Question about Eliminator MotoMaster Mobile Power Inverter 700w
Is there a manual reset button on the 700w eliminator inverter?
Why doesn't it charge?
Carolyn, These power boxes were not made to last, the batteries inside are probably bad now, if still under any warranty return for exchange or hopefully refund.
Feb 09, 2016 | Eliminator MotoMaster Mobile Power...
What does ocp mean on the 3000 motomaster power inverter
Unit is overheating.
1. Check fans are running. and unit is in a cool place where air can flow freely.
2. If fans not working try using an external fan to see if the OCP error goes way.
Reduce the load on the outlets (Disconnect some stuff i possible)
Apr 04, 2014 | Eliminator MotoMaster Mobile Power...
Motomaster eliminator 2 in 1 spotlight/lantern power
I am looking for a charging cord...I moved and haven't seen it in a while. Is there somewhere i could buy one.
Dec 02, 2013 | Eliminator MotoMaster Mobile Power...
My 3000 watt inverter says "lup" on the display
This question is solved in detail on a different page here on Fixya by user Pierre Curtis in detail. It's very well written. Rather than repeat, just click this link:
http://www.fixya.com/support/t26322938-3000_watt_eliminator_olp_lup_codes_any 3000 watt eliminator with OLP and LUP CODES any Ideas
Nov 09, 2013 | Eliminator MotoMaster Mobile Power...
My motormaster eliminator mobile power pack 700A just started beeping. What is wrong with it?
if there is a car fuse, under the cover, remove it.
most of the time, it is only use to activate the LOW Battery alarm.
Put the fuse back, when fully charge.
Jul 10, 2011 | Eliminator MotoMaster Mobile Power...
Have an eliminator intelligent battery charger model CT-1200A 11-1513-8. Can this be used to keep a car battery charged for a period of say 3 months while car is not being used. I have this same question...
· Automatically switches from full charge to maintenance mode to maintain batteries during prolonged periods of storage without overcharging or damaging the battery
Nov 27, 2010 | Eliminator MotoMaster Mobile Power...
Can i run a camper off a power inverter
A 12 volt camper can be run off an inverter if the inverter has the capacity. The camper must be 12 volt right, just bulbs and such?
Jun 18, 2010 | Eliminator MotoMaster Mobile Power...
Hi; I have a 1750w eliminator but no fitting instuctions. is it just a case of fitting it straight to the battery . is it as simple as that ? what if the truck has 4 batteries how do i know which to...
Sounds like your a truck driver. Anyways you would hook up the ground to the negative and the hot to the positive side. The 4 batteries are in a series so just pick a negative and positive. I hope this has helped, please give a rating on the answer. Good Luck and have a great weekend.
Apr 02, 2010 | Eliminator MotoMaster Mobile Power...
Lost AC charger and lighter adapter - need replacements
Although the MotoMasters are quite popular and are excellent products in most folk's opinions, parts are quite difficult to find. Complete units are in abundance.
Your charger doesn't have to be branded MotoMaster. And charger of approximately 500 to 750 mA and approximately 14 volts will work nicely.
From time to time Canadian Tire have some parts or open box sales. You might check with them. Hope this helps!
Sirwriter
Nov 06, 2009 | Eliminator MotoMaster Mobile Power...
Eliminator MotoMaster Mobile Power Inverter 700w Logo
142 people viewed this question
Top Eliminator Electronics - Others Experts
ottworld5982
Mark Magill
Mark Magill
Tom Chichester
Are you an Eliminator Electronics - Other Expert? Answer questions, earn points and help others
