Question about Garmin Nuvi 660 GPS Receiver
Garmin 760 I bought a new Garmin 760 from the Ithaca store. I am not getting any voice prompts. I checked to make sure that the mute was not marked.
  • Anonymous Sep 03, 2008
    GARMIN NUVI 760 HAS NO VOICE PROMPT, AUDIO INCOMPATABILITY
Try rebooting the unit it might help
Posted on May 15, 2008
There is no "voice" on my Garmin - Only had it 2 weeks! Volume is on High.
Please tell us what model it is. Is the sound set to be muted with a check mark in the box? Make sure that a voice is selected in the voice set-up menu.
Nov 14, 2016 | Garmin GPS
My Garmin Nuvi 760 GPS announces the turns but not the street names.
1. This is because some voice files are only basic but others speak the street names. To change the voice file press TOOLS, then press SETTINGS then press LANGUAGE. Press the VOICE and change it to a different one.
2. You can download extra voices, if you need to, by connecting your satnav to your computer, Download webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27 and install it. When it's installed it'll look for software updates. After this it'll give you the option to download extra voices. Select the ones you want and press next. Follow the prompts and they will be downloaded to your satnav. When you have disconnected your satnav from the computer you can select a new voice as described in para 1 above.
Aug 19, 2010 | Garmin Nuvi 760 Car GPS Receiver
I have a nuvi 760 and lost the voice instructions
First check that the sound has not been muted. Pres the volume symbol and see if the mute box is ticked. If not either the voice has become unselected or the voice file has become corrupted. Press, Tools, Settings, Language. The selected voice should be displayed. Press voice and select another. If there's not another voice or if the voice file is corrupted you can download it again. First download webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27 and install it. Connect the satnav to your computer and using webupdater it will search for updates. When it's finished it will give you the option to select voice files by clicking on them. Select the ones you want and press next. When the files are downloaded and the satnav is disconnected from the computer you can select the voice you want as described above.
Aug 07, 2010 | Garmin Nuvi 760 Car GPS Receiver
Garmin 760 stopped talking was fine yesterday
Make sure the volume isn't muted. There is a separate volume adjustment for Navigation (voice) in addition to media player. Can be a bad speaker. Make sure a TTS voice is selected. More info at these links:
http://www.sharc.net/gps_audio_repair.htm
http://www.sharc.net/discus/messages/6/74.html?1269626536
- Jim
- Jim
Jun 23, 2010 | Garmin Nuvi 660 GPS Receiver
Lost all voice prompts and in bluetooth mode voice is garbled
Go to Tools.....Settings....Language.... under Voice make sure Language with ( TTS ) is chosen
If that is ok then look at this...
Press Volume Icon.... if a checkmark in Mute remove it
if no checkmark then on the bottom of the screen you will see FM TRANS press
Does Enable FM Transmitter have a check mark? if so remove it and check sound
May 30, 2010 | Garmin Nuvi 760 Handheld GPS Receiver
How do I get the voice back on Garmin Nuvi 760?
do u have it on "MUTE" do u have the voice volume turned down? check yoyur user manual for these settings and how to locate them in the GPS tools section, most likely it is just a matter of resetting the volume.
Mar 25, 2010 | Garmin (010-00583-00) for nuvi 750/760/770
My garmin nuvi 760 suddenly lost it's voice and I have gone into tools and checked the voice and it is at 100% and the fm transmitter is off and the mute is off. Now what?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Assuming you have all the features on, try this
You will need to ensure that you are running the latest software which can be done by installing a program called WebUpdater. WebUpdater can be installed via the link below:
Once updated please allow the unit to reboot which will ensure the software successfully installs.
If after following all the above the final steps would be to perform a master reset:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers on. After 5-10 seconds you will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Please follow the on screen prompts on the nuvi and when completed place your device in an area with a clear view of the sky until it acquires satellites.
Dec 01, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
My Garmin 760 does not speak street name on the turns. How to set dthis?
On your GPS device, Touch settings>Select language>Select Voice and select the TTS(Test To Speech) man or women to speak.
Make sure the volume is up, and the mute is off.
The pre-recorded voices(those with out a persons name) have a limited vocabulary and do not speak names of locations or streets.
hope it helps you out
JADF
Apr 13, 2009 | Garmin Nuvi 760 Car GPS Receiver
No voice prompts on my new nuvi 750- volume level not muted.
I had the same problem after I had my Nuvi 750 for a few months.  The voice just stopped.  I called Garmin and they replaced it under warranty.
Feb 11, 2009 | Garmin nuvi 750 GPS Receiver
Garmin 760 - No Voice Directions
Check The system settings, I had to download the newest version of the audio software for the voice to work. The software vanished once and I had to re-download it using the web updater.
Hopefully it will stick around this time.
When I load the new software the voice works.
Sep 03, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
71 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
