Question about Sony PS2 Dual Shock 2 Controller (PrePlayed) (PS2PRSODUSH2)
Newbie here. Is there somewhere I can see what button is number 1, what button is number 6, and so on?
  • phillippierc Aug 31, 2010
    Thanks so much for the quick response, but I guess I am a little dense. You lost me.
    I have 2 buttons on the left on the controller that face the TV, and two on the right side that face the TV. The top 1 on each side has a 1 on it, and a 2 on the bottom. Can you first tell me what they are ( I guess what is L-1, what is L-2, what is L-3, what is L-4.
    Then I have the little right/left/up/down arrow buttons on the left of the controller. Do they have numbers associated with them, and if so, what are the numbers?
    Finally we have the four buttons with symbols on the right. What is the one with the button number for the red square, the number for the green triangle, the number for the red circle, and the number for the purple X.
    You know, it is amazing that I have been searching for an hour, and can not find one site that tells me this. Yet, I have games that say "push button 12 to crouch", and I have no idea where the stupid number 12 button is !!!!
    Then finally, your four buttons on the right
    Let me reword this better
    Thanks so much for the quick response, but I guess I am a little dense. You lost me. I have 2 buttons on the left on the controller that face the TV, and two on the right side that face the TV. The top 1 on each side has a 1 on it, and a 2 on the bottom. Can you first tell me what they are ( I guess what is L-1, what is L-2, what is L-1, what is L-2.Then I have the little right/left/up/down arrow buttons on the left of the controller. Do they have numbers associated with them, and if so, what are the numbers? Finally we have the four buttons with symbols on the right. What is the one with the button number for the red square, the number for the green triangle, the number for the red circle, and the number for the purple X. You know, it is amazing that I have been searching for an hour, and can not find one site that tells me this. Yet, I have games that say "push button 12 to crouch", and I have no idea where the stupid number 12 button is !!!!
  • 864 Answers
The left button on the left side is 1 lower key is 2 right key is 3 top key is 4 then it goes 5 and 6 for l1 and r1 7-8 for l2 and r2 9-10 for select and start 11-12 for the l3 - r3 This was found just testing my own controller so i can assume it is the same for you. Thanks, Midwest-tek
Posted on Aug 31, 2010
  • Nathan Ayers
    Nathan Ayers Aug 31, 2010
    ok firs thte buttons on the top of the controller that say 1 and 2 on the left side near the d pad are l1 and l2, l1 being at the top and l2 on the bottom. On the top on the right side the buttons that say 1 and 2 are r1 and r2 which stand for right 1 right 2. Sometimes they will be called Right bumper 1 and right bumper 2 this also applys with l1 and l2. Now the x, square, circle and triangle. Are all standard buttons as on any game system. The buttons in the middle between the directional pad on the left and the x, [ ], /\,0 are the select and start button. Select is on the left and start is on the right. The 2 joysticks are called dual analog sticks. The l3 and r3 are when you click the left or right thumbstick.
Why is it that All the numbers are not responding except 1 2 and ?
TI 84 Plus Keypad not functioning - Cemetech ' Forum ' Calculator ...
www.cemetech.net > ... > Calculator Hardware
Mar 24, 2013 - Gryphon; Newbie (Posts: 2); Newbie ... My TI84+ will turn on when the on button is pressed, but no other ... i had the same problems but i had a problem with the os maby you can send a new os. at my calc is now all working Very Happy. new projekts (basic): c-compiler 1% / mylib 3% / ultimative gaming lib ...
HP 12c Calculator - Resetting the Calculator - HP Customer ...
support.hp.com/us-en/document/bpia5202
Sometimes a calculator will lock up or will not respond correctly. ... With thiscalculator, there are two options for draining the capacitor. The option to use is ... A paperclip reset can be performed on all HP 12C calculators with serial numbers before CN11500001. This will ... These calculators will have one CR2032 battery.
[PDF]Using the Canon Printing Calculator - Gallery Los Olivos
www.gallerylosolivos.com/Using-Calculator.pdf
Jan 31, 2016 | Office Equipment & Supplies
I have a 16 port kvm over ip switch that i bought at an auction that i need login info for, the mac code of the switch is 00:0D:5D:00:4D:96, inside it has what appears to be a plug in board with a pro
THere should be a 'model number' or part number somewhere on unit. Find that and post here or even better, just google it. Find a user manual which should contain access info.
Jan 16, 2015 | Advance Computers & Internet
Bushnell Telescope 78-4678
A telescope like that has a very narrow depth-of-field, so you need to focus very, very slowly to be able to see any image. Try focusing on something bigger (like a spot on the moon) and adjust the crosshair accordingly. The two eyepieces gives different magnification.
Jun 30, 2010 | Bushnell 675x5 EQ Reflector Telescope
Newbie on this I added MAC adress
Reset the router and start all again. look for a little hole and in the hole should be the reset button, with power off, reset it and do it all again.. this time properly..
get your manual for a how to do it below. http://www.retrevo.com/samples/Zhone-Router-manuals.html
Mar 06, 2010 | Zhone (6218-I2-200) Router
Can not view through theLCD while taking pictures
No, you are not missing a button. The D60 does not offer 'live view' like the compact digital cameras.
Gizmodo
Apr 14, 2009 | Nikon D60 Digital Camera
Nvidia GeForce 9800GT has an internal hdmi audio cable --
hello, i recently helped another person with similar connection issue with nvidia graphics card. he said it needed to be on the 2 pin, spdif connector on the motherboard,near the audio chip-. i have seen this connection in between pci slots also,. not all mainboards have this, so i hope you find it! best of luck!
Mar 25, 2009 | HP Computers & Internet
Starview codes
To enter the "secret menu" on Starview press the menu button on your remote, ignore the menu and press 1 5 7 0
Jun 09, 2008 | StarTech.com StarView SV211K 2-port KVM...
Ws-65315 won't turn on
Need to know more, 1-2 is no error code, you say will not turn on, do it has led light on or do you hear sound in set like high voltage? Any lights blinking? Or just completely dead, like fuse blown?
Mar 24, 2008 | Mitsubishi WS-65315 65" Rear Projection...
Restting the phone handset number
I would suspect that you need to de-register both 3 and 4 at the same time before re-registering them. This probably will not work if the base unit still thinks phone number 2 is out there somewhere. It would need to be de-registered as well for the others to move up a notch. I did read the process for de-registering somewhere on the web, don't remember where, just that it involves removing/installing the battery and punching some buttons.
Jul 28, 2007 | Panasonic KX TG1000N Cordless Phone
Need help to unlock the AF-Point
Below the thumb pad there is a lock switch. Make sure it's in the upper position then tap the shutter button. You should now be able to select your focus point. When in doubt press and hold the "BKT" and the "Meter" buttons simultaneously for 3 seconds. Both buttons have a green dot next to them. This will reset your camera to default settings.
Sep 19, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Sony PS2 Dual Shock 2 Controller (PrePlayed) (PS2PRSODUSH2) Logo
103 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
