Question about Canon Cameras
I have a Canon Power Shoot A540. When I turn it on and get ready to take a picture I am getting a message "Memory Card Error". Wonder if you can help! Thank you. Bonnie Steele
    Brigadier General:
  • 11,967 Answers
It may just want you to format the card in the camera. This will erase it so download any pics you want to save first. Use a card reader if necessary.
Posted on Aug 31, 2010
When putting a Lexar Multi-Use 16 GB SDHC memory card in my Canon Powershot A540 I get Memory Card Error message as well Card Locked message. Have tried unlocking it by the slide on side of card, is t
It's a lost cause. The A540 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You need to stay with SD cards, 2GB and smaller.
Jan 03, 2013 | Canon PowerShot A540 Digital Camera
Window Vista not recognizing my Canon Power Shot A540 to download
I recommend getting a USB card reader for your memory card.
You should make sure that the camera is on for the transfer. If that doesn't work, try another USB input.
Nov 17, 2012 | Canon PowerShot A540 Digital Camera
When I install a new SD card in my Canon PowerShot A540 it displays Memory Card Error Card Locked. I have moved the tab on the card and it displays the message regardless if the card setting. What
it seems to be the memory card slot is damaged normally 9 contacts connect with MC if any of it doesn't contact, will not work, open and takeout card slot if the contact is bend align it to touch the MC's contacts.
Sep 02, 2017 | Canon PowerShot A540 Digital Camera
I have a Canon PowerShot A540 Digital Camera I got a new memory card it is a sandisk SDHC 8 GB but I am getting a memory card error message.... What can I do?
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Please note that your particular model camera can only use up to 2GB standard SD cards. These are relatively inexpensive these days, and may be purchased on Amazon if your local store no longer carries them. There are also other common causes if the above didn't help, with troubleshooting steps for this problemlisted here.
Oct 01, 2011 | Canon PowerShot A540 Digital Camera
Card locked error on screen card is unlocked and even new card gets same message
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out (sorry, an A540 can only use 2GB or less standard SD cards. These are very inexpensive these days, and are available on Amazon if your local store no longer carries them). There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Aug 17, 2011 | Canon PowerShot A540 Digital Camera
Hi, My canon PowerShot A540 camera gives an error " Card locked" Memory card error. I tried switching off the lock, but it didn't help. The card does not get recognized while inserting it in...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
You also mention recovering photos saved on the card. If you actually did take pictures with this card (assuming it's a 2GB or less standard SD card, as 4GB SDHC was not designed for your camera), you may be able to recover the photos using recovery software. See this other link.
Jun 10, 2011 | Canon PowerShot A540 Digital Camera
When I connect my Canon A540 to the computer, I get a message that says: "An error has occurred when attempting to import. Either the sourceis unavailable or the destinatkon is full or read only.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Dec 11, 2010 | Canon PowerShot A540 Digital Camera
Memory Card Error Card locked. I get the same
If you've already tried the lock/unlock switch on the side of the card, then see this link for additional troubleshooting tips for this problem.
May 16, 2010 | Canon PowerShot A540 Digital Camera
When i insert 4gb memory card into canon power shot s21s, camera is disabled. cannot take pictures
Your new 4GB memory card is the problem. The card would likely be an SDHC card (look on its front cover). Your A540 camera was designed well before the SDHC format came out, and your camera will not recognize it. Your camera can only use standard SD cards (2GB or less). Here's some from Amazon.
Feb 14, 2010 | Canon PowerShot A540 Digital Camera
Incompatible JPEG format
right click on one image on the computer >> properties >>open with >> choose windows picture and fax viewer >>click ok
Jul 17, 2008 | Canon PowerShot A540 Digital Camera
Cameras Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
