Question about GE Profile Arctica 25.4 Cubic Feet Side-By-Side Refrigerator With Dispenser PSS25MGMWW
I have a GE Arctica Side by side and water is leaking out from under the freezer side of it? The ice dispenser and water dispenser are fine, but water is leaking a big puddle out of the bottom. No water inside freezer. What should I do?
  • damirkhan Sep 01, 2010
    OK, I did that and it drained fine. I have isolated the problem. On the left hand side on the back of the refrigerator there is a little blue water reservoir or tube that leads to a piece that has a red and blue connection on the top. In the bottom of that connector piece there are two pin holes from corrosion. I'm a female so I really have no idea what to call that piece to order a new one. Is this something that I can replace on my own? What do I call that piece?
  • 4,070 Answers
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the back of the freezer.
Posted on Aug 31, 2010
GE Profile Arctica ice dispenser switch quits working
I came across this problem recently , and found the main control board was bad . Check this site first , to see if it can be covered under warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
It was covered under warranty , at the previous customers residence .
Nov 20, 2009 | GE Profile¿ Arctica® Energy...
GE Profile Arctica PSS25SGNA BS Icemaker is not working seems to be filling with water but no ice.
The water dispenser and ice maker side run separate sides of the water control valve. Fill ice maker with tap water and let it freeze. If it dumps the ice then does not refill then the water control valve is the problem. I will be back soon with a photo and some links, Thanks, Sea Breeze
Nov 18, 2009 | GE Profile Arctica Stainless Steel Top...
My ice maker will not work, Ge profile Arctica.
Here you go...my dad had the same issues...Good Luck!
http://www.youtube.com/watch?v=sW2yqQjEcLI&list=HL1329704348&feature=mh_lolz
Jun 23, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Not getting water from dispenser in door
The connector that is leaking is bad causing tubing to come out and leak. The reason it won't flow is it is iced up inside of the door and no, unfortunately, you can't disassemble the door to get to it. It requires a door replacement. The connector is part number WR02X10471 from www.geappliances.com or GE Factory Service Parts at 1-800-626-2002
Dec 20, 2008 | GE Profile¿ Arctica® Energy...
GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Apr 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
103 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
