Question about Frigidaire Refrigerators
Have 2007 frigidaire SxS model FRS3R4EQA serial 4A70818174 control adaptive defrost timer went out this was under orig part 241736601 this was factory replaced by part 241508001 when this part is placed in unit, all power goes off - compressor, light in frig, etc. have put in 2 diff. parts and have 3rd part in hand, all results the same. What do you think is the problem?
    President:
  • 3,773 Answers
You may have a bad defrost heater (around cold coils in freezer)
Which is shorting out the card. or some other short.
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 31, 2010
How do i diagnose the damper assy 241736601
Well that part number you provided is not for a damper assembly that is for a defrost control electronic. the defrost control is usually controlled electronically by something called a thermistor and that thermistor could be defect what is the model number of your refrigerator?
Appliance 911 Sea Breeze
Nov 18, 2015 | Frigidaire Refrigerators
Location of defrost timer on frigidaire model lfus2613f3
Hello Friend, thank you for allowing me to assist you!
It appears that the defrost timer of your Frigidaire refrigerator (LFUS2613F3) uses the main control board to energize defrost. The defrost timer is located at the front of the control console in the fresh food compartment (display that controls all functions). I do hope this information proves to be helpful! - Z
Jun 04, 2014 | Frigidaire FRS26KR4A Side by Side...
Where is defrost timer location on fridgedaire mod # ED25DQXVN00
Your mechanical defrost clock timer is located in the control panel where the rotary knobs are for the ED25 model given which is a Whirlpool SxS, For the Frigidaire Mod FRS, your defrost control will most likely be located in the long housing running down the center wall (front to back) of the fridge near the outlet vent, this is an electronic adaptive defrost control. Pleazer Appliance...
Apr 18, 2014 | Frigidaire FRS26KR4A Side by Side...
Location of defrost timmer
The defrost timer on your model is inside the fresh food compartment and behind the controls. Just above the top shelf. Click Here=> FRS23W3A Control Panel
Location 23 in that photo is the timer part Number=> 215846602 Defrost Timer
Some model's have the=> 240375803 Adaptive Defrost Control
Either way should you have questions I will be here to help you. Please rate this solution, Thanks, Sea Breeze
Jun 20, 2011 | Frigidaire FRS23W3A Side by Side...
I cannot find the defrost timer on my Frigidaire FRS3R4EB3; I've looked at manuals online and still can't figure it out. Anyone know?
You don't have a timer you have an adaptive defrost control which controls when it defrost. If your heater and defrost thermostat are ok then the control is bad. Part 23 on this diagram. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5153839&diagram_id=1247647#d1247647
Nov 22, 2010 | Frigidaire Refrigerators
How to remove defrost timer
need complete model # to give correct help but most kenmore sxs ref / the defrost timer is located in the control panel . two screws to remove an un plug it .. reverse to install .. some older models are locaded behind the toe grill . same two screws.. mm
Oct 23, 2010 | Kenmore 52282 / 52284 Side by Side...
Where is defrost timer in maytag MSD2756GEQ SxS
Inside the refrig section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and foreward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrig's , a white box will be seen. Inside this box , is the adaptive defrost control
Jun 13, 2010 | Maytag MSD2758G Side by Side Refrigerator
The alarm went off indicating that it the temperature had risen above the recommended level for keeping food frozen and safe. However, the temperature knob is set to the highest possible level.
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others. You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Feb 26, 2010 | Frigidaire Freezers
The refrigerator is not cooling
If your freezer is frosting up, fresh food section is warm: bad fan motor,defrost drain stopped up and forming slab of ice between the freezerand the fresh food section. Check heaters andterminator(defrost thermostat) unplug the ice box and let it defrostcompletely. Clear objects from drain. Check timer. Note to find thelocation of your timer look up your model number online here: APPLIANCEPARTSPROS.COM.
Check under the bottom for the fan motor to be running and the cobwebs, dust, dirt, and pet hair, off the condenser coils. If the fanunderneath has quit then the ice box won't get cold. BASIC REFRIGERATION REPAIR MANUAL
AMANA SxS REPAIR MANUAL
BOSCH MANUAL
Monogram Manual
KitchenAid SxS with variable capacity compressor
GE LATE MODEL SxS MANUAL
F&P Reefer
Jan 11, 2010 | Maytag Refrigerators
Frigidaire GS26HSZCC7
it sounds like it could be the defrost timer/board hanging up in defrost periodically. this refrigerator has an adaptive defrost control board that acts like a defrost timer. it keeps track of how long it takes the freezer to defrost and schedules the time between defrost cycles accordingly (to save electricity). old defrost timers would go thru a defrost cycle every 12 hours whether it needed it or not. so i would suspect that this control board may be malfunctioning. the control board is item # 1036287 at repairclinic.com. you will need a repair technician to test it and make sure it is bad before spending $75 on it.
Jul 10, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
Refrigerators Logo
268 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
