Question about Fujitsu Office Equipment & Supplies
What does the following message mean? 20208: compressor failed
  • 3,083 Answers
The video compressor is failing. Here is a suggestion for fixing the problem:
http://knowledgebase.kofax.com/faqsearch/results.aspx?QAID=10724
Here was what another person had to say about this:
http://forums.kofax.com/viewtopic.php?f=68&t=5962
Good luck, thanks for using FixYa, and hope this helps.
Posted on Aug 31, 2010
What does e1error code mean?
There are some thermal sensor in the inside unit and out door unit which is used to measure the Coolling and compressor heat. If any one of the sensor is faculty then that error message will appear.
If you wish to get some more details about air-conditioner repair then check the following link
http://electro-medical.blogspot.com/
Aug 21, 2016 | Heating & Cooling
What do it mean when compressor is not turning
It can mean many things, one the compressor is not getting any power, second the clutch assembly is failing. The AC relay or fuse is blown.
May 07, 2014 | 2005 Ford Crown Victoria
CO light is not lighting with a received call
While I do not see a programming guide for the lights on the unit, here is the programming guide where you can take a look yourself.
http://www.wedophones.com/Manuals/Panasonic/KX-TD%20208%20telephone%20system%20Additional%20Features%20update%20for%20version%203.pdf
Jan 21, 2014 | Panasonic KX T7436 Corded Phone KX-T7436
Lenovo 20208
Lenovo 20208 comes up as Lenovo B590
http://shop.lenovo.com/us/laptops/essential/b-series/b570
If this is, or is not correct; state back in a Comment.
Motherboard manual for a laptop?
Ummm,.............No
What information do you need?
Specifications?
Service Manual?
Have problems with the laptop, and want to know what electronic components may be involved?
Post back in a Comment.
Regards,
joecoolvette
Apr 01, 2013 | Lenovo Computers & Internet
Refrigerator has power but not cooling
A couple of possibilities: Coolant level has declined too far; compressor has failed, and finally, the defrost timer has failed. During the defrost cycle, the compressor is intentionally shut down and if the defrost timer has failed during the defrost cycle, the compressor will not be re-enabled.
You didn't include the model number so the following may not apply: The defrost timer is often located behind the lower grill of the unit. Remove the grill (often held by plastic tabs) and look for a small black box with a hole or a short protruding shaft. These often have a screwdriver slot to allow manual rotation in the event of a timer motor failure. If you find this, insert a flat-bladed screwdriver and rotate the shaft ~ 1/4 turn and wait to see if the compressor then starts up. If not, turn the shaft a bit further and wait again.
If the compressor does not start, either the relay that supplies AC to the compressor has failed or the compressor itself.
Sep 23, 2011 | Hotpoint Refrigerators
I keep getting the message Alignment Failed.
hello deer1626, if a printer gives you a message alignment failed that means your catridges are not properly installed try removing the catridges and fixing them back you will get a notification of aligning just follow the onscreen instructions and thats all
Jan 03, 2011 | HP Officejet Pro L7680 All-In-One Printer
HP8150- I keep getting an error message cartridge replacement failed. I put in new cartridges and one does not "snap" in however, it does go in and the top does " snap " down. Cartridges 95/99
I assume you mean the 8150 Photo Printer. That message usually means the cartridge is not making good electrical contact with the contacts on the printer.
Follow the instructions on this link.
Aug 23, 2009 | Office Equipment & Supplies
Fail to install avgwdsvc.exe
Probably the AVG program files are corrupted, please try to reinstall/download the latest AVG version thru this site www.filehippo.com. regards
May 28, 2009 | Polyview S17E 17" LCD Flat Panel Monitor
Freezer problem
Not sure of what cut out refers to. If you mean the power supply is tripped out after twenty secs hen I would say there is a fair chance of the compressor being down to earth (ie broken). If you mean that the compressor tries to run and then stops after twenty secs then there is a fair chance the compressor is stalled (ie broken). There is also a chance that the relay (starting device) may be at fault failing to start the compressor. If it is the relay then the cost may be around £70 if its the compressor then you are lookin at a couple of hundred pounds approx. The buzzing sound does sound like the compressor trying to run but stalled and unfortunately compressors have no real average anymore and are prone to fail whenever they choose to. Sorry to sound negative and hope this helps.
Sep 03, 2007 | Freezers
Open Questions:
211 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Tony
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
