Question about Samsung Refrigerators
My back fan stopped working - Samsung Refrigerators
  • 1,531 Answers
Replace the fan but alos check the wiring and make sure it is in good condition
Posted on Aug 31, 2010
Tip
Rebuild the fan when it stops working!
Caframo advertises a feature in this fan which will shut the fan down if it gets too hot, and then start it again when the fan cools down. In fact, this feature is heat sink compound between the two halves of the body (which are each heat sinks) and the power plate between them. That compound breaks down over time and use. If the fan stops working, take it apart and scrape that compound off (it was silver on my fan), and replace the compound with a thin coat of CPU heat sink compound from an electronics store. Put the fan back together and let the compound set up over night before placing the fan back on your stove. Should work like new!
on Nov 01, 2009 | Cfm 802 Ecofan Table
Front fan just stopped working...back one is fine.
{: ) It could be the BLWR fuse 40amp at the underhood fuseblock, a faulty blower resistor assembly, or the front blower motor itself.
Apr 27, 2010 | 2008 GMC Acadia
Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ceiling fan just stopped working. Turned on
did any outlets stop working, mat be a tripped or bad breaker in elect. panel she if one breaker is tripped. flip off and back on, could se short in fan but unlikely. if cannot see tripped breaker, turn off computor, tv, any appliance you have on and go down breakers and flip off and back on. if a short is present one breaker will trip back off. call repair
Jul 11, 2009 | House Brand Dryers
My fan blower stopped working the fans in the back still work but not the front??
it sounds like it could be just a loose connection at the back of the fan or not sure if the fans are connected or not but a blown fuse may cause this
Jun 04, 2009 | 1999 Ford Expedition
Heater fan stopped working
check the back of the fan switch for power and inspect it for damage ,melted or loose connections.
May 25, 2009 | 2002 Ford E350
The fan in back of the fridge has stopped working
The fan motor probably is bad and need to be replaced but before do it check the wiring to the fan for loose connections and also check the blade if its hitting or touching something that could make it stop.
May 01, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Whirlpool top freezer problem
Check for frost build-up behind back wall in freezer. If there is a heavy frost build-up, it's not defrosting. This will restrict airflow to refigerator section and can stop fan. If fan is stuck again and it's not because of frost, replace evaporator fan motor.
Nov 12, 2007 | Whirlpool ET1FHTXM Top Freezer...
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
