Question about Intermatic T104-20 Indoor Hot Water Timer
Timer clock only runs when in on position - Intermatic T104-20 Indoor Hot Water Timer
  • 565 Answers
That's because the timer is mis-wired. The incoming wires from the circuit breaker _must_ be connected to terminals 1 and 3. The out going wires to the water heater must be connected to terminals 2 and 4.
The clock timer motor is connected internally to terminals 1 and 3, so it won't work if the incoming (always hot) wires are connected to terminals 2 and 4 (until you close the contacts by moving the manual lever to the ON position)
Posted on Sep 02, 2010
Why is my timer runnung backwards
Timer is not identified.
Analog timers have clock motor.
If the gears strip out, then timer can run backwards.
Some timers have replaceable clock motors, such as Intermatic and Tork box timers, and pool timers.
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
While small plug in timers generally do not have replacement parts.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Jul 19, 2012 | Hardware & Accessories
ML600 won't turn off
The clock module for power pack is not sold separately.
Set timer to auto using override knob so lights are on, then plug power pack into cheap timer.
Check outlet with circuit analyzer.
Try connecting power pack to another outlet.
Copy following link for warranty information, tips to help power pack last longer, links to trippers, troubleshoot, etc.
Jul 15, 2012 | Malibu ML600TW - Low Voltage Power Pack -...
Intermatic T104 timer wont turn pump on,despite being tripped
If override lever snaps back and forth crisp, and turns pump ON-OFF, then timer switch is good.
Try installing new trippers. The trippers wear down and start to slip over the trip lever.
If pump does not turn on-off with override, look for loose wires at breaker or pump.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timers.html
Jun 06, 2012 | Hardware & Accessories
Where can I find the manual for the Intermatic Incorporated Timer, Spst-125V 24Hr Mechanical 2 On/Off - PB913N84
There is no manual specific to the PB800-900 series timers.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#PB
http://waterheatertimer.org/pdf/Intermatic-PB800-PB900-timers.pdf
Timer uses 107TTN222 ON tripper and 107TN221 OFF tripper.
Push trippers onto dial at times you want timer to turn on-off.
Rotate dial until current time lines up with arrowhead located in center of timer dial.
images show that timer has override knob that can be rotated.
Timer has 4 terminal connections. 2 connections are for 120Volt clock motor, and 2 terminals are the switch for turning Load on-off.
Black hot wire and white neutral wire connect to clock terminals.
Switch terminals are dry.
Dry terminals mean they have no power when wires are connected to clock motor.
The switch terminals wire just like ordinary light switch: Power connects to one of the terminals, and wire to Load connects to other terminal. Neutral wire does not connect to switch terminals, just like wiring an ordinary light switch.
Offhand I do not know which set of terminals is for clock motor.
Use continuity tester on each set of terminals.
Clock terminals will show continuity at all times, no matter which position override knob is set.
Switch terminals will show continuity with override knob in one position, but not the other position.
Jul 04, 2011 | Intermatic TIMER,SPST-125V 24HR MECHANICAL...
I have an Intermatic T104R timer set up for my pool pump. It seems that the clock is running backwards. Why is that?
If dial is not rotating clockwise and keeping correct time on 240Volt T104 timer, then WG1573 clock motor is probably bad.
Open following link for troubleshoot checklist:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 06, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
1: 42 25805 DEHUM 50 PT ELEC w/PUMP Lost manual - how do we set the timer to shut off at night?
How to program the delayed start function: From the OFF Position.
1) With the unit OFF press the clock/timer button and use the and - buttons to set the number of hours after which the appliance should start functioning.
How to program the delayed stop function: From the ON Position
1) Press the clock/timer button and use the and - button to set the number of hours after which the appliance should stop functioning.
2) Ont the left side the display will show the number of hours to start/stop and the dot under the clock/timer symbol indicates that the timer has been selected.
Jun 13, 2010 | Kenmore Dehumidifiers
Timer keeps time, but sticks at tripper points
1) Clock motor needs replacement:
Link below shows timer and wiring manuals.
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
2) 120Volt Clock motor sells for $43 at Frontier lighting
http://www.frontierlighting.com/product.jsp?part=10431&process=search&show=&ID=,Photo.Cells...Time.Controls,Replacement.Motors
3) New Tork 1103 sells for $55. Just swap out insides without changing box.
4) Intermatic crossover for Tork 1103 shows Intermatic T103 timer.
Amazon sells T103 for $50
http://www.amazon.com/Intermatic-T103-120-Volt-Mechanical-Switch/dp/B000LDIDBY
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Oct 01, 2009 | TORK Digital Interval Timer Ssa100r-24
My intermatic timer won't trip back on
I don't think the timer runs on 240 volts does it? You can switch 240, but the timer uses 120 volts to run. You might check the connections and timer clock rating more closely. Also, the 'off' & 'on' trippers are different, make sure you use the right one.
Jun 26, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
I think the clock is run backwards
reverse the wires to the timer and it will run clockwise.
Apr 09, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Intermatic T104-20 Indoor Hot Water Timer Logo
83 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
