Question about Neff B1421 Electric Single Oven
Ijust replacedmy fan oven element and there was only tow prongs not three - do I need a different fitting?
  • Neff Expert
  • 414 Answers
No, the new element should have come with a sheet of paper with the solution on it. Basically the old element would have had a prong in the middle to connect the earth. You need to remove the back of the oven casing and put the spare connection on the spare spade on the fan motor. Obviously ensure that the unit is isolated from the mains power supply before removing the back case panel. Hope this helps.
Posted on Sep 02, 2010
Hi, I have a Neff Double Oven (U1721N0GB/02). In the process of replacing the main oven element (which was clearly visibly faulty) I think I may have casued a short-sircuit / blown an in-line fuse. I have...
Did you replace the element from inside the oven cavity? If so, you may have knock off one of the spade connections whilst pulling the bracket through. Isolate from mains, remove back panel behind oven (not in the cavity) and check you don't have a wire floating about. The wires usually look quite similar but if you look closing they should have a black or red fleck in them, the element has two prongs on each side, you need to put the two the same colour on one side and the other single different colour on the other prong. If the fan is working then you have not blown the limiter that you will see quite close to the fan, but you might have blown the thermostat or the selector switch. If the red light comes on the fascia when you select the temp then it's pretty safe to assume the thermostat is ok. Hope this helps
Mar 24, 2013 | Neff U1721 Double circotherm Electric Oven
Tip
How to diagnose, fit and change a Belling fan oven element
If your fan oven is not heating up properly the Fan Oven Element for your Cooker is usual culprit. Fitting an oven element is generally very easy, as demonstrated by The Apart4u video on How to change repair and replace your fan oven element:this fan oven element can usually be changed without taking the appliance out of situ. Belling Elements
on Aug 25, 2010 | Belling XOU492 Electric Double Oven
Tip
Belling Elements
on Aug 25, 2010 | Belling XOU592 / XOU593 Electric Double...
Model no. SA420X oven. Have rubbed off the pictures that show the choice of cooking eg. super fan forced or fan forced, conventional etc. I need to see a picturs of the dial as it isn't in the manual
I dont know if this helps but if you turn the dial to the different settings and leave if for 5 to 10 minutes between testing you should be able to figure out what does what. Conventional generally means no fan forced. Fan forced generally means fan with one to two elements. Super fan forced generally is fan with two to three elements. You should be able to see or feel most elements. Sometimes the one or two elements in the bottom are actually located beneath the oven floor.
Feb 06, 2011 | Smeg Ovens
Is there a high failure rate on fan elements ?
It is not unknown for fan oven elements to fail quite regularly, some brands more than others, you must make sure you are fitting an element with the correct wattage, as this can make quite a difference to it's life expectancy.
Dec 01, 2010 | Bosch HBN 7052 GB Stainless Steel Electric...
Tip
on Aug 25, 2010 | Belling XOU482 Electric Double Oven
Tip
on Aug 25, 2010 | Belling XOU252 Electric Single Oven
Zanussi ZDQ 595 fan oven not heating
Here is a free video to help you with your cooker fan motor problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feedback please
For all your parts visit our site http://www.apart4u.co.uk
May 14, 2010 | Zanussi ZDQ495 Electric Double Oven
Replacement of fan oven element on Nef U1721
Hi Steve...yes, these are a pain! Remove the centre fan nut (which is anti-threaded) then lever off the small locating washer underneath. If you are lucky, you will be able to now pull the fan blade off of the motor shaft. However, very often they won't budge!. If you try to knock it off, it is so easy to damage the fan motor (about £80!!). It is possible to leave the top bracket screwed to the oven and unclamp the element from it. I have come across three different typed of clamps so far. One is very easy to do. You can then remove the clamp from the new element and once the element is in place, use the old clamp. It's a fiddle but quite do-able. I have also come across these where the top clamp has been previously removed altogether by engineers on previous repairs! Hope this all helps a little....
Jun 24, 2009 | Neff U1721 Double circotherm Electric Oven
Tip
on Aug 25, 2010 | Belling XOU174 Electric Single Oven
Neff B1421 Electric Single Oven Logo
116 people viewed this question
Top Neff Ovens Experts
ashburton
paulcarew
bobby1964
Level 1 Expert
Are you a Neff Oven Expert? Answer questions, earn points and help others
