Question about Frigidaire FRS23R4A Side by Side Refrigerator
REFRIGERATOR AND FREEZER IS WARM. I HAVE UNPLUGGED THE UNIT AND IT STILL RUNS WARM AND DOESNT MAKE ICE
  • Frigidaire Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 31, 2010
Testimonial: "thanks a lot "
Why do freezer coils ice up on my Stainless Steel Whirlpool refrigerator (model GB2SHDXTS)?
On your model your cntrl board has a relay that can stick causing the compressor to always run even when the unit is turned off or in defrost. turn the fridge off, move the temp of the freezer to it's warmest setting and it should display a line in the freezer and fridge temp display. listen to hear if the compressor is running in back of the unit. if it is you need part number: 12868513
Mar 15, 2013 | Whirlpool Refrigerators
Unit is about 10 years old, bought new from Lowes. When I open the doors the bar or middle frame is warm to hot. Now the freezer and refrigerator is not cold. Ice started to melt down so I removed the ice...
I suspect the warm to hot is from a heater that keeps moisture from from condensing on that bar. you don't notice it when the unit is working properly. Make sure your condenser fan is running and that condenser is clean. You may have a compressor that is failing
Jun 23, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Uplug to clean now it is staying warm
Hi!!
If you have ice build up on the evaporator (located in the freezer) unplug fridge and melt ice using a heat gun or hair dryer to speed up the process. Taking the back cover will also help. (If you don't feel comfortable doing it, don't do it.)
And don't worry, it is very common to change temp. settings when cleaning fridge. Check settings and restart unit.
Don't forget to rate this answer, GOOD LUCK
Apr 16, 2010 | Kenmore 57029 Side by Side Refrigerator
The refrigerator is prety warm and the ice maker
Sounds like a defrost problem. Is there any frost is the freezer? Do you hear a fan in the freezer? Does the fan and compressor run on the bottom? If the fan doesnt run then the compressor will go out on overload.
Aug 14, 2009 | Refrigerators
Freezer works refrigerator warm
Sounds like the FF(freezer fan) is wearing out this fan supplies the circulation for both the freezer and the refrigerator, when this fan motor starts to wear out it does not produce enough force to circulate air thru the freezer and refrigerator causing the area around the fan to ice up. The immediate solution is to unplug the unit for around four hours or use a portable hair dryer to melt the ice around the fan, but be very careful not to melt the plastic. That is why it is better to let the ice melt on its own by unplugging the unit. The minimum cost to repair/replace this fan assemble is around $300.00
Jul 11, 2009 | Refrigerators
Compressor runs, very little cooling, internal fan not running
You will need to unplug refrigerator and open plane inside freezer to see if fan is stuck or burned out. If freezer is frozen over with ice you will need to warm the ice for removal. Let me know, when you are ready, Sea Breeze
Mar 22, 2009 | KitchenAid KTRP22EK Top Freezer...
My refrigerator is 60 degrees and my freezer is hovering around 25 degrees
Seems to me that your defrosting timer is not working.When defrosting is not working unit will collect ice on element(Hidden)Could also be fan inside refrigerator which is not working properly.You need a repairman.Jan
Feb 02, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Amana refrigerator warm
Chances are if they are getting cool but not cold-
1) the evaporator fan in the freezer is not running
2) Defrost heater has failed
3) Defrost sensor has failed
4) Defrost timer/refrigerator control has failed.
Check for ice build-up on the back wall of the freezer. If there is ice, unplug or turn the unit off for 6-8 hours with the doors open (put any food in a cooler with ice to maintain). Note water may come out of the refrigerator.
Plug the unit back in or turn it back on, close the doors, and check temperature after a couple of hours of operation. If all OK, you will need to have the above tested, or, if you know how to use a multimeter and can read a schematic/wiring diagram, I can instruct you on how to check the above.
Jan 20, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Warm fridge
how is the freezer side check theese and get back to me hold the rating till we are done is the freezer fan running as the freezer cools both sides is there heavy frost on the back wall of the freezer down toward the bottom is the compressor running is the fan that cools the compressor running are the coils underneath the unit clean is the ice cream to soft milk too warm
Mar 02, 2008 | Amana ASD 2624 Side by Side Refrigerator
Frigidaire FRS23R4A Side by Side Refrigerator Logo
396 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
