My air conditioner everstar mpk 10cr leaks water and i dont understand why. i just bought it from a friend and the bottom plug leaks i dont know how to stop it.
Ed Phillips
  • 11 Answers
SOURCE: I have an everstar mpk-10cr and it leaks water out
This cap must be in place in all coolers I have seen. Frequently there is a gasket that is identical to the type used on a common garden hose. It needs to be clean and free of cracks. They only cost pennies. I don't understand what you mean by "I plugged it up but water did not go into the normal receptacle."
I will assume you mean that this is a manually filled unit and not attached to a water source. If that is the case give me more details on what you mean.
Posted on Jun 20, 2009
co7196
  • 3433 Answers
SOURCE: looking for bottom drain plug for MPM1-10CR-BB6
This is a window unit? If so the unit should not be level. Should be lower on outside end. You may have to drill a hole in a vcorner outside to allow drainage. Good Luck
Posted on Jul 01, 2009
  • 6 Answers
SOURCE: water going into carpet instead of ac water bucket
I have this air conditioner. What I did was get a long plastic tube from home depot and connect it to the middle back drain. I then put the plastic tube outside my window, or if u have a drain somewhere put it in there or put the end into a big bucket. Let gravity do its job. I did not connect the tube to the internal bucket b/c I would have to empty it too often. The air conditioner is on top of a table so that water will flow down the tube and out the window.
Posted on Aug 19, 2009
  • 37 Answers
SOURCE: My Everstar portable air conditioner model#
Simple I believe...just run a weed eater line up the whole in the back where you have the clear tube. You can take the little back door off the power cord area to see inside where the water drips into the little tray before it goes down the hose tube. Water debris sometimes blocks the water from draining properely. The weedeateer line will clear the blockage and it will begin flowing again.
Posted on Aug 21, 2010
  • 37 Answers
SOURCE: I am looking for an air vent hose for an Everstar
http://www.supportuscenter.com/product.asp?specific=90
Everstar MPK-10CR compressor keeps running after power off, on remote. Display blanks. Only shuts off when O/L @ wall plug tripped.
call in an electrician as there is a problem in the circuit allowing power from a neutral line and bypassing the switch
Jun 30, 2016 | Everstar Portable Air Conditioner MPK-10CR
Just got a used everstar mpk-10cr and its leaking on the bottom of the back of unit.. is there supposed to be a plug there also? it has a plug higher up on back.. I know that the water pan on the side is...
Yes there is supposed to be a screw in plug. You can probably order one directly from Danby
800-496-6049 Make sure you have the correct model numbre when you call.
Hope this helped you. Please let me know. Thanks.
Jun 19, 2011 | Danby DPAC8020 Air Conditioner
Everstar Model MPK-10CR, What does flashing P2 mean?
p2 means the bottom pan is full, you need to drain the bottom, small valve on the back bottom in the middle
Aug 13, 2009 | Danby DPAC8020 Air Conditioner
Jun 20, 2009 | Danby DPAC8020 Air Conditioner
Heating & Cooling Logo
83 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
