Question about Microsoft Compact Optical Mouse 500 v2
Wired mouse opposite clicks right click is left
SOURCE: I Need Help with my mouse
I'd suggest ou first change he battery or at least make certain it's fully charged!
Second, stroll on over to the control panel and check the mouse settings!
Posted on Mar 13, 2008
IrishDruid
  • 2712 Answers
SOURCE: HP Optical Mouse right click button does not work
Hello PearlySue,
Just download the latest driver for your operating system HERE
and reinstall the driver. Once you've done that, reconnect the mouse and hopefully, it should work. If it does, it would be that the mouse is kaput and you may have to replace it. If it is under warranty, just take it back to the point of purchase and get it replaced. If not, you may have to purchase a new one. But do try the latest driver download first and see...
Should you have any further questions, please feel free to post them here. Please do not assign a rating until you feel your problem is resolved. I will try my best to help you further if need be.
If you are satisfied with my solution or have no other questions, please close the problem by assigning a FIXYA rating for my solution. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 20, 2008
MJS_1
  • 150 Answers
SOURCE: Mouse Right click doesn't work
Replace the batteries and check to see that there is a clear path
between the wireless mouse and its transceiver.
Keep the transmitter well away from older style CRT monitors, and make sure that the USB connector is properly plugged in.
You can also try to reset the mouse by unplugging the USB
connector and plugging it back in. There is no need to reboot
the PC, because USB is hot-plug-and-play.
1) The mouse consumes very little power in standby mode.
When the mouse moves or you press a button, the mouse
wakes up, it's internal processor begins to crunch
coordinates, and the RF transmitter is briefly activated.
This surge in power quickly depletes a weak battery, and
the mouse begins to malfunction. After a short rest, the
battery partially recovers (this is due to chemistry) and
the mouse may work for a few seconds again.
For some reason, my Logitech mouse fails quicker, when
I press buttons, rather than just move the track-ball, and
the buttons are the first to malfunction.
(No I have not analyzed the circuit and the internal mouse
software to determine the exact reason it does this ::)
Anyway, replacing the "AA" battery should help.
2) The location of the little RF transciever, which connects
to the computer using a USB cable, in relation to the mouse
is also important.
a) The communication signal weakens with the square
of the distance.
b) Metallic objects will block the signal.
c) CRT monitors emit powerful, wide band interference,
polluting large segment of the radio frequency spectrum.
This interference can over-power and corrupt the faint
communications between the mouse and the transceiver.
3) If these obvious measures fail, you may have a defective
mouse:
a) The fault is most likely in the mouse, not the transceiver,
but do check in the control panel => mouse settings
to see if the mouse is communicating, and the battery
status.
(Most mouse drivers do report these things)
b) If the mouse is at fault, you can disassemble it by
removing a few small Phillips screws. Pay special
attention to any mechanical linkages, springs and levers,
to make sure you put it back together correctly.
c) Pop out the tiny circuit board, and locate the mechanical
micro-switches. See if they work when you manually
activate them.
If they feel intermittent or flaky, you may try to clean them
with a spray contact cleaner, or replace them, but given
the price of mice these days, this may not be worth it,
save for the psychological boost/and or satisfaction.
Martin
Posted on May 08, 2008
  • 7 Answers
SOURCE: Want to open and clean Intellimouse w/ sticky left click button
you need an arsol can of air, and a simple wash cloth with water, no alochol.
the air cleans the contacts, the cloth cleans the entire mouse.
do not open the mouse. contact microsoft for further instructions if this does not work.
It has worked great on mine.
Posted on Jan 31, 2009
  • 63 Answers
SOURCE: microsoft wireless mouse/keyboard is not connecting
there is no such life span for a wireless device, atleast not very small, if handled carefully they will last you for a long time. there may be a problem with your button setting which can be corrected by going to 'control pannel'-> 'mice and pointer devices'->'buttons' tab.
Posted on Aug 03, 2009
How do i copy & paste an email add to my email? For example, when replying to an ad on craigs list
hold down left click on mouse ,drag left to right ,text will change color , if more than one line required pull mouse down still holding left click down all text will change color, release left click ,right click and select copy with left click. Go to email left click where message goes,right click mouse and select copy with left click. Sounds involved but easy after a few tries.
Aug 10, 2014 | Computers & Internet
Right Click not Working
If the left click is not working then you do not need a driver for it. I would advise that you try and carefully open the mouse up and check inside of it. Is a wire out of place or is something broken inside it? If you can still not fix it you can just get a new mouse or ask for expert advice on how to fix it. Hope this helps.
- Nathan
Apr 19, 2014 | Gear Head Mouse
I want to change mouse from right hand to left hand use?
It's very easy. Just follow the following steps!
