Question about Thermador Ovens
I have a thermador double oven ct227nw i had corecentrics rebuild the control panel when i pluged it in i get an E 3 code on the display
  • 833 Answers
SOURCE: Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
Posted on Dec 07, 2007
SOURCE: Lighting panel in my electric Thermadore double oven is dim.
I just replaced two of the capacitors and it worked thank God. I couldn't get at the 3rd capacitor with the soldering iron because the display blocks it and I couldn't see how to remove the display unit. We had already begun shopping for a new double oven. This was the last resort. The capacitors were $1.78 apiece at an electronics store. A repairmen quoted us a $780 fix - with him shipping the parts out to be rebuilt because Thermador is out of business and not producing parts anymore. There is a great place in Canada called Appliancetimers.com which will rebuild the timer for you inexpensively ($109) but they also want you to send the Power Relay Board which requires removal of the double oven to get at it. We found that it was much too heavy to consider that solution.
Posted on Mar 27, 2009
SOURCE: thermador oven control panel light is not working
Please see post by bonanzsapilot on 14 March 2009; he gives exact & easy to follow directions for making this repair for <$10. It's listed uner 'Thermador SC301IT oven - FixYa'. In a separate post I added the correct capacitor numbers from Newark.com. I made the fix in abt 30 min & it's good as new. Thermador no longer makes control panels for this oven & no wiring diagram is available to help. Shop price was estimated at $500.
Posted on Apr 13, 2009
Macmarkus
  • 2605 Answers
SOURCE: front panel display dim, can't see the
I see this post has been here for quite some time. Sorry you haven't had an answer yet, while I can't say why, If you still are inquiring, the problem lies in the control and harness assembly. In my professional experience with almost all thermador of this era it's sometimes a bad solder on the control pin connector from the display,(which can be fixed by a proficient soldering person or conversely destroyed by a poor one) a bad transformer integrated onto said control, or other times just a bad harness, you'll likely need a control in any event. When you purchase a control ( # 1051714 for 302-double or 1051712 for 301 single oven models, and around $200US check your local parts depot or service center.) they should have new harness enclosed in the packaging of the control.
I just joined here less than a month ago, so I'm starting to see alot of post's I haven't seen before (there are many) and likely some may never get answered directly, but alot are the same if you search out similarities.
hope this helps.
**I should add this could be a job for a professional tech, who depending on how proficient they are or how the environment is set up, could handle this in 30-45 min or so. It is quite straight forward for one experienced with servicing thermador units. I would suggest you insist on an authorized b/s/h tech, they tend to have more of the update info if any or reworks etc.**
The above (re: hiring a tech) is just my opinion based on my professional experience and there may be opposing opinions, in the end you are the authority.
hope I've been helpful to you,
Good Luck
Posted on Oct 19, 2009
SOURCE: how to remove the control panel on Whirlpool double oven Model RBD305PDS14
Emge & Associates is investigating gas and electric ovens manufactured by Whirlpool, including such popular brands as Whirlpool, Jenn-Air, KitchenAid and Maytag.
The firm is investigating reports that the electronic control panel on certain models is subject to failure after a limited number of uses of the appliance’s “self-cleaning” setting. While most foods are cooked at temperatures reaching 375 degrees, the “self-cleaning” setting raises the interior oven temperature to 1,400 degrees. Due to defects in the design and or manufacturing, the electronics contained on many ranges are damaged by extremely high heat. Repairs to damaged control panels typically cost in excess of $300 per replacement.
If you have experienced failure of the control panel in your range after using the “self-cleaning” setting, you can join this investigation by contacting Emge & Associates at (800) 629-3409 or (619) 618-2974.
Posted on Dec 19, 2009
The control panel is very dim on my Thermador RDSS30 oven
Cannot Read Display or See Temperature Thermador RDDS30
FixYourBoard.com repairs this failure and back their work with a two year warranty.
May 14, 2011 | Thermador Ovens
CODE F64 WHEN TRYING TO USE THE BOTTOM OVEN.
Hi, i found out from Thermador customer service that error code F64 means that the lower fan switch (located inside the bottom trim on the right side) is not being detected as closed. In my case, this was because the header (P4) on the Display panel had broken loose from the PC board and was no longer making contact. P4 is where the lower fan switch wires connect to the control boards (actually the display panel).
Mar 29, 2011 | Thermador C302U Electric Double Oven
I am getting an F64 on my thermador electric double wall oven after a few minutes of preheating my upper oven, and the oven turns off. What des this mean?
Jan 05, 2011 | Thermador SEC302 Electric Double Oven
Oven displays Off with every button you push
touch panel has failed . may need replacement . . this unit may require a update kit .. ( new p c control and panel .. ) very costly. mm
Jul 13, 2010 | Thermador SMW272 Electric Double Oven
Thermador wall oven doesnt heat up after being self cleaned
This may be the thermal fuse mounted on the back panel or you may have a failed control. We rebuild Thermador control boards at www.fixyourboard.com
Jun 02, 2010 | Thermador C302U Electric Double Oven
The LED control panel on my Thermador double oven is out
I solved this. Its a vaccum flourescent display. The voltages that drive it are reducing because the capacitors on the control board deteriorate with temperature. Replace the 3 capacitors and its good as new.mine still working after 2 years...$.20 at radio shack...or have a repair place do it for you...saves $250 for a new board
Nov 16, 2009 | Thermador SEC302 Electric Double Oven
Thermador SC302 double oven the top oven is not getting hot
We've had the same problem. I contacted a local sales room and they contacted their rep who promptly mailed the replacement parts I requested (I'd looked up the part numbers already). Now I'm waiting to find someone who will reasonably do the work.
Aug 10, 2009 | Thermador SMW272 Electric Double Oven
The cap replacement worked....saving $250 (every 2 years !!!) I posted it on another site...now its making its way around the web....its the only value added thing I've done on the web (sadly!).
Nov 14, 2008 | Thermador SC302T Electric Double Oven
Thermador Display
Have 2 Thermador ovens, SMW272 and SC302. Both have display failure. Just repaired one with replacement display. It did not require a new control unit or harness. Have not opened up second unit yet as display is still dimly/slightly visible.
Called Thermador and received no offer of replacement parts or service. Numerous other web reports of similar failures. My neighbor has 2 dead ovens also unfixed because of outrageous repair estimates ($600 each). Do not recommend this brand.
Full kit including display, control, and harness ordered on Ebay for $170.
Sep 21, 2007 | Thermador SMW272 Electric Double Oven
Ovens Logo
122 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
