Question about Troy-Bilt® Briggs and Stratton Chipper
I have a troybilt riding lawn mower that gas seems to be going into the oil..what could this mean
    President:
  • Troy Master
  • 1,545 Answers
This is serious. Don't use the mower till it is fixed. Probably the carburetor has malfuntioned and may need to be removed, disassembled and possibly rebuilt. Major flooding is ocurring somehow either by the carb or a mechanical failure of the engine.
Posted on Aug 31, 2010
Troy bilt troubleshooting
what are you trying to troubleshoot? heres the troybilt link to get you started
http://www.troybilt.com/equipment/troybilt/lawn-mowers/lawn-mowers?facet=cas_f9_ntk_cs%253A%2522Zero%2bTurn%2bTractor%2522&sortBy=3?cm_mmc=Google-_-Mowers-_-Zero%20Turn-_-Sponsored&gclid=CjwKEAjwi6OeBRCCrZqp-qaQhhISJACrfbtAq_Hepy9R8IgJYw_E9HkmY0pum-PDxyoqjOrFfOWq-hoCAknw_wcB
Jul 17, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
HOW MUCH OIL DOES A TROY 174HP MOWER TAKE
http://www.troybilt.com/equipment/troybilt/lawn-mowers/tb2654-garden-tractor-tb2654?cm_mmc=Google-_-PLA-_-TroyBilt-_-17AR94KK066&gclid=CKCS
May 09, 2014 | Troy Garden
Troy bilt self propelled mower overheats
Check oil level . Dump out old oil and fill with new 30w oil.
Sep 24, 2012 | Troy Bilt 5.5hp Self Propelled Mower
Troybilt push mower will not start
Might be bad gas. Empty tank refill with fresh gas with Stabile. Might have to remove carb bowl clean and reinstall. Flush out tank with a little gas before refilling, disconnect fuel line to flush.
Aug 24, 2012 | Troy Garden
Newly purchased Troybilt snowblower. I don't know anything about these machines, but filled the oil tank and gas tank, started it up and it started but seems to be blowing lots of white smoke. Is this...
This is not normal. You either have overfilled it with oil (check the engine oil level when cold) or there is water in the fuel system. Hopefully no real damage has occured (engine) and you can rectify this situation. I recommend (using in cold weather) a multi-viscosity synthetic oil be used. Synthetic is far superior to regular oil.
Nov 29, 2010 | Troy Bilt 5.5hp Self Propelled Mower
My troybilt riding mower quits after 3-5 minutes of running. I can restart it but it then dies immediately. Suggestions?
remove the carberator bowl nut on the bottom side of the carb and empty out the gas from float then just put it back together there is debree or water in the float bowl.
Jul 14, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Help With Troybilt Ride On Lawn Tractor
check your crank case for fuel,
bowls stick open an fills it up
if this is the case , you can buy a plastic fuel cut valve from lawn mower shop
todays fuel isn't very good
also try sta-bil fuel coditioner
May 30, 2009 | Garden
Weird under load symptom briggs 17.5
a couple other checks would be to dump the carb resevoir where the float is, water under the float could be accumulated and closing the fuel off, due to density. out here on the farm we never use the gas to the last drop from the can. also the linkage between the motor fan blade, (govenor) might have been connected to the carb incorrectly. or a bad switch interlock on the mower blade.
some briggs motors are hooked wrong straight from the factory, where the throttle linkage is concerned. ( and the little spring is pretty hokey too)
May 16, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Gas/ oil mixture
If it is a riding lawn mower it is probably not a two cycle engine so there would not be a gas oil mixture. It must be a 5 horse power or higher so it would use straight gas. I hope this will help you. donnyb60
Mar 20, 2009 | Poulan Garden
Troy-Bilt® Briggs and Stratton Chipper  Logo
99 people viewed this question
Top Troy Heavy Machinery Experts
Matt Olenzek
Matt Olenzek
donald boissonneault
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Troy Heavy Machinery Expert? Answer questions, earn points and help others
