Question about Viking VESC306-4B Electric Kitchen Range
Need parts for my VESC306-4BSS and don't know where to find them need left rear element right front infinite switch and left rear dual element
Could this be a User Interface,Board 316239500 part problem? or a Electronic Control Board part problem?
Normally, the E.O.C. (electronic oven control) only controls power the ehe bake/broil side for the oven. Doesn't control power to the element. If you have already replaced the infinite switch to that eye, the element itself could be faulty. There is a sensor inside the element that is supposed to communicate with the infinite switch to determine the proper cycling temp for what you selected.
Jan 31, 2013 | Frigidaire GLEF396 Electric Kitchen Range
Don't know radio connector color code
This should help.
1987-88 Plymouth Voyager Stereo Wiring
Constant 12V+
Red
Switched 12V+
Red/White
Ground
Ground/Back Strap
Illumination
n/a
Dimmer
Orange/White
Antenna Trigger
Yellow
Antenna
Right Front
Front Speakers
5 1/4" Dash
Left Front (+)
Green
Left Front (-)
Green/Yellow
Right Front (+)
Purple
Right Front (-)
Purple/Yellow
Rear Speakers
6" x 9" Tail Gate
Left Rear (+)
Brown
Left Rear (-)
Brown/Yellow
Right Rear (+)
Blue/Red
Right Rear (-)
Blue/White
Sep 20, 2011 | 1987 Plymouth Voyager
Wiring diagrams for clarion dxz535 car stereo
Here's how it goes:
Speaker wires:
grey=right front pos.
grey/black=right front neg.
white=left front pos.
white/black=left front neg.
violet=right rear pos.
violet/black=right rear neg.
green=left rear pos.
green/black=left rear neg.
red=12 volt switched power source
yellow=12 volt constant power source (direct to battery)
black=chassis ground
orange/white=illumination (switched source,not to head light switch)
blue/white=amp turn on lead (to remote turn on lead of amp)
blue=auto antenna (switched power source)
brown=phone mute lead (to cell phone mute lead)
RCA connector leads:
grey lead:
red=right front
white=left front
black lead:
red=right rear/right rear subwoofer
white=left rear/left rear subwoofer
(connect to external amp)
red lead:
red=right aux input
white=left aux input
(connect to external unit)
green lead:
red=right dual zone output
white=left dual zone output
(connect to wireless head phones)
That should be all there is. on the yellow that goes direct to the battery you need to use an inline fuse holder with 30 amp fuse.
Sep 26, 2010 | Car Audio & Video
Control for dual element has to be wiggled just so -so to shut element off, what do I need to fix it? Heats perfectly, shutting it off is my only problem.
The control you're wiggling (infinite switch)needs replacement. Model# and the position of the dual element (right or left, rear or front) is needed to get the part number.
Mar 03, 2010 | Cooktops
Viking 30" electric free-standing glass-top range Model VESC-3064BSS :My left rear dual element will not turn on now with its own infinite switch, unless the left front element is turned on, and then the...
sounds like bad inf sw / as one feeds the other or ist been miss wired .. I would replace the the left front first and left rear if needed .. .. mm
Dec 07, 2009 | Dryers
Hi there, we have replaced dual infinite switch on our jennair range and cannot figure out the correct wiring for the new 12002125 switch....can you help...???
Follow the instructions below from partselect:
Attach the black wire(s) from the old switch (terminal 2) to the new switch terminal P1. Also attach the jumper cable to P1 and "jump" it to S1.
Attach the orange wire (old switch terminal 5) to S2
Attach the yellow wire (old switch terminal 4) to 4a
Attach the tan/(white?) wire (old switch terminal 3) to terminal 4 on the new switch
Attach the single red wire from the right front element to terminal 2 on the new switch.
Attach the 'compound' red wires (the ones that come from the left rear/outlet connection and is also attached to the right rear switch) to terminal P2 on the new switch.
There is no need to separate the compound red wires.
Best regards.
G.
May 28, 2009 | Kitchen Ranges
Replacing a radiant element on a maytag glass top range I'm having strange problems with the two right elements of my MER5770 The front larger dual element will only operate at high heat. When turning on...
yea sounds like an issue for sure, nut not with the element but hte switches instead, theres a short in one or the other( most likely the dual switch) i wouls reccomend replacing both the switches, the elemenst should be fine.
May 24, 2008 | Maytag MER5770 Electric Kitchen Range
Knob is popping
Mcrib, sounds like one of your infinite switches is going bad. This is not a hard fix, you can get to them by removing the back panel behind the control panel. I would give you the part number but I would need the whole model number and whether it was a left or right front or rear burner causing the problem. Catriver...post back
Aug 15, 2006 | Whirlpool RF378 Electric Kitchen Range
Kitchen Ranges Logo
97 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
