 16, 2010 | Samsung RB2155 Bottom Freezer Refrigerator
Samsung Ice Maker--Ice block and now no water flow...
Wait a few hours before you jump to conclusions. All depends on the position of the cam.
Aug 23, 2017 | Samsung RF265AA Bottom Freezer French Door...
My icemaker in my large French door Samsung refrigerator takes forever to make more ice. Is there some way to increase ice production? It takes 2 to 3 days to fill up the ice bucket. There is nothing in...
Have a nice day...
Sep 08, 2009 | Samsung RF265AA Bottom Freezer French Door...
Samsung RFG297AA (285 cu ft) Bottom Freezer Commercial French Door Refrigerator Logo
115 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
