Can't locate speakers
Sorry if this is not appropriate question for you, but I have searched 'high and low' for the compatable speakers for a monitor we recently purchased. Can you please assist. I am needing a description and a quote. I am hoping they mount directly to the monitor.
Thank you.
  • ccwater May 09, 2008
    I thought it was listed...
    Samsung
    Syncmaster 400PX
    40" monitor
  • Anonymous May 11, 2010
    Please tell us the monitor make and model numbers.
Greetings,
These are the speakers that are compatible with your monitor.
http://www.officedepot.com/ddSKU.do?level=SK&id=725849&cm_mmc=Froogle-_-Shopping%20Comp-_-Datafeed-_-Technology They will attach to the left and right sides of the monitor. Also I just wanted to say that is a beautiful screen.
Take Care,
-WN
Posted on May 09, 2008
Is my AOC 9170 monitor compatible with HP Pavillion 6523W Windows 7? Does this monitor have built in speakers?
I am not sure about the speakers. The best way to tell if it has speakers is if you can physically see them. They are usually located at the bottom of the monitor and they look like little screens on either side of it. If it doesn't have HDMI or a line in jack (speaker plug) that you can see then it won't have built in speakers for sure.
If the monitor has the right connections to plug into your HP computer, which it should. Then it will work with your computer. Your computer has both VGA and DVI monitor connections on it so either of these should work as long as your monitor has the connections (which it should have at least one).
Sep 13, 2011 | AOC Monitor
Are my tr-2810 tower speakers shielded? Will they ruin my television?
if you are using lcd monitor then it will not do any damage to it. however, if it is a crt type of monitor then yes it can or may damage the monitor. if the speakers do not that they are shielded then you should assume that they are not and should be placed away from the crt monitor because the speakers magnetic field will affect the crt magnetic filed used to display the picture on the screen. speakers with high magnetic fields and are unshielded should kept away from crt type monitors! lcd monitors do not use magnetic fields to bring a picture to the screen so it will not affect these types of monitors.
you nay also check your user's or owner's manual for more information on you speakers and maybe check any of the manufactures web site as well. but it better safe the sorry to keep the speakers away from the monitor in question.
Sep 01, 2011 | Theater Research TR-2810 Main / Stereo...
I can't find the location to plug the speakers in on my acer monitor.
is it an acer monitor or
Acer (90.00012.30B) Computer Speakers Reviews
are you sure they need to be connected to a monitor if they have a usb connection they will plug into a usb port or if they have plugs the speakers into the speaker outlet usually at the back of a computer then
control panel sounds and audio,volume,advanced,speakers select the appropriate speakers
hope this helps
Jun 25, 2011 | Acer 90.00012.30B Computer Speakers
I bought an hp 2211x monitor and a lenovo pc from office depot and everything seems to work except the audio. I checked everything and it says that the speakers or headphones are not plugged in. I have no...
It is possible they aren't compatible but it is more likely the outfit you bought has something missing.
Sometimes the speakers are integrated into the monitor but the connection to these is by a separate audio cable from the PC.
If the speakers aren't integrated into the monitor you will need a suitable active speaker system that should arrive with a power supply and all other leads ready wired and just need plugging into the PC.
Consulting the instruction manual is a good way of learning where to plug things in. Most conventional PCs have three jack sockets close together and some are usefully colour coded - One is audio out and another is audio in but I can't remember the third.
It is possible your new PC is entirely USB and has many USB sockets but few of the more familiar sockets. If that is the case you will need a pair of USB speakers.,,
I suggest you contact the supplier for advice...
Aug 11, 2017 | Office Depot Computers & Internet
How to change my display setting when my monitor sudden stops working at 1076x768 high resolution
uhh it obiously cant take that resolution maby it can try install a new driver if that does work sorry it can take that high of a resolution
Jan 12, 2011 | LG Studioworks 552V 15" CRT Monitor
Is samsung 920nw compatible for windows 7 ultimate?
No, according to Microsoft listing:
http://www.microsoft.com/windows/compatibility/windows-7/en-us/Search.aspx?l=en-us&type=Hardware&s=%20Samsung%20SyncMaster%20920NW&results=50
What it means is that you may not be able to set it to the native resolution for best pictures.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 21, 2010 | Samsung SyncMaster 920NW Monitor
Can someone tell me step by step, where is the microphone located on the Hanspree 20" flat panel LCD monitor? I can't find any info in the manual on this. I go on to Skype and my speakers work but not the...
Hannspree says they don't offer a 19" LCD with a built-in microphone. If there is one, I can't suggest you use it as noone would be able to understand you well.Their built-in speakers,also, are notorious for low power and poor, tinny sound. the addition of a USB or audio card compatible type headset is recommended for most voice applications, including Skype. Tigerdirect.com, overstock.com or walmart.com all have inexpensive headsets and stand alone mikes. Hope this helps some:)
Aug 20, 2010 | Hannspree 19" Widescreen LCD Flat Panel...
Can't get speakers to work.
Hi...
Mostly of the sound driver now are need a compatibility if your installed driver is not compatible it will affect the hardware. It's better that you will know the model of your motherboard, if you know the model you need to search the model and download the sound driver witch is compatible.
For now the all motherboard are High Definition Audio.
ICmanServer
Jul 30, 2009 | Ozaki DT-500 3-Piece Speaker System...
Low volume sound
I was afraid of that. The speaker system is only half in the monitor the other part(Amplifier section) was in your old computer. Here is a possible solution. Buy an external sound /speaker system. The amplifier comes with it and many can be had at a reasonable cost at **** places as  Walmart , target ,etc. Sorry. but the speakers on  your monitor, I believe ,  will not work with you new computer. Sorry.
Mar 09, 2009 | HP Compaq WF1907 Monitor
Monitor making humming noise
First try moving speakers away from monitor a bit. Some speakers magnets actually reduce the life span off monitor. I hope I am wrong but usually a high pitch whine is the High voltage Transformer. Costs more than the monitor. All you can do is continue use till it goes. Speakers usually deteriorate the tube itself. HVT are just one of those parts that go due to use. Hope it gives you more enjoyment before it goes. Good luck and try to have a good day.
Jan 31, 2009 | KDS Visual Sensations 190i 19" CRT Monitor
49 people viewed this question
 Grubhead
Grubhead
