Question about Texas Instruments TI-30XA Calculator
How do you find 10 to the 10th power on calculator
2 to the 10th power
Posted on May 22, 2012
I have Texas Instruments 84 plus, where is the button
Posted on Jan 25, 2014
  • Texas Instru... Master
  • 7,993 Answers
Use the key marked EE
Example To enter 6.22 x10^7 you type in 6.22 then press the EE key then type in the exponent 7. Finally press the = key. If the exponent is negative, press the change sign key [ -] after the EE key then the value of the exponent
EXAMPLE; enter 52.76 x10^(-3)
52.76 [EE] [ -] 3 [=]
Posted on Sep 01, 2010
  • k24674 Sep 01, 2010
    To enter 10 to power n where n is any number, you type 1 [EE] n. When yous use the EE key never type 10 before. The 10 is already taken care of. EE key is a short cut for time 10 to power.
I am trying to calculate powers with my Texas Instruments BA ii plus, but big powers such as ^360 gives me an error msg. How can I solve this problem? Thanks!
Break the problem up into smaller pieces.
There's a limit to how big a number the calculator can represent. Numbers as large as 10 times 10 to the 100 simply can't fit into the calculator. For really large numbers, calculate the mantissa and the exponent (power) separately.
For example, to calculate 2^360, first calculate 2^300: press 2 ^ 3 0 0 = and see 2.037036*10^90. Divide by 10^90 (and remember the 90): / 1 0 y^x 9 0 = and see 2.04. Multiply by 2^60: * 2 ^ 6 0 = and see 2.348543*10^18. Multiply that by the 10^90 we took out earlier by adding exponents and write down 2.348543*10^108. That number is too large to fit into the calculator but we got it by calculating the 2.348543 and the 108 separately.
Oct 25, 2013 | Texas Instruments BA-II Plus Calculator
How to turn off calculator
Most calculators have a key sequence to turn off power. The key may be dedicated (one function) or it can be activated by pressing SHIFT or 2nd first. For a Casio scientific calculator, press SHIFT followed by AC (All clear). Some solar powered calculators do not have a key to power off but the calculator will turn itself OFF after a moment of inactivity.
Jun 03, 2012 | Office Equipment & Supplies
How to work to the 2nd and 3rd powers
Most calculators have a power key. It may be marked "^" or "x-superscript-y" or similar. This key can be used for any power, not just 2 and 3.
Many calculators also have a dedicated 2nd power key, typically marked "x-superscript-2". Some calculators also have a 3rd power key.
Nov 12, 2011 | Office Equipment & Supplies
How do you calculate a exponent thats a fraction? (24/76) with a power of 1/7?
Enclose the base 24/76 with parentheses, and do the same for the exponent 1/7
(24/76)^(1/7). The caret ^ represents the general power key. On your calculator that key may be marked X to power y or Y to power x.
Jul 14, 2011 | Sentry CA 756 Calculator
How can I calculate x to the power n. I know that x to the power 2 and x to the power 3 buttons are given on the calculator but dont know how to calculate x to the power n. e.g. 5 to the power 8
Yype in x, then press the button on the top full row that is the fourth from the left. (It should look like a right angle facing up) Then type in n.
Jun 01, 2011 | Casio FX570MS Scientific Calculator
I want to calculate powers on my calculator but am unsure what buttons to press
You have two buttons to calculate powers: The [x^2] calculates the square of a number while the [caret ^] key allows you to calculate any power, be it with integer, fraction or negative exponent.
Both keys are next to one another, one below OPTN and the other below the VARS key.
To calculate roots, you have the square root [SHIFT][x^2] the xroot key [SHIFT] [caret ^] , the CUBE root [SHIFT] [(] , and the inverse key [SHIFT][).
Feb 28, 2011 | Casio FX9750GII Graphic Calculator
My HP 10s Scientific calculator does not switch on what could be the problem, is it maby because the calculator was left in a drawer and now the batery ran flat hou can I charge it on the solar power...
You can't charge the calculator off the solar power panel. The solar power panel merely conserves battery power when using the calculator in a bright environment. Try putting in a new battery and see whether the calculator turns on.
Aug 25, 2010 | HP 10s Scientific Calculator
How do you calculate for example 0.90 to the 9th power?
Once you know how to raise a number to a power you know how to calculate any power. It is all done the same way: Use the caret ^ key.
0.9^9 =0.387420489
Hope it helps.
Oct 21, 2009 | Casio FX-300MS Calculator
How do you calculate "to the power of" calculations? Thanks
Use the y^x function (2ndF DEPR). For example, to calculate 2 to the 3 power, press 2 2ndF DEPR 3 = .
Apr 03, 2009 | Sharp EL-738 Scientific Calculator
Casio calculator fc-100v, to the power of?
Hello
To calculate a number to an arbitrary power you use the button labeled ^ .
If you want the cube of 2 your enter
[2][^][3] will give you 8. If your exponent is negative use the sign change key (-) and close the negative exponent between parentheses : for exemple the sequence to compute 2 to power of negative 5 is as follows
2[^] [(] 5 [(-)] [)] which means you enter the value of the exponent before the change sign (-). If you use the big MINUS sign you will get a syntax error.
Hope it helps.
Aug 29, 2008 | Casio FC-200V Scientific Calculator
Texas Instruments TI-30XA Calculator Logo
2,238 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
