Question about Dell Inspiron XPS M140 Notebook
Unable to open iTunes
I've had iTunes on my laptop for about a year and a half. I'm not able to access it now due to receiving error stating that audio is not configured correctly. What do I do?
  • 81 Answers
Hi FRND,
If you have the Audio driver so you must install the Audio driver in the laptop it might be corrupted so the problem occurs….
After this restart the system and it works fine…
Best Luck..
Posted on May 09, 2008
Unable to ascertain the compatibility of iTunes. Please check out interne
First thing you have to check the update version of iTunes.. then; when you install the iTools the iPhone should be disconnected from your laptop, also deactivate the option which allows iTunes open when you connect your iPhone to you laptop
Mar 24, 2014 | Apple iPhone 4S
My ipod wont turn back on
You have not stated any model no. which makes it hard to provide a solution.
The iPod A1136 is the fifth generation iPod from Apple that uses a click wheel to scroll through your device's media library, and may occasionally lock up when you attempt to play a song or display a photo. This error error occurs when the hard disk is unable to access the information and stalls while opening a file. A reset of the device usually corrects the problem, as it clears the device's memory and any errors. Check your iPod's buttons to determine if the cause is due to a hardware error before resetting the device, as the problem may be due to the iPod's hold switch. Slide the hold switch at the top of the iPod to the right, and slide it back to the left to ensure the switch is in the off position. Hold down the center button in the click wheel, and at the same time hold down "Menu" on the click wheel. Continue to hold the iPod's buttons until the device's screen shuts off, turns back on and shows the Apple logo. Plug the iPod's connector cable into the dock connector on the bottom of the iPod. Plug the other end of the cable into your computer's USB or FireWire port to charge the iPod. Wait at least two hours for the iPod to charge. Launch iTunes on the computer, and click "Controls" of the iTunes menu. Click "Eject iPod" in the sub-menu to disconnect the device. The iPod takes four hours to completely charge its battery.
Hope this helps.
Jan 24, 2013 | Apple iPod Audio Players & Recorders
Trying to access purchased songs on itunes but getting error 1202
hi please help me itunse me is error 0x80092013 can u help me for problem ty my email: mohamad.emadodin@yahoo.com
Mar 29, 2012 | Apple iTunes
I tunes store error 306.
Launch Internet Explorer
Click the Tools menu
Select Internet Options
Click the Connections tab
Click the LAN Settings button
Make sure that that "Use a proxy server for your LAN" checkbox is unchecked
Click OK till you are out of everything, and then close Internet Explorer
Try again in iTunes to load the store
if this dose not work
Then it is your security that is blocking you
try this
Sometimes this error can be caused by software on your computer that slows down the network connection. This error can also appear if you are downloading multiple items. I'd like to provide some steps that should help you successfully download your purchases.
It often helps to pause the download and then download items one at a time. These steps will walk you through doing this:
1) Open iTunes.
2) From the Store menu at the top, choose Check for Available Downloads. If you're unable to upgrade and are using iTunes 7, the option will say Check for Purchases.
3) Enter your account name and password, then click Check. Your purchases should begin downloading.
4) Under the STORE section on the left, click Downloads.
5) Click the Pause All button in the lower-right corner. This will temporarily pause all of your downloads.
6) To resume only one of the downloads, click the refresh button that appears to the right of one of the paused downloads.
Certain types of software can affect the way a computer sends and receives information from the Internet. Here are a few examples of these types of software:
  • Firewalls
  • Web accelerators
  • Ad filters
  • Virus protection software
If you have any of this kind of software installed on your computer, you will need to configure each of the applications to allow your internet connection to access iTunes freely. For instructions, please refer to the documentation that came with that software, or contact the software's manufacturer. You'll need to configure the software to allow these domains to send and receive data from the Internet freely:
itunes.apple.com
ax.itunes.apple.com
For assistance in configuring your firewall or accelerator software, you may need to contact the manufacturer or your Internet service provider (ISP). When contacting their support representatives, it may be useful to have the following information:
"Well Known" TCP and UDP Ports Used By Apple Software Products
http://support.apple.com/kb/TS1629
The following article helps Windows users pinpoint software conflicts that could cause the error:
Using MSCONFIG to troubleshoot conflicts in Windows XP
http://support.apple.com/kb/HT1275
Using MSCONFIG to troubleshoot conflicts in Windows Vista
http://support.apple.com/kb/HT2292
Once you have managed to allow access to iTunes through other software, please follow these instructions:
1) Sign out of the iTunes Store.
2) Quit the iTunes application.