If you are using windows 8, press the windows button on your keyboard(the one left of left 'alt') and type "change mouse click settings" , just click on settings tab on right and click on the first option that appears.
Just change the left or right orientation as per your choice now and click on apply and ok.
If using ANY OTHER OPERATING SYSTEM
1. goto start->control panel
2. Click on mouse(or hardwares-> mouse if in category view)
3. click on buttons tab
4. select required orientation and click on apply and ok
Aug 06, 2013 | Logitech Cordless Mouse
HOw to replace the mouse left click and right click
The mouse click changes are based on OS used.
In windows OS ..Click Start button on your windows desktop. Select and click on Control Panel from the menu. Select and click Mouse from the control panel. From the Mouse Properties Window, select the Buttons tab. Select and check the Switch Primary and Secondary Buttons check box. Click the OK button.
Your mouse buttons should now be switched around, so now when you click your left mouse button, it will behave as a right-click, and clicking your right mouse button will behave as a left click.
Dec 01, 2010 | HP Compaq Presario C306US Notebook
How do i can et internet on my laptop xp to connect from wireless router it show a lock how can i unlock
Step 2: With the left mouse button, click on 'Control Panel'.
Step 3: With the left mouse button, click on 'Network and Internet Connections' (Network Connections, if in Classic View).
Step 4: With the left mouse button, click on 'Network Connections'.
Step 5: With the right mouse button, click on the 'Wireless Network Connection'.
Step 6: With the left mouse button, click on 'Properties' button.
Step 7: With the left mouse button, click on the 'Wireless Networks' tab.
Step 8: With the left mouse button, click on the name of the wireless network, under 'Preferred networks', that you want to automatically connect to.
Step 9: With the left mouse button, click on the 'Properties' button.
Step 10: With the left mouse button, click on the 'Connection' tab.
Step 11: Ensure there is a checkmark in the checkbox, next to'Connect when this network is in range'.
Step 12: With the left mouse button, click on the 'OK' button.
Step 13: With the left mouse button, click on the 'Advanced' button.
Step 14: With the left mouse button, click to select 'Access point (infrastructure) networks only ' (This will help prevent your connection from bouncing around from one network to another).
Step 15: With the left mouse button, click on the 'Close' button.
Step 16: With the left mouse button, click on the 'OK' button.
Jun 13, 2010 | Computers & Internet
Right-click, Left-click not working....
Hi. Connect a wired usb mouse and go to the device manager. Expand pointing device and right-click the touchpad and select uninstall. Restart your computer and windows will automatically reinstall the touchpad driver.
If it doesn't work, you have to replace the entire palmrest where the touchpad is integrated with.
hope it helped... ^_^
May 17, 2010 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
My right click menu pop's up when ever i try to click on my laptop anywhere, i have a DELL inspiron 1520.
is your pointer set to be opposite... go into control panel and mouse options, and see if you accidentally switched your mouse clicker buttons.... try clicking with the right click, does it still open your 'right-click' menu? does it work normal on an external mouse?
maybe its just a setting issue,... if not then prolly need a new mouse pad...
Sep 25, 2009 | Dell F3534 Touchpad
Tote n Go laptop, mouse click not recognized
It is very likely one of the wires came loose inside the mouse itself. There are 4 black foot pads on the bottom of the mouse. With the batteries removed, pry off the four feet and remove those four screws. You will see two tiny brown wires that correspond to the mouse button.
Examine these two smaller brown wires and ensure they are not loose or have become disconnected from the small computer chip inside. The two smaller brown wires are on the interior of the chip and should be soldered to the board, opposite a larger brown wire and a larger white wire. The two larger wires, brown and white go back into the main cable that connects inside the laptop.
If these four wires appear to be intact, the next step would be to remove the two larger screws in the central blue piece with two larger holes on either side. This will release the mouse from the base. Examine the two solder points where the two brown wires are connected for any breaks. If these look good, there are two more screws that hold this chip in place. remove them and examine the button of the mouse.
Many others have found the actual push button under the mouse fails. This blog entry explains how he fixed the mouse button: fangletronics.blogspot.com
If you need further help, send a request to: kjhenseler [at] gmail [dot] com
Jun 18, 2009 | Vtech Tote n Go Laptop Plus
Right and left click are working backwards
Go to control panel, mouse, buttons tab, uncheck "switch primary and seconday button"...
Pls rate this solution.
Apr 07, 2009 | Microsoft Wireless Notebook Optical Mouse...
Mouse behaving erratically
try system restore from Accessories-sysstem tools when it was working fine or try uninstalling and reesinstalling the mouse driveers.
Feb 03, 2009 | Logitech Cordless Mouse
Microsoft Compact Optical Mouse 500 v2 Logo
60 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
