Question about Hotpoint Refrigerators
Water not flowing out..the icemaker works fine, but when you select water, water does not flow out....what should I look at?
  • 1,531 Answers
You can take a peice of weed eater line and stick through the water line in the door and see if it goes all the way through. If not then there is frozen water in the line.
if there is a coupler on the bottom of the door disconect it and try to dispence water if the water comes out there then the water valve is good and you need to defrost the line i the door a blowdryer usually works for this but it does take some time
Posted on Aug 31, 2010
Where do I find the ice maker inlet water valve or solenoid? The valve on the back of my fridge has only one hose going to both the water dispenser and ice maker and the water dispenser works fine.
Since there is water that flows to the water dispenser, the water valve is working. Now, there's a spout that water flows from to the icemaker tray. Look for it. It's located on the back wall inside the freezer and maybe behind the icemaker tray. Check and see if it's frozen. If so, defrost your freezer by turning the temperature gauge to off position. Wait a while until it's defrosted, then turn it back on.
Next, make sure that the metal wire is in down position.
If that doesn't work, your icemaker maybe defective and needs replacement.
Nov 01, 2014 | Maytag MFI2665XEM Stainless Steel
Icemaker not working, water works fine, freezer working as designed
If you model has water n the door, check to see that it is flowing quickly.
If it is flowing slowly, or is not flowing at all, then it is likely that you have a clogged water filter.
The filter is usually locataed in the upper right hand side of the fridge, after you open the door. Or on the bottom left side with the door closed.
Good Luck!
Jan 30, 2010 | Refrigerators
The water line to my ice maker in my Maytag MF12568AEB sprung a leak. I replaced the entire line, but now no water is flowing to the icemaker. The other line works fine to the water dispenser in front. Do...
No you should not need to reset anything get the water line to flow threw the water supply and raise the lever on the ice maker till water comes out if you don't get water out check to see if you left the shutoff valve off. Hope this helps. Thanks for using fix-ya.
Jan 19, 2010 | Refrigerators
Water is not going into icemaker, I've replaced
I have a maytag side by side with water in the door, the cold water works but the icemaker doesn't. No water flow into the icemaker, it doesn't appear to be iced up. Can not tell if the selenoid works.
Jul 14, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water flowing to the icemaker would not stop. It over flowed the
sounds like the water switch is stuckopen or the valve is. Is the water going to the icemaker or thru the door. If the icemaker is overflowing and doesnt shut off then unplug unit,still coming in change the valve. Not coming in then look at the switch.
Jun 10, 2009 | Kenmore 53542 / 53544 Side by Side...
Water seems to be flowing into icemaker fine. When I turn on the icemaker the water flows for a few seconds then stops, I have waited to see if the cycle to dump works and it seems as if it never attempts...
If your freezer temperaures are good i.e. it freezes ice cream and the like, then you need to replace trhe icemaker. Typically, under normal conditions, the icemaker would dump a load of cubes @ every 1-1/2 hours. Icemaker part number WR30x10093 @ $148.00 from Marcone Appinace parts or AP Wagner
Apr 09, 2009 | GE Profile PSI23SGR Arctica¿...
Water dispenser doesn't work but icemaker works fine
TAKE A HAIR DRIER AND HEAT UP THE RESEVOUR INSIDE OF THE REFFRIGERATOR BY THE OUTLET UNTIL THE WATER STARTS TO FLOW. GOOD LUCK
Jan 11, 2009 | Maytag MFI2568AE Side by Side French Door...
Water despenser
hi there,
check to see if you have a leak in the water line. the line runs from the wall to the icemaker. do you have any leaks on the inside of the door? any frost build up? im assuming that you have a side by side fridge with an icemaker.
Oct 11, 2008 | Refrigerators
Water wont flow into LG LX259602b ice maker
You may have a bad water valve.  The valve has 2 sections, one for the water dispenser and the other for the ice maker.  Check those connections in the back of the refrigerator.  If everything is ok, replace the water valve.
May 18, 2008 | LG LRSC-26922 Side by Side Refrigerator
Automatic icemaker
Have you made sure your water supply was good and a good steady flow of water is flowing in to the back orf the fridge?/ If you have then theres a small micro switch that opens a water valve at the proper moment of the cycle of the ice maker. This switch is inside the icemaker up against a small cam being driven by a small motor. The switch activates a small valve that lets the water flow into the ice maker.if the water flow is good its the switch or the valve. Good luck
Apr 16, 2006 | Whirlpool ET1FTTXK Top Freezer...
Refrigerators Logo
48 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