3) Restart your computer.
4) Open iTunes.
5) Select Check for Available Downloads from the Store menu at the top of iTunes, (if you're unable to upgrade and are using iTunes 7, you'll choose Check for Purchases).
If you can't find this option, you can also click this link to do the same thing:
https://phobos.apple.com/WebObjects/MZFinance.woa/wa/checkForPurchases
6) Enter your account name and password, then click Check. The missing item should begin downloading and appear in your Purchased playlist.
Please note that the iTunes Store cannot investigate every user's connection issue. Apple Discussions are another source of information about iTunes, where everyone from new users to professionals can interact and share their knowledge and experiences. You may find another user with the same operating system or ISP that may be able to help resolve this issue. You can find the iTunes discussions group at:
http://discussions.info.apple.com/itunes
If you are using a dial-up connection, you might consider downloading your purchases over a broadband connection, if you have access to one.
Apr 06, 2010 | Apple iTunes
I have a dell desktop 8300 dimension running on xp. when opening itunes an unable to locate component window pops up stating "This application has failed to start because JavaScriptCore.dll was not found....
This is due to the dll file is not registered. Try to register the dll file will resolve your problem. For this
1st step: search for JavaScriptCore.dll file and copied the same to system32 folder using search menu.
2nd Step: type regsvr32 JavaScriptCore.dll in run menu and enter, it will rigester the dll.
Still you are facing the problem, once again reinstall the application.
Revert back for more assistance and also give your valuable feedback/rating for the solution provided.
Feb 10, 2010 | Computers & Internet
I am on internet explorer and can not access my email because of folder that states applicaion at the top above that folder i another one that states inbox the application box is stopping me from gettin to...
here is my advice : Just go to www.microsoft.com and download internet explorer again and install it , then reboot your system . I'm sure that this will solve the problem . any way , why don't you try other internet communication softwares like ( firefox or google chrome) those both are great also . I advice you to have more than one internet communication software . I already have three just in case if one of them is corrupted . I have ( Internet explorer and firefox and google chrome ) . just try the idea and you'll be satisfied with the result .
If that didn't help then try to check system for errors . such as registry errors .
good luck .
rate if useful please !
Oct 23, 2009 | Acer Aspire 5500 5570-2609 Laptop
Win32 app error for every application opened. the last thing i downloaded was updates for my hp laptop after stating it had updates available. i can't go to anything , tried accessing control panel to...
Do a system restore. start>all programs>accessories>system tools>system restore.
or in vista: just type system in the start search and click on system restore.
Sep 22, 2009 | Dell Inspiron 1420 Notebook
Incredimail
Based on the small amount of information provided, I'm assuming that you may being receiving an error stating that the page cannot be displayed.
If there's no problem with your connection to the Internet and you're positive that you are connected then install a different Web browser such as Firefox, Opera, Google Chrome, etc. If you're unable ot access the Internet using your Internet Explorer icon then you will have to use a different computer to download the installation files for the Web browser. After you download it, you will have to save it to something - a CD, flash drive, floppy - something. Take it to your computer and install the browser. Launch the browser after installation to see if it works.
A possible cause would be a firewall blocking all Internet access. This means that you would need to turn it off or reconfigure the settings to allow you to access the Internet.
This issue could also be due to the configuration of your connection and, since I have no clue how you're connecting (dial-up, wireless, broadband), I can't help.
A router may even need to be reset. Who knows...
Mar 25, 2009 | Dell Inspiron 6400 Notebook
How can I get Itunes to work on Ubuntu Operating Syste,
The short answer is: realistically, you can't.
The longer answer is: while some folks report that they've gotten iTunes to run under Linux/Ubuntu w/ Wine, it ain't pretty, and it probably won't recognize your iPhone.
The much longer answer is: I finally broke down and got a refurbished PC w/ Windows Vista on it mainly so my 3 sons and I could manage our iPods (3 iPod Videos and a Nano). I still don't like iTunes, and rarely if ever buy any music with it (I download most of my music from amazon.com these days), but it remains the only sure way to manage your iPod and/or iPhone until Apple decides to open their specs.
Sorry to be a downer...you might just get it to work if you put a LOT of time and effort into Wine or running Windows in a virtual machine, but the easiest (and perhaps cheapest in the long run) way to go is to have a cheap Windows machine around.
Eric Imboden
http://commoncontext.com
my take on tech : http://redsquiggly.com
Dec 01, 2008 | Apple iTunes
Dell Inspiron XPS M140 Notebook Logo
35 people viewed this question
Alun Cox
