Question about MotorGuide Standard Motor Replacement Parts - Type: Switches And Compone
I have a model T52 MotorGuide trolling motor and It just stopped working. I took off the top cover and I noticed the large black and red wire had got hot and melted the insulation on it and the yellow wire it cossed over on. I repaired both wires but still won't work. Anything I can try? HELP Thanks Ron
SOURCE: Wires fried on my switch KT150-02. Got a new switch, anyone know
if you still need to hook up this switch email me at pphhiill41@hotmail.com
Posted on Aug 04, 2009
SOURCE: wanting to install motorguide 24v trolling motor
I have installed a selectable 12/24 volt trolling motor on my boat. When in the 24 volt mode, the motor works well for about 3-4 minutes the loses all power. After about a 15-20 minute "cooling off period" the motor will work again for about 3-4 minutes. In the 12 volt mode, the motor works well all the time, only at about half the speed of the 24 volt mode. Why is my motor losing all power in the 24 volt mode?
Posted on Mar 30, 2010
  • 5 Answers
SOURCE: Motorguide trolling motor driver board burnt out part # JF157-02
trolling motor parts.com
Posted on Apr 30, 2010
SOURCE: On my standard motorguide trolling motor the
put the motor in the water and ensure that the propeller is at the rear. On the head of the unit (where the direction indicator is) push down and turn the round plastic plate (this plate has the direction indicator on it) clockwise until the direction indicator mark (mine is blue and is about one inch long) is in line with the alignment bar on the non-moveable part on the head. You will hear several "clicks" and this means that the indicator plate is clicking around to the proper directional alignment with the motor in the water.
Posted on Jun 17, 2010
  • 24 Answers
SOURCE: I have a motorguide trolling motor and the front
With the top off take the six screws out and lift the cable and gear out. Next put your foot pedal at mid position. Then make sure the motor is pointed forward and reinstall the slider gear and the six screws. Last put the top on and make sure the arrow indicator is pointing forward and thats it.
Posted on Jun 29, 2010
Need a relay for a MotorGuide Stealth 200 troll motor - part VF4-899F11
I have a Motorguide Stealth 200B trolling motor, works perfect but getting a new boat with a new motor. Trolling motor has original manual and paperwork with it, as well as 4 blade Ninja prop and prop wrench. Has some cosmetic scratches on motor. looking for $25.00
Feb 12, 2011 | MotorGuide Standard Motor Replacement...
Only have 5th gear on my trolling motor its a 5 peed but 1 thru 4 do not work already replaced the switch
I have the exact same problem gears 1 through 4 don't work but 5th gear works fine, any help from anybody would be greatly appreciated. There are 4 red wires going into the switch also a yellow and a blue. The 4 red wires all have power going through them in 5th gear but when I switch to the other gears only the two middle wires have power.
Aug 14, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Wanting to install motorguide 24v trolling motor in boat will it work on just 12 v system
It should but may not run at it's intended potential. It may also run your battery down a lot quicker.
May 13, 2010 | Electrical Supplies
No owners' manual
I have a Motor Guide Trolling Motor - Bow Mount - Model-71V- 24 Volt. Problem is arrow on top of motor does not align with the direction motor is going about 100 degrees off. Any solutions? wm.513@hotmail.com
May 12, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
I bought a used trolling motor (motorguide brute 750 50# thrust) it has a 12-24 volt selector switch and three wires to hook up to battery, a black, a white, and a red. i'm assuming on 12v setting of...
the black wire goes to - and the red goes to + for 12 volts. If you want 24 volts you need to add another battery and run a jumper wire from the - of the first battery to the + of the second battery and hook the white wire to the - of the second battery. Here is a picture to help you.
Mar 15, 2010 | MotorGuide Electrical Supplies
Mar 09, 2010 | MotorGuide Standard Motor Replacement...
Need to know how to wire a motorguide 767 brute trolling motor
The white wire is the ground. The black wire is neg. and the red wire is pos.
Mar 15, 2009 | Electrical Supplies
Motor guilde lll trolling motor
I have a motorguide trolling motor model 2600 #s/n 19409 can't find out what thrust it is
Feb 15, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
MotorGuide Standard Motor Replacement Parts  - Type: Switches And Compone Logo
168 people viewed this question
Top MotorGuide Electrical Supplies Experts
Craig Butler
Craig Butler
Ian Summerfield
Ian Summerfield
Mike
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
