Question about Nokia 6270 Cellular Phone
6270 problem Hi,,, my 6270 , switched off , and now can,t be on again , battery is ok and charging when connect it to charger.(display shows that) Question ,, how to update sw , or how to download it again , because looks i,s sw problem. Kindly advice
  • jalal May 10, 2008
    HI , after opening the mobile , i found the 2 screws which fixing the ON-OFF button loose, i just tighten those screws and my mobile comes back to normal. no more problem.
  • 81 Answers
Just take a Drier totally dry your cell, after that switch it on .
Remain is u want to update your cell so…. You have to install the Nokia PC suit connect through the USB cable go to update phone software…
Its nothing but update the Firmware…
Best Luck…
Posted on May 09, 2008
  • DRSS..
    DRSS.. May 12, 2008
    Ok DUDE... you have a luck so u dont found any problem...
Lattitude e5520 wouldn't charge
Ted try this once more:
1. turn off the machine.
2. keep pressing the off switch a little longer 3. remove the battery.
4. press the off button for say 15 seconds.
5. re-install battery after a few minutes.
6. connect charger to computer and see if it shows % charge.
7. when it shows 100%disconnect charger and see if the battery still shows 100% If it does you are now reset. IF not,will cross the bridge then.
Jan 24, 2014 | Dell Latitude E5520 Laptop Computer PC...
My samsung mobile sch-f 309 cdma. last one week i put charging continuosly 4 hrs am not getting charged fully .it is showed only one point.and some times no charging shows low battery. after i changed...
here's what you can do...
Check the charging terminal of your unit and look for dirt accumulation and the like that maybe blocking the metal part or the terminal, remove it if any. if there is none, chances are that you have a defective charger or your unit has a defective charging circuit and will not charge your battery. aslo try on charging on other outlet.
To check your charger, you must have a multi-tester and set it to 10 Volts dc. connect the red probe of the tester to the positive terminal of the charger and the black to the negative. it must have a reading between 4V to 8V if it is OK. if it has a negative reading, reverse the connection.
if charger is OK, most probably that the charging circuit has problem.
I recommend to have it fix to a repair shop to avoid further damage on the unit.
Hope i helped you...
Don't forget to rate me OK... Thanks...
Bst regards,
Jan 05, 2011 | Samsung Cell Phones
I have an Olympus e510 that I bought new 2 years ago. The other day I got it out to use it and it will not turn on. I purchased a new battery, charged it, and it still will not work. When I removed the...
Hi, as per your information your camera 2 years old but not used much. You buy a new battery 1st time when you charged you see the gree light. But camera not working. When you try to charge the battery again you seen the red light. Its mean your charger have a problem. So what you do now? Ok try these.
Remove the power connection of the charger. then fixed the battery there slowly & properly. After that plug on the charger again. If the same thing happens then unplug the charger & plug in in different point. Then see what showing. If again red light then wait 1 hours and waiting for green signal. If there is no green signal showing then visit a service center with your charger. Tell them your problem. They will fixed the charger for you. Don't worry your camera is ok.
Your new battery or your charger one of then damaged. Thanks & waiting for your feedback.
Feb 15, 2010 | Olympus Evolt E-510 Digital Camera
230 chauffeur doesn't charge. Batteries new and
hi, ok you mentioned nothing about the charger, is it built in ? or stand alone charger, can you try another charger ??
If you have a Electrical meter tester check that the charging socket pins do actually connect to the batteries if not check the charging socket,
of the three charging pins two are the positive & negative so should show 24 volts the odd one out the one in the middle just below the other two is the inhibit , that is normally grounded otherwords negative.
Sound like a loose connection so please check all connections if you are sure the charger is ok.
Dec 10, 2009 | Electric Mobility Mobility Electric Power...
Nokia 6270 not charging
nokia 6270 not charging
Apr 08, 2009 | Cell Phones
Not charging show please give me your service digrame
check with other charger else "charging element of phone has died get it replaced ffrom nokia care.
Mar 17, 2009 | Nokia 6270 Cellular Phone
New phone won't turn on just has "Hellomoto" screen
hi.there...don't worry.. what happens with your new normal..why? when your battery is low and there a pop up screen at the display "battery low...please recharge" that's mean you must charge the battery soon.
when connect your phone to charger adapter and your battery is very low / weak condition the display only showing "hellomotto" and nothing else. but it's normal! diplay need more power from you battery to showing all information.after the battery reach the minimum power to display it ( usually after 15-20' charging) try to push red bottom at your keypad phone and the display will showing again..good luck..
Feb 02, 2009 | Motorola Mobility RAZR V3
Display problem Nokia 6270
Your phone's LCD is damaged by some reasons (could be the heat produced while charging) or is loose.
If ot is still in place,the wayto have it back is to buy a new LCD. A ratr for this will be mush appreciated...
Aug 05, 2008 | Nokia 6270 Cellular Phone
Battery suddenly will not charge.
the charger has gone bad; get a new one at
Mar 05, 2008 | Sony Ericsson Z610i Cellular Phone
Motorola razor v3 display problem
If the charger is not an original motorola charger,, then you have a problem. make sure its original.
Oct 11, 2006 | Motorola Mobility RAZR V3
Nokia 6270 Cellular Phone Logo
74 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
