I need a new power cable for my tv could you tell me where i can buy one please
    President:
  • 2,712 Answers
Http://www.electronix.com/
http://www.chsinteractive.co.uk/manufacturer_replacement_parts/
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 09, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
    Brigadier General:
  • 6,966 Answers
Power cords are often make & model specific. Pls post back with the brand & model of your TV.
Alternately, most electronics parts stores carry various power cords, perhaps you can try there. A lot of current TVs are using an IEC320C13 to NEMA 5-15P. It is the same type of AC power cord with those used by computers. Of course the plug itself would have to conform with your country's electrical code.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
NO POWER, NO NOISE OR CLICKS, JUST NO RED LIGHT OR POWER TO THE TV. WHAT IS THE PROBLEM?
Hi, It is means your TV is dying. Please get it repaired at tv repair shop or invest for new LED TV
Jan 31, 2011 | Mitsubishi WD-73C9 73" DLP TV
I heard a pop in the TV and then the screen went red. I can still hear it and watch it but everything is red. Is it a bulb that needs replacing? If not, what is it? Can I do it myself or will I have to...
Several failures can cause a red picture but it sounds like if you are connected from the source with component video cables(red,blue,green)you may just have a bad cable,but you may have had a blue and/ or green projection gun failure,which would cause the red gun to over power the other colors(blue/green), if this is the case definently not worth the cost to repair, you have to replace all three guns at the same time costing $500+ to repair, invest that towards a nice new LCD panel TV. Good luck !
Nov 26, 2009 | Akai PT5492S 54" Rear Projection...
Have a samsung projection hd tv monitor 1080i auto perfect focus tv....that's what it says on the tv front. my grandson came by and he's 1 and pushed the video/tv button, now i tried to turn my tv on and...
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Sep 13, 2009 | Samsung HCN4226W 42" Rear Projection...
Tv wont stay powered up. turns off after 15 seconds
Hi
This issue occurs due to a faulty ballast or due to overheating inside the TV. You'll need to check for swollen capacitors on the TV power supply board and also would need to check if the cooling fans are working fine.
Please tell me the model and ,make of your TV si that i can tell you where to buy the parts and also provide you details regarding the replacement.
Please revert for further assistance.
Thanks
Rylee
Jul 26, 2009 | Televison & Video
Tv goes off, then comes on, and volume goes to max
OMG! Verizon Fios at it again with changing boxes! Well let me tell you if you do not loose signal on a DVD using these same inputs ITS NOT YOUR TV!
Whats going on is further into Verizon system you loosing the signal from the VDSL slam outside in the pill box. This thing will need to be replaced and they are going to blame your TV until you just give up and buy a new TV only to figure out its not your TV.
1. Call them back
2. tell them to check there network
3. if that dont work tell them to check it again
4. if you have HDMI use that instead of the scart connections.
I hope you have luck with Verizon Fios there internet rules but there TV service is sub par!
Thanks
rulds2008
Jul 17, 2009 | Mitsubishi WD-52525 52" Rear Projection...
WHEN I TURN TV ON IN FRONT OF TV IT TURNS ON AND OFF AGAIN
the remote and buttons use one IC to control,
tuning, remote,
open your tv and check the common IC and change it okey
Jan 12, 2009 | Philips 50P8341 50" Rear Projection...
I pulled the tv by the cable cord and broke the metal part.
this metal can rectangular component? this is the tuner module for the tv the device that seprates the signals that come into you tv into the channels you watch. Union electronics, partsstore.com are some places you can get tunner
Nov 19, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Black Screen VERY loud noise
Samsung color wheel fix
http://www.jaGet a new cable if everything else works that is your problem
Oct 14, 2007 | Samsung HLN5065W 50" Rear Projection...
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Electro Med Services...
