Question about Bassett Cottage Sleigh Crib
I have a bassett bed and i lost the bolts and i need some were would i find them at?
SOURCE: bassett baby bed mod#0681518
the front inside gate go up and down it locks at the top but does not lock at the bottom. It automacially comes off completely. What Can I Do to make it right?
Posted on Nov 17, 2008
  • 8 Answers
SOURCE: Need instructions ofr converting crib to a toddler bed.
This site has instructions for the cribs listed below. The 1st two listed seem to be generic cribs with a metal mattress support. It worked for my used crib.
www.milliondollarbaby.com/help.milliondollarbaby.com/
*For cribs with snap-in spring hangers hooks & metal mattress support.w/ spring hanger hdware.
*For cribs w/ bolt-in metal hdware for metal mattress support w/ metal hdware.
For cribs with Safety Glide nylon(rodless) hardware
Sleigh Convertible 3001 Crib
Sleigh Convertible 3091 Crib - Safety Glide
Jenny Lind Crib
Ashley/Alexandria Crib (1 piece headboard) +Day bed info.
Ashley/Alexandria Crib (3-piece headboard) +Day bed info
Lauren Crib ) +Day bed info
Emily Crib (One piece headboard) ) +Day bed info
Emily Crib (Four-piece headboard) ) +Day bed info
Mini Emily Crib
Anastasia Crib
Bridget Crib
Valerie Crib ) +Day bed info
Bailey Crib ) +Day bed info
Ellie Crib Day bed and full bed info
Kalani Crib Day bed and full bed info
Bordeaux Crib Day bed and full bed info
Annabelle Mini Crib
Italian Cribs-Metal Barrel Nut
Italian Cribs-Nylon Nut
Canopy cribs with snap-in spring hanger hardware
Canopy cribs with metal bolt-in hardware
Posted on May 17, 2009
SOURCE: Unique Oak Treasures Crib - Full Bed Bassett Model 5542-0521
We have this crib as well. We bought it from Babys R' Us in 2005.
We also purchased the rails to convert it to a full sized bed. It did not come with instructions but I can explain to you how to put it together.
The rail conversion set should come with 2 pieces of wood that act as the bed frame. You do not need to purchase the extended frame. The set should also come with 4 long screws, the hex tool to tighten it and 4 metal pieces. You might also have some wood nail cover plugs.
Once you've taken apart your crib, the only pieces that you will need are the 2 longer pieces of the crib...the headboard and the footboard. The 2 shorter side pieces which served as a headboard and footboard as a crib and the metal grate to hold up the mattress can be put into storage.
On the sides of each of the new wood rails, you will see a circle indent on each end with a hole. You will insert one of the long screws into each and then insert it into the head board. You must use the special tool to screw/ tighten it in. The metal flat pieces can be inserted into it the circle befor eyou are done tightning so that it does not strip or damage the end of the circle. You do this with the other rail on the other end and then add the footboard using the same process. If you would like, I can send you a copy of what this looks like close up. ( the cricle indent with screws. The bed is extremely strong. We've all napt in it as a family along with our 2 large dogs. I highly recommend ordering the extra long/ tall bed rails from OneStepAhead for security because my son has rolled out of the bed and it is super tall!
http://www.onestepahead.com/catalog/product.jsp?productId=534602&parentCategoryId=85183&categoryId=85216&subCategoryId=86203
Posted on Jul 18, 2009
6ylucy
  • 742 Answers
SOURCE: Bassett crib model 5665-0621S. How does it
you can try asking at manualfox.com
Posted on Mar 31, 2010
CribParts
  • 340 Answers
SOURCE: need side rails to convert our bassett 5469-0521
This is Products America! Although we do not carry conversion hardware, you may try www.bassettfurnituredirect.com and see if there are any rails for your Bassett crib at a Bassett direct near you. We hope that this will help with your crib hardware needs!
Posted on May 20, 2010
How to assemble rails
Take a look at this pdf. It might help you to reassemble your bed.
http://ebookbrowse.com/bailey-sleigh-bed-12aug2010-chl01-pdf-d295022039
If it doesn't help you should consider contacting the manufacturer.
Sep 30, 2012 | Vaughan Bassett Night And Day Cordovan...
Bassett crib model 5530-0621 purchased in 2007- how to convert to day bed? Currently have it set up as a crib
If you don't have the rails to convert, Bassett discontinued the crib in2008. You can convert it using a standard metal (bolted) frame found in mattress or furniture stores. I called customer service today and found this information. 7/15/2013
Sep 05, 2011 | Bassett Baby Gear
I have a bassett baby bed number 5015-1508 made in april 1989 I need the brackets that hold the springs up
All drop down cribs have been recalled and are NOT safe to use around children! A bed this old should be discarded and replaced with a new certified model.
Apr 22, 2011 | Bassett Cottage 3-in-1 Crib
Need side rails to convert our bassett 5469-0521 crib into a full size bed - where can I find them?
May 19, 2010 | Baby Gear
Jan 20, 2010 | Bassett Baby Gear
I have a bassett baby bed with no instructions, which way does the rail sit? Bed was manufactured in 1991. There is one keyhole slot on each side of the rail, does keyhole go in the top or in the bottom...
Just as I thought the keyhole slot went in the top screw hole for that section; noting the purpose of the keyhole slot is to put it on the screw and slide it down. I finally got the bed together, might I add without instructions, and it works great.
Aug 24, 2009 | Bassett Baby Gear
Jul 12, 2009 | Bassett Cottage 3-in-1 Crib
Jenny Lind Crib
Mini Emily Crib
Anastasia Crib
Bridget Crib
Annabelle Mini Crib
May 16, 2009 | Bassett New Haven 3 N 1 Crib
HOW DO I ACTUALLY CONVERT A 3 in 1 CRIB TO A BED?
I have two children and I changed their beds from the cribs to the day beds by taking the front or footboard part off.  You have to save this part because in order to change it from the day bed to a full bed, you have to buy a siderail kit, take the sides off, and attach the siderails to the headboard and footboard.  Hope this helps!
Oct 11, 2007 | Bassett Cottage 3-in-1 Crib
Bassett Cottage Sleigh Crib Logo
Top Bassett Baby Gear Experts
Jennifer Rock
Jennifer Rock
ray gallant
Tom Chichester
Are you a Bassett Baby Gear Expert? Answer questions, earn points and help others
